  1. kickin_81
    kickin_81 Well-Known Member
    Installed this fix to get rid of the pesky P0420 CEL. I hope this did it because the CEL comes on just about every day now where before it was only once every other week.
  2. ofspunk7
    Went on the hunt for a boost leak.
    Pull the TMIC, looked for the usual suspects (hoses and clamps). Turns out my TB hose was loose on the end that meets the TB. I have only had the rubber gasket fail on that end, but never had the hose get loose. I am guessing it is from pulling my TMIC so many times. I could see installing and uninstalling enough times making it loose... well that is the SCIENCE my brain came up with.... I pulled the hose off the TB with very little effort. So I am 99% sure that was the issue. When installed correctly it should not budge. The worm clamp should hold it down on the lip of the TB. I cleaned the hose out, cleaned out my TMIC. Forgot to mark the top of the TB hose .... :banghead: ...... installed, checked fitment, uninstalled, adjusted, installed, checked fitment about 5 - 6 times before I got a good fit. Put it all back together. Letting the gasket maker dry before I go out for a test run. Sucked to tweak it so many times, but I feel that the TB hose has a better position that it did the last time it was installed. The worm clamp on the TMIC end seemed to have a tiny bit more lip to grab onto, and the clamp did not want to slide like it normally does. I guess we'll see if it was a success or not over my lunch break.
  3. xluben
    You should be using a t-bolt clamp.
    Subierex and ofspunk7 like this.
  4. Nuke
    Liar
    We use standard menard worm clamps just fine
  5. ofspunk7
    Washed it too
  6. gc8
    gc8 Well-Known Member
    Cleaned it up after going way too long without a nice bath...
  7. PaulasaurusREX
    Sold it :(
    However... Grocery Getter Foz Edition photo thread coming soon!
  8. svxninja
    svxninja Well-Known Member
    Install Boost gauge
  9. ofspunk7
  10. svxninja
    Maybe later tonight when I pick up my fresh painted door from legendx aka tommy
  11. yuseforester
    Dropped my wife's Forester XT today onto some 03 WRX struts/springs; looks pretty sweet but wish that I would have opted for 1/4" saggy butt spacers...looks like that will be the next part order!
  12. drunknmunky81
    Looking gd yusef...gonna have to drop mine soon here...maybe after I get it from the shop...
  13. fancyfootwork15
  14. kickin_81
    I felt the same way after I lowered my first FXT. Loved the lowered look but it just looked butt heavy. Don't take a corner with heavy people in the back seat either. :eek: :eek:
  15. yuseforester
    Did you remedy with saggy spacers?
  16. kickin_81
    Changed the coolant. They don't put the plastic plug in a very good location do they? It's difficult to get into comfortable postion to loosen it and once you get it off the coolant falls onto a beam that spreads coolant everywhere. I probably caught 75% of it with my pan, and when I opened my mouth to say oh ****, I got some in my mouth. mmmm, sweet.
  17. kickin_81
    I don't think the spacers have been engineered yet at the time so I never had.
  18. ShortytheFirefighter
    I picked up some "road bling" in the form of what looks like a half inch bolt in my right rear tire. It went into the perfect spot so you can actually see the outline in the sidewall :banghead: so I had to get a new set on order. Michelin Pilot Super Sports here I come!
  19. 2barsti
    2barsti Well-Known Member
    Picked up some 255/40/17 Kumho Ecsta XS tires.
  20. TMF
    yea, its a pain...and part of the reason why I've been putting it off on my car. I think it helps if you only open the plastic plug a small amount to it doesn't ole faithful everywhere.
  21. svxninja
    I took my door off and totally apart, to put my newly fresh painted one on... I just hope I remember how to put it all back together tomorrow
  22. Starkall
    Starkall Active Member
    Put on JDM coachworks alcantara shift boot and brake boot. I'll put pics up later
  23. Soupboy
    Soupboy Well-Known Member
    Put off washing it, again.
  24. drunknmunky81
    Got it back from the shop. Great work done by Devoted Auto Works of WBL. Great guys to work with. The owner Yang knows his stuff. Great guy to talk to also.
  25. svxninja
    What you end up doing ?
  26. drunknmunky81
    Had a timing pulley go out last wk. They ened up having to do the timing belt and head gasket because it was leaking oil.
  27. svxninja
    glad you got it fixed
  28. idget
    Beat tangledupinblus bugeye on foot. 5mph street racing y0. Subaru style.
    svxninja likes this.
  29. svxninja
    finished my door...
  30. LightningLemke
    LightningLemke Active Member
    Got it aligned by Jeff and drove it around a bit. It's nice being able to drive my car again.
  31. tangledupinblu
    It was 3.8mph ass...quit pretending to be fast!
    Was driving to Sheeniss' place and while on Larpenteur, when i pushed on the gas pedal i felt it snap and go to the floor. Cable broke under the hood about 6 inches from the throttle body. Praise God, i had a spare in the garage at home which Sheen threw in the car while i was working on his house. Thanks to both of you!
    kickin_81 likes this.
  32. gc8
    Sounds like one of those stomach dropping moments...glad to hear everything worked out okay.
  33. Frogy
    Frogy Well-Known Member
    I pulled the crappy prodrive front sway and put the stock bar with new bushings and kartboy links in, it is nice not to hear clunking when I hit a bump
    I also bled the clutch and greased the pivot pin for the clutch fork
  34. gc8
    De-mud flapped...
    Before:
    Halfway:
    After:
    Woot likes this.
  35. ofspunk7
    Rolled some miles and took a picture.
  36. Tash
    Tash Well-Known Member
    Ha I rolled more miles then you! Step your game up! On a side note **** 555...
  37. tjkolb
    tjkolb Member
    I managed to get the infamous spun bearing on my 02 WRX...sad day...I think? So now I'm on the hunt for the 2.5L and do a nice swap... :)
  38. dmoo
    dmoo Well-Known Member
    put a car cover on it in the garage so i don't have to look at it, and now i can safely use it as storage space...
    Subie Lovers likes this.
  39. Wirtz
    Wirtz Member
    Flipped my wheels with the new slimmer fitting tire to the other side for uniform gap/camber and no more rubbing until I get new tires
  40. gc8
    Got my Cobb heat shield in the mail and polished it up to look like new. Now just gotta wait for the TurboXS Stealthback to arrive...
    ofspunk7 likes this.
  41. Hagadorn
    Hagadorn Member
    Got new tires put on my stock wheels. Had my coworker paint them white while he was going to school for auto body and paint. FOOO FREE!! Turned out pretty nice if you ask me. Then kind of old but I reinstalled the momo shift knob that came with the car. The leather was all worn out so i striped the leather off sanded it down then stained and sealed it.
  42. slacker-wrx
    slacker-wrx Member
    Aww so that was ur car a devoted!! I saw it the other day when I was over there. Alway wanted to get one, especially in white!
  43. Starkall
  44. svxninja
    Were you going south on 494 by minnetonka blvd at about 715pm?
  45. Starkall
    nope, I live about 2 hrs west of Minneapolis. :)
