  1. pocketrocket
    Got the Sedan Front end mocked up on the car tonight. Also got the tranny cleaned up and ready for the rebuild. Finish welding up the catch can tomorrow after pulling an SR out of an S13.
  2. ofspunk7
    Wash + Wax last night. It needed it and looks sooooo nice. Too bad it might rain this week.
    I noticed a few rock chips, which seems to happen every time I wax my car. I tried to touch up my flat black grill with the same can of paint i used to paint it. i sprayed a good amount into a cup and used the back of a match to apply it. I was shocked to see that it was a lighter color of black.... even though i used the same can. So looks like i am pulling my bumper sometime this week to spray the grill again. I might have to try the matte enamel a 2nd time.... i didn't like it before, but it is pretty early to see rock chips.
  3. JesseJames
    JesseJames Well-Known Member
    Well it wasn't today, it was actually two Friday's ago, but I installed my Cobb AP, officially at Stage 1 now! AND i'm in the process of completely re-doing the garage...so far painted, installed new shelves, added workbench, got rid of lots of crap....photos of the final product to come....once it's done of course. Oh and new rotors and pads up front.
  4. ofspunk7
    Well i noticed some rock chips when i waxed my car the other day. So I grabbed the same can of paint i used to spray the grill, and applied touch ups. For some reason I got a different color of flat black... which looked really bad, you can see the spots in the picture below... so...... Last night i pulled my front bumper and pulled my grill. Then i cleaned and taped off the grill for paint
    The paint / aerosol must have gotten under the first layer of paint. After the first coat, my paint started to vein up and look really bad.... then i freaked because this was going to be a quick 1 hour job and then i was going to shoot some photos with Ben... so i made the situation worse by trying to clean up the veins. Needless to say i ended up using a razor and light sand paper to clean up the grill. Then I applied paint again.... woke up @ 5:30am and put it all back together. The paint is all one color now but i need to pull it and sand it down again. I am not 100% happy with the finish, i can see some of the edges of where the 1st layer of paint was and wasn't from the sanding and peeling.... i really wish i would have let the paint dry more before i tried to "fix it".... but not it looks good, just the minor things that i notice... i am guessing i will fix this weekend.
  5. turkeylord
    turkeylord Well-Known Member
    Wagon's at the dealership today getting a new clutch on their dime... Hopefully this one doesn't slip!
  6. ofspunk7
    What year car and how many miles?
  7. turkeylord
    05 LGT Wagon with 76k.
    So, Muscatell bought it at auction with a bad clutch, which they replaced while it was on the lot. So, new clutch worked well on the test drive, though I did point out that the pedal feet light. Turns out that the clutch they put in it was the wrong one mis-boxed at the factory, lol... Must've been for a 2.5i or something, no wonder after break-in it was slippin like crazy under boost.
    New clutch feels great, but it's gonna take some getting used to. I already killed it once, lol. [​IMG]
  8. chad1.5litertoaster
    chad1.5litertoaster Member
    What did I do to my Subaru today?
    I bought one. A 2007 Forester. :)
    What should I do to this thing first?
  9. retreif
    STI rear sway.... anti roll bar.
  10. curly2k3
    replaced the radiator for a newer style one that wasn't a worthless pile of crap, also decided that the DD wagon needs sway bars and endlinks
  11. kickin_81
    kickin_81 Well-Known Member
    Inspected the radiator cap and the air bypass valve. No leaks.
  12. dmoo
    dmoo Well-Known Member
    old busted, new hotness
    messy job is messy.
    The fit was surprisingly good for an aftermarket hose. it was cheaper to buy a premade one rather than piecing it together, and cheaper then a replacement from Subaru. I would recommend it if you have a high pressure line that is leaking at a factory connected joint (hard to soft line).
  13. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Fixed boost leak(s) over the weekend thanks to Derek/Dan/Nuke.
    Started playing with an early version Nuke tune. Makes me feel kinda giggly. My apologies to whoever was behind me when I almost threw it sideways on the first 90* right a couple blocks from home. Didn't quite expect that... :jumpy:
  14. Black_peter
    Black_peter New Member
    Found out I am getting full boost =D
  15. 4drcivicmaster
    put on my new rear bumper. (old one was missing some paint)
  16. silver03
    removed front and rear wiper arms, sanded, primed, than painted nice flat black with light coat of clear. its the little things...
  17. RexNEffect
    Upgrading Aqua Thunder's exhaust.
  18. Lukasz
    Lukasz Member
    taking off a clear license plate cover that is apparently illegal and grounds for a $108 ticket! i did not realize clear plastic obstructs the plate, it was there when i bought it and never even thought of it.
  19. Mr.Tran
    Mr.Tran Well-Known Member
    Took my car to Turbo turtles to check around for my Vacuum leak. Ended up getting a new coolant reservoir in, new bpv gasket, tightened bpv hose, and to top it off Dan pointed out the previous owner deleted the TGVs. Thanks a bunch Dan, the car feels alot better!
  20. stoooo
    stoooo Well-Known Member
    Got all of the outstanding paperwork sorted out so I can drive it again. Yay ! Whodathunk that coilovers and an exhaust could be so troublesome ? Not me, that's for sure.
  21. kev004
    kev004 Member
    Got me some new kicker speakers for my foz
  22. turkeylord
    Found that yes, you can fit a Toro 924 Powershift in the back of an LGT wagon, if you leave the hatch up. Friends with pickups? Who needs em! :foreveralone:
  23. '05_STi
    '05_STi Active Member
    Ordered the AMS catback with an Invidia Bellmouth catless downpipe. Going stage 2 finally!
  24. stoooo
    Took it for a run up to Nicosia to watch the Sti v Evo Time Attack Shootout. I'll post pics later.
  25. ofspunk7
    Gave it an oil change.
    Looked for a boost leak because i just had a feeling, my vacuum was sitting nice @ -20, my idle was fine... but my MPGs were way up .... noticed oil spray on my TMIC from the TB hose. Spent a good 20 minutes trying to get the clamp just right.... the TB hose and the IPR TMIC have a very small area for connection, my clamp kept slipping off of the bottom of the TMIC so it wasn't secure. I am pretty sure it is finally on there good, i did some testing last night and it looked clean (no oil spray). I guess after a day or two we will really know what is going on.
    I knew i shouldn't have been getting 19MPG on E85.
  26. Lukasz
    Lukasz Member
    grimmspeed license bracket is on now to cover up the old ugly holes someone decided to drill into the bumper!
  27. turkeylord
    Bought a used AP and flashed a stage 1 map. Stage 2 parts should be here next week! :)
  28. JuStaWRX
    Just got her back from Minnetonka Subaru - got some hose leaks fixed
  29. turkeylord
    Stage 2 parts are all here now. Gonna wrap the DP, then need to find time/help to get it all installed...
  30. mosho93
    mosho93 Active Member
    This past week I installed a Grimspeed 3 port BCS and let Nuke work his magic.
  31. LawnMaster
    LawnMaster Well-Known Member
    New summer wheels - Rota Gravel 18x8.5 et44 and OEM 245/40/18 tires.
  32. ofspunk7
    ^ I like the white
  33. carl
  34. Buddy
    Buddy Well-Known Member
    Dropped the wagon off with sheen. He's going to work his magic on my very dull black paint and bring it back to life. Can't wait to see it.
  35. turkeylord
    Put the wagon up on ramps to get an idea of what I was in for on my UP/DP install... Found out it's already got an aftermarket UP! Anyone recognize the brand? Non-flex, EGT bung, and kinda unique flanges. The manifold flange has a beveled edge and the turbo flange has a thicker center area, a step, and a thinner outer part... These are the best pics I could get.
    View attachment 25042 View attachment 25041
    So anyway, that should save me 3+ hours :)
    *edit*
    Invidia?
    http://legacygt.com/reviews/showproduct.php?product=115&sort=2&cat=12&page=1
  36. Tash
    Tash Well-Known Member
    just went winless!
  37. turkeylord
    Got the downpipe installed and flashed a stage 2 tune... Awesomeness!
  38. Black_peter
    installed the clear side markers that showed up ohhhh 5 minutes ago ! lol
  39. 4drcivicmaster
    installed hawk hp+ pads in the sti. soooo nice, but a little loud...
    fixed. lol
  40. FuJi K
    ^^^ we need to do your fuel pump setup. and crank up the boost.
  41. 4drcivicmaster
  42. Moleness
    HP+ or HPS?
  43. 4drcivicmaster
    +++++++++++++'s lol
  44. dmoo
    short sleeves, shorts, no gloves, flammable asian hair, welding like a Boss.
    cars looking good. will there be an epic long build thread on this car somewhere?
  45. TMF
    I just ordered the HP+'s for mine :)
    I'm not too concerned about the noise (I'm basically metal on metal now :mad: ), but what did you do to quiet them down?
