  1. Glock_Turbo
    Glock_Turbo Well-Known Member
    installed used 05 STi radiator from vangstaboi on my 02 bug, put back stock air box on top of perrin shroud, added redline wetter coolant additive, lube rusty nuts, clean engine, air blow dust inside engine, top mount, radiator, pulleys, alternator, alot of sand and dust! Oil change, feel really good now.
  2. snwbdr94
    snwbdr94 Well-Known Member
    Clutch and Flywheel came in today, will be installing those either tomorrow night or Saturday morning. :naughty:
  3. eviledx
    eviledx New Member
    I put on the new hood which was ordered from bumper warehouse prior to me buying the car. Ofcourse the fitment isn't perfect. But it might be because my radiator support is tweaked from when prev owner hit a deer... top pass is tweaked a little and i'm pretty sure the pass side panel is too. I also got the new (used) hood scoop on too, no more broken hood scoop and dented hood and cracked up front bumper! Let's just say I've got a project on my hands. =)
  4. predavore
    predavore Well-Known Member
    Drove it back from Wisconsin... The Forester got 30.6 MPG this afternoon. 28+ going up, ~30 on the way back. Very happy with this car.
  5. Moleness
    Group N motor mounts. What a PITA! I am excited to feel the results though.
  6. TMF
    That was a real pain huh? I'm planning on doing mine tomorrow....
  7. Moleness
    It sure was! I am not super mechanically inclined, but i had a coach present ;)
    Iirc, edo performance has a good writeup on it...
  8. TMF
    yea, I think I saw that write-up. Fortunately Jesse (jrex) has a hoist that he is going to let me use tonight. Hopefully will be a bit easier to access the mounts. I hear the passenger side is the fun side
  9. STi Scott
    STi Scott Well-Known Member
    Over the past couple weeks I've put on the summer wheels, lowering springs, and a Varis carbon exhaust shield. Had a friend take a few pics yesterday.
  10. silver03
    ^^that is a fine looking automobile!
  11. STi Scott
    Oh, and today I performed surgery on one of my ballasts because it got water in it. Luckily I was able to fix it. For those of you thinking of clearing your headlights... take the time to make sure they are sealed good when you put them back together! I had to do it twice :(
  12. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Bummer. She's a head turner. Very much digging the understated vibe.
  13. ofspunk7
    Drove 10 hours home from St Louis. Pulled the TMIC, fixed the boost leak (again) then got a car wash.
  14. xluben
    Was it the cap on the throttle body side of the hose?
  15. ofspunk7
    BINGO! I had an issue getting the TMIC back in place the first time... the hose wasn't perfectly put back in place. I loosened, twisted a tiny bit, and the intercooler fit on perfect! Good thing it isn't any heavier, my arm is still weak from being broken and it was boarder line pushing my limits adjusting it. But all is well. Went for a test drive and car wash... seems to be fine.
  16. Rideride2
    Rideride2 Member
    Removed a block of rust, I mean my trailer hitch last night. Anyone want a class 2 trailer hitch for a 99 Legacy?
  17. BugIedIzzy
    BugIedIzzy Well-Known Member
    put my h-brace on finally!! i had a lift so i spent more time deciding Wat other suspension stuff i want than actual install.
  18. TMF
    Got the group n mounts done last night and it wasn't too bad. Only one battle wound (smashed hand), almost stripped a thread, and a couple donor parts from Jesse's car :)
    Overall, really wasn't a bad job. The key to removing the difficult rear mounting bolts, is to place your ratcheting wrench on the nut, and then have someone else hold a pry bar against the wrench so it stays on the nut. Connect another wrench to the open end of the ratcheting wrench for more leverage, and you're golden.
    Thanks again Jesse for the help (and parts) !
  19. RexNEffect
    Installed the sub finally and gave her a quick interior detail over the weekend.
  20. ofspunk7
    How do you feel about the sub? Worth the money?
  21. predavore
    No, but it's factory and it's better than not having one...
  22. SkeetsWisconny
    I'll have to check this out when its not so nasty outside. Good to meet u sir!
    ...Threw my new Hankook evo's on my summer rims and than detailed the inside. A lot of yellow lab hair over the long winter.
  23. ofspunk7
    Yeah, I know that is what people usually say.
    Brian what do you think?
  24. RexNEffect
    It's a custom aftermarket 6" sub. I just quick hooked up a 35x35 watt amp (non-bridgeable) that I found stored away. It hits hard, but could use more power and filtering I think. I got lows and highs now, but nothing in the middle range really.
    As for a stock Subaru woofer, I recently installed one into Tonie's car. Gave her some more bass on top of her already awesome system.
  25. ofspunk7
    I really would like to upgrade my system..... but less than I want more power.... so?!?!?? I guess I wait for Xmas?
  26. TickTack
    TickTack Well-Known Member
    Took the car on a little shake-down lap of Blaine to work any kinks out of the setup before autox this weekend.
  27. TMF
    Nice! Did they have open lapping at BIR or something?
    Also, what suspension are you running?
  28. RexNEffect
    BIR = Brainerd International Raceway. ;)
    I'm guessing he meant that he took it for some "spirited" driving around the city of Blaine.
  29. 4drcivicmaster
    didn't drive it, but took a picture of it. lol
  30. Mr.Tran
    Mr.Tran Well-Known Member
    Wasn't today but I recently purchased the last of what I need to finish my "phase 1" plan.
  31. 01midmetws6
    01midmetws6 Well-Known Member
    Reinstalled turbo (now rebuilt with 8cm housing) with new GS uppipe. Waiting for Koyo radiator and some brake pads to get the car ready for BIR on Monday.
  32. 01midmetws6
    What springs are these^^? Auto-X at valley fair this weekend? I might try to swing down and watch if I get a few spare minutes.
  33. TickTack
    Those are 10k/8k springs. (clarification: BC inverted coilovers)
    Yup, I'll be at autox. Note that it was moved to canterbury due to flooding. You gonna run at all this season? I'll bet all your new toys put you in some dumb class, huh?
  34. phi11
    Summer bumper and fogs were installed last night.
  35. JasonoJordan
    installing feal struts today. very excited for this as with 4 dead sti struts it felt like my pelvis was being reduced to dust with every bump
  36. SurlyOldManMN
    ** insert horribly inappropriate reference to Latina ex-girlfriends here **
  37. Mr.Tran
    Lol that's actually pretty funny Surly!
  38. ofspunk7
    Dropped it off @ GrimmSpeed to test out some new products for the 09 (08+) WRX.... product installed, installation video made, car is now back in my possession.... sitting in my parking ramp waiting for me to get off of work.... will post more details when the product release is posted on this inter-web thing.
  39. 01midmetws6
    Who's coilovers are you running, that was not something that you ran last year was it? My car would have already been in ST I believe. This over the last couple of weeks it has received a brakes and RCE yellow springs, I dont know if that would change my class. Oh and tuning for E-85. Did you ever get some real tires? Tire rack just cleared out 12 225/45/17 VR700's for about 80/piece.
  40. TickTack
    They're BC inverted coils. I was totally stock last year. Yup, got some real tires.
    ST huh? I thought you had a different turbo and more in there for some reason. All I know is more boost = BSP and a different turbo means something more. If you're still on the stock turbo, you may be in BSP with me. I don't know what porting and things do either.
  41. 01midmetws6
    I may be confused with the classes and know that when I was at the midway even it was tough to get an answer on what class the car would fall into. The turbo is not stock and I know one guy I was talking to said it would be some crazy fast class? Regardless I will get out a couple of times this year and get abused by the people who actually know how to drive their cars ;)
    What all have you done with your car? Nuke is going to be tuning the car Sat morning so hopefully I will be able to make it down to the auto-x to poke around a little.
  42. JasonoJordan
    well drove the car only from dans over in bloomington back to my house in eagan so far and im already a believer. The struts are amazing! Its like the perfect combination of handling from a soft coil over and the ride comfort of a stock wrx strut. In this case you really can have your cake and eat it to.
  43. Dirtyracin
    Dirtyracin Member
    Shaving the front bumper and doing the front plate relocation kit from grimmspeed.
  44. TMF
    Nice, I'd like to see some pics. I originally saw this over on saab92x.com
  45. Dirtyracin
    Dirtyracin Member
    should be done being painted monday night tuesday morning I will do some pics then.
