  1. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    You suck. :(
  2. idget
    fixt :)
  3. stoooo
    stoooo Well-Known Member
    Upgraded turbo doesn't help me see around corners. When I got to a spot where I could see around the corner, the current turbo worked just fine :rockwoot:
  4. twiztid_rs
    twiztid_rs Well-Known Member
    got my STI sway bar installed yesterday in the toaster
  5. atacamaR
    atacamaR Well-Known Member
    fixed the ABS. I should probably fix or replace the charcoal canister to stop the check engine light from tripping every couple hundred miles.
  6. Ninja 4 Life
  7. 2barsti
    2barsti Well-Known Member
    Sold the advans, picked up some volks, and dropped it. Now I need to fix the damn coolant leak and get it a good wash.
  8. atacamaR
    finally got around to taking the clock out, fixed it.
  9. RS MN
    RS MN Well-Known Member
    ordered from susquehanna motorsports:
    hella xenon +50% premium headlight bulbs
    hella yellow star H3 fog light bulbs
    hella 100w H3 bulbs for my hella 500ff's
  10. WREX
    WREX Member
    installed swift springs and whiteline front and rear sway bars!!!
  11. RS MN
    started figuring out my revised plans for the RS.
    started finalizing my plans for the GTI and putting them into action:
  12. atacamaR
    patched evap canister tonight, (pencil sized puncture hole) hoping this fixes the p0457 cel that has been periodically coming on ~ every 150-200miles.
  13. zisson33
    zisson33 Well-Known Member
    Yesterday, borrowed a fuel pressure regulator and installed. I think it's time to get one of my own ! Thanks Nuke.
  14. thunderdan1313
    thunderdan1313 New Member
    nailed some rocks avoiding a deer car got towed to morries
    pics tomarrow
  15. thunderdan1313
  16. Ninja 4 Life
  17. 02subbieRS
    02subbieRS Well-Known Member
    OOOUUUCCCHHH!!!!!!! So sorry to see that man!
  18. Glock_Turbo
    Glock_Turbo Well-Known Member
    Changed the oil, 2qt royal purple, 3qt mobil 1 clean. finally installed a new denso front 02 sensor, cel went off right away, engine sounds smoother. check the turbo oil line and saw that there's no filter in there, since i couldn't find anything on if an 02 wrx had one or not. Oh yeah, and took off my WR foam intake, and wash it throughly, low dry it.
  19. RS MN
    me too!
  20. RexNEffect
    Sorry to hear, Dan. Similar thing happened with my car a year ago. Avoiding a deer, and broadsided a curb with the rim. Hamline Autobody fixed it up great, though!
  21. Glock_Turbo
    Put an SPT license trim on the back, and MNSubaru trim on the front, put front plate just below original mount to the right, and patched up and repainted old holes, looks baddass. overall inspection, feeling very good about making the trip down to wabasha for a weekend of trout fising and duck hunting. hopefully i'll see some Subies down there along 61!!!
  22. retreif
    I'm doing front and rear on mine Monday. Did you get any lateral link weldment support for your rear?
  23. BroCo
    BroCo Well-Known Member
    Don't be shootin any ducks yet, it's only early season for geese.
  24. RS MN
    bought some heads from tchaint :)
  25. pillboy
    Once I get my lazy a$$ off the couch, the wife's Outback gets its fall exterior detail and waxing today. I missed the spring one this year, so I am feeling a little guilty about that. Just a little though as it has 135,000 miles on it.
  26. pbedroske
    pbedroske Well-Known Member
    I re-wired my front speakers now I'm working on installing 6.5" speakers in the rear deck of my wrx. One down, one to go!
  27. RVO3VOM
    RVO3VOM New Member
    I installed a RalliTEK 19mm rear anti-sway bar and RalliTEK HD Rear Endlinks on my '10 OBS. WOW! What a difference.
    I can't believe Subaru sells any of their models without one. I also can't believe it took me 8 months to get around to doing this.
    Tomorrow I'll work on replacing the stock front bar with a 22mm.
  28. TSTRBOY2004
    I did mine about 2 yrs ago and havent cracked them yet...
  29. 02blubru
    I'll do it for you for a reasonable fee.
  30. retreif
  31. Shibbs
    Found a bunch of stuff I need to sell from mine. lol
  32. WRX1
    Washed both of them yesterday and will do oil changes in both of them as soon as I get done reading here and a couple of site maint items taken care of.
  33. carl
    wow, the rest of the car is really dirty! anyway, finished up the switch panel martin and i were working on. Now I just need to figure out the switch wiring once I get the ecu and can see the pin-outs
  34. RS MN
    thought about selling/trading it.
    then decided against it.
  35. Glock_Turbo
    yes, yes, somehow i keep calling all of them ducks, just geese, took 4 geese, and 1 duck for camp fire dinner, simply because that day was slow, and the damn thing kept volunteering to get shot. pllllllzzz don't report me, they'll never give you your promised benelli 12 gage.
  36. pillboy
    Didn't happen. I suck.
  37. TSTRBOY2004
    but I also didnt say anywhere in this thread that it DOESNT happen ;) just that I have had mine on for the life of my car over 2yrs and NADA nothing broken.. and I am telling you the roads I drive on EVERY DAY are worse than most will see on this forum... its hit or miss... some may break others never will...
    oh and to be on topic.. I finally cleaned it out and vacuumed it... the poor girl is still in shock
  38. xveganxcowboyx
    A noise developed today from my driver's side rear wheel during turns. I got the car up in the air and the wheels has an inch or more of play in all directions. Apparently it's time to do the rear bearings only a month and a half after doing the front. Grrrr. There was no steady decline. The thing must have just exploded inside.
  39. Glock_Turbo
    kept pushing it pass 100 on 61 from wabasha to hastings, had 2 other buddies tailing me in a 09 blazer and 09 tundra, left them in the dust on every 45mph curves then slow down to 70 on straight aways, it was hella fun, plus they wanted to see the suby performance.
  40. J.Rex
    J.Rex Well-Known Member
    Awesome, you need ign, fuel, and a start button on there and all the fuses converted to resettable circuit breakers inside the cabin.
    How does the launch control switch work, it's just a digital input into the ecu right? Why can't you just have it active when your going below a settable speed?
    I did nothing to my subaru today other than get the impact out of the trunk.
  41. carl
    analog input, the ecu uses all existing switches (so you can use the a/c or cruise control for example as an input to select maps or turn on als). you can have it activate or turn off based on a multitude of parameters (egt and tps for example) but the switch is the primary if I want it 100% off.
  42. J.Rex
    What ECU are you using, or going to use if it gets through customs?
  43. carl
    General Engine Management Systems
    ups tracking shows it's finally in Minneapolis
  44. MMC_555
    MMC_555 Well-Known Member
    Installed MB Quart PVI 216 components in the front doors. Last week I put in Polk db 401s in the back doors... Finally, much better!
  45. Glock_Turbo
    Disconnected daytime drivings lights on my 02 wrx, behind glove box, very easy to do, 2min. gonna switch out my curved wipers from bosch, it sucks, leaves streaks through the middle, gonna buy reg rainx wipers, none of that sucky a** curve wipers, even switched out front windshelds and it still leaves streaks, so it's the wipers, it was doing that when i 1st bought it.
