  1. Glock_Turbo
    Glock_Turbo Well-Known Member
  2. Rusty
    Rusty Member
    Finally installed a block heater!!! bought it from morries and am loving it, i'm parking next to the garage and it makes for much better starts and is pushing hot air by .5 mile of driving. :)
  3. Mr.Tran
    Mr.Tran Well-Known Member
    How much was the block heater? I'm assuming it was pretty easy to install?
  4. badbennyb
    I think they(most)are about $30 bucks or so. For another $20 or so I added a battery warmer, I've set em up on a timer for a few hours before I head out and it seems to help having things warmed up a bit upon startup.
  5. JasonoJordan
    what makes more diff in your opinion battery or block? how hard is the install on the block heater?
  6. idget
    block heater. If you can change the coolant you can install a block heater.
  7. JasonoJordan
    is it installed down by the water pump?
  8. badbennyb
    Don't recall specifically where the plug was but I seem to remember it being a jumbo hex type or something. I did it during a coolant change and it was super easy. And block>battery but can't go wrong with both of them.
  9. idget
    Plug on the bottom of the block on the driver's side. The heater comes with instructions. It's as easy as changing oil. Drain coolant, remove plug, replace plug with block heater, route cord, replace coolant.
  10. Tash
    Tash Well-Known Member
    just got my new LEDs for the taillights! love them, and they help alot with having my lights blacked out now i would say they are about as bright (durring the day) as non tinted tails. if it did it again i would go with the 45leds all the way around not, i went with 18leds for my running lights and its about the same brightless as the lights already were, couldnt tell a diff side by side with regular bulbs.
  11. RexNEffect
    Installed a new set of Conti. Extreme Contact all-seasons on the stockers after blowing out one of my winters at around 5 a.m. on 169 a couple weekends ago. So far, so good! I was sold on getting good all-seasons over winters after reading a thread on here, and borrowing a friends Eagle GT's for a bit. It's nice having more grip on dry pavement when the roads are clear compared to dedicated snows.
  12. Mr.Tran
    Installed new coolant line, did the Subaru upper engine cleaner and oil change. Car is running great!
  13. greaser
    greaser New Member
    went to install my gunmetal motegi 17s on the wagon. pulled one old wheel off put motegi on went to thread on the "tuner" lugs damn wrong thread. put wheel back on go to parts store get now lug nuts go home pull old wheel off put new one on go to thread lug nut on DAMN wrong thread. put old tire back on go to parts store order new lug nuts because they dont have anything that will work they will be in tuesday. :( go home put away pretty rims and tools go inside and make a drink. so lots of work and nothing accomplished lol
  14. Chuyixiong
    Chuyixiong New Member
    I went to my garage, opened the door, looked at it,walked out, closed the door, then looked thru the garage window..lol....
  15. MidnightImpreza
    I finally changed the fluids in the manual trans and rear diff. Almost 10k miles overdue. I pulled a similar move to what 'greaser' did. I got the car up on the lift, wrong size star wrench for the drain plug, got the car down, drove to the store, bought a bigger star wrench, got the car back up, drained the fluid. Mine did work out however. But next time I will make sure I have all tools on hand. Took me a almost two hours including the drive to the store. I think that's not bad for my first time. I can feel a difference in the freshness.
  16. BugIedIzzy
    BugIedIzzy Well-Known Member
    now i won't tailgate you anymore and blame your brake lights
  17. Tash
    no now you can tailgate me and not have to worry bout rear ending me by not seeing my brake lights lol
  18. greaser
    greaser New Member
  19. WilliamSTian
    WilliamSTian Active Member
    today i am getting a 60,000 mile service on my STI. I also am getting a new battery and they will also be installing my brand new Perrin turbo back system. very exciting. bout to take her on a road trip as soon as i get it re-tuned.
  20. stoooo
    stoooo Well-Known Member
    Filled it up with electricity and drove it for the first time this year.
  21. Rusty
    Rusty Member
    Block heater plus 21! WISH I DID IT WAY SOONER. it makes it starts much easier and you have heat on you by the end of the block. install took an hour. it does have a bit of a weird socket that is required, its a 14mm Allen. i bought the 14 mill allen wrench (for $14) lifted the car up at the shop, and could not break it loose. there's no room for a breaker bar, rubber hammer didn't work either. a day later i asked around the shop and one of the mechanics had a 14mm allen socket, took it off easily with a pneumatic gun. It's hard to break loose because there is high temperature gasket compound on it. Got some covalent in my hair when it gave though, watch out for that. Once it drains a bit, cover new threads with high temperature gasket compound, (i had to buy some as well, if you'd like to borrow some it doesn't take much) install and torque down to 35 ft-lbs and route cable fill with coolant and done. took only a hour.
  22. curly2k3
    last weekend we made STi vinyls for spots on my GC8
  23. AWDimprezaL
    Spun out on some black ice on 94 and smoked an exit sign. Man, my car gets uglier every year, I has a sad.
  24. AWDimprezaL
    This is a pet peeve of mine, your car is NOT a GC8. Its a GC4, or a GC6. Hugs and kisses, crazy pantz.
  25. stoooo
    Plugged my GC8 back into the wall. I guess I'll be checking the fluid levels in the battery this weekend :(
  26. AWDimprezaL
    You OWN an actual GC8, so its all good.
  27. stoooo
    :D ...
  28. JasonoJordan
    Hit a pot hole that was more like a canyon and bent my rim and blew out the tire. Wtb thread being posted short?y
    Sent from my Droid using Tapatalk
  29. curly2k3
    what the hell are you talking about? the only thing about my car that's not a gc8 is the fact that its still LHD. and its a 4 door, hence a GC...8... that 8 is you know, the JDM EJ20k(G STi block with K heads) thats swapped into it.
    I didn't say they were for the GF4 ;)
  30. AWDimprezaL
    If it doesnt say GC8 in your vin, its not a GC8. You can dress a pig up to look like a dog, teach it to bark and fetch, but its still a pig.
  31. AWDimprezaL
    PS. Beer.
  32. curly2k3
    psh, vins.
  33. AWDimprezaL
    Lawl.
  34. curly2k3
    I'll make a vinyl for that too, and create my own vinyl stating that its a rebodied Enzo
  35. AWDimprezaL
    lmao atta boy
  36. curly2k3
    perhaps something more exotic and off the wall, like a gumpert. in theory, its all the same... but then I won't be able to post in here, because it won't be a subaru.
  37. AWDimprezaL
    Ooh, good point.
  38. Chuyixiong
    blah blah Mazda blah blah on 94.. !!!
  39. FuJi K
    ohhh.... ib tsis lawm cem koj nawb! Txhob tham txog tsheb sib xeem, vim tsis zoo nkauj rau hauv no.
  40. badbennyb
    I think what Fuji is saying here is-Any use of these forums to perform or discuss illegal or unsafe activities is not endorsed or condoned by MNSubaru.com, and may be deleted at the discretion of the Moderators.
  41. Dirtyracin
    Dirtyracin Member
    Well what happened with my subie yesterday. Started out at MAP on wed picking up my new BOV, I brought it back to my dealership and wanted a tech to put it in because MAP was to busy and I was only on my lunch break. Shortly later the tech comes up and says you have to weld this one in???? I was like f to the no and called MAP starting at 2:30 consistantly on the half hour mark until 5:30 and the response was always the same hey I'm busy call you back in 10 mins, never ever receiving a call back even the next morning. Then I went to Morries Subaru yesterday to get a brake positioning senor adjusted "service bulliten" and they said they couldnt due to wires under the passenger seat not from the factory "aftermarket amp". So I headed up to St. Cloud Subaru where they laughed at morries and fixed my issue THANKS GUYS awesome service department even gave my boy a sucker and bs'd with me for a while it was nice. Now to have my new BOV installed on the car so I went to DB performance in rogers being a lil ticked off at MAP and they said the one I got from MAP on wed was the completly wrong one. Which I figured hence why I called them just wanted a second opinion. Well crap here I go back down to plymouth and they have the "correct" one in stock. But to busy to help me out and install it to make sure, so back to db where Shane said bring it right in be more then happy to help you. I bring it back and head to Maynards for a beer and bam get the phone call wrong one again. Must be really hard to read a part number. So now just straight up ticked off I told DB to order the correct one and my intake and might as well do the tune at the same time for next Thurs. Told my buddy the story and he was like how much is your tune I told him $350 for 4-6 hours of dyno time and tune. He is now going to DB as well. So in other words Morries subaru doesn't like warrenty work, MAP can't read a part number or dial a phone, St. Cloud Subaru 5 stars and thanks to DB for showing a newb the correct way answering questions and earning the business of me and my friends.
  42. AWDimprezaL
    You need to specify WHICH morries subaru, as I didnt remember anyones car here with that issue (tonka)
  43. Dirtyracin
    Dirtyracin Member
    brooklyn park morries sorry. What happens is your traction shut off light comes on, hill rollback assist light and abs light all at the same time. Also there is another service bulliten out for check engine light, traction shut off light and cruise control light flashing. All are cold weather conditions due to the brake sensor.
  44. xluben
    What model car and what model BOV?
  45. AWDimprezaL
    my guess is 2008-2010 impreza.
