  1. turkeylord
    turkeylord Well-Known Member
    Took mine to the track for the first time since last year when I was just stage 2. I'm 1.36 seconds faster now :)
    13.18@105
    Car ran perfect (thanks RS!), but my driving still needs work, lol...
    *EDIT* Video Added [​IMG]
  2. babiker712
    babiker712 Well-Known Member
  3. svxninja
    svxninja Well-Known Member
    Recieved Retrofit kit for headlights, but it will be a couple of weekends till I can install :(
  4. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Dropped it off at RS for a new, new clutch. :(
  5. turkeylord
    wat
    What are you going with this time?
  6. SurlyOldManMN
    Not sure. Depends on exactly what happened. If it turns out I straight up torched the clutch then there is a good chance it's a driver education issue and another HDSS will be fine. If there is something else afoot then I'm looking at something beefier. Maybe a ClutchMasters FX300 or a CC stage2.
  7. turkeylord
    Dealer put in a OEM Sachs when I bought it last year - so far so good, even w/stage 3e & 26 drag race launches. I full expect it to fail eventually, and I'm all but sold on the FX300 based on all the reviews I've read.
  8. SurlyOldManMN
    Welp... the good news is it sounds like it was just the clutch plate that fried. The bad news is that means I apparently don't know how to drive my own car.
    Chong, where you at mang?
    atacamaR and turkeylord like this.
  9. Wirtz
    Wirtz Member
    Took a 0-60 (well 75 lol) vid at one of the many stop lights near my milwaukee apartment. Still stage II on a dp, cb, walboro, and open source setup from when I bought the car
    Estimated at 4.5 (looked at it frame by frame) at 64 mph on the speedo as my it reads a hair slow but not bad. I'll take another better one when the opportunity comes.
  10. gc8
    gc8 Well-Known Member
    Changed the oil and discovered a exhaust leak in my midpipe->axle back connection :mad:
  11. GiMp
    GiMp Well-Known Member
    Your check engine light is on :confused:
  12. Essemo
    Essemo Member
    Last Friday ko from nf installed my new exedy stage 1 clutch :)
    ofspunk7 likes this.
  13. Wirtz
    Wirtz Member
    Haha I added an annotation to the vid. My gas cap needs to be replaced so I've been throwing an evap leak code on an off lately :rolleyes:
  14. wrxwied
    wrxwied Member
    Took my WRX down to RS to get a lean code checked out and fix some boost leaks. No more CEL for me!
    Ctracey218 likes this.
  15. Juks
    Juks Well-Known Member
    Put in new spark plugs. Who would have thought new plugs will make your car run better?!
  16. Wirtz
    Wirtz Member
    Took the grinder to the rear fenders and pretty much flattened the hell out of it. No more rubbing on a 9 wide +13
    Juks likes this.
  17. Starkall
    Starkall Active Member
    Started putting my 11 wrx back to stock for trade in. Got the AOS off, stock injectors back in and intercooler off and stock air box on. Tomorrow will be gauges out, stock dp and exhaust, remove coilovers, install stock fuel pump, and remove my Prova steering wheel.
  18. phi11
    Last night I installed d-specs
    And tonight I did the RSB (20mm) into the GT
    I can't believe I waited 7 years to do the sway bar.
    turkeylord likes this.
  19. Grayguy
    Grayguy Well-Known Member
    Wow, I've had my (current) GT for 7 months and I already have a bar about to go in (cusco 18-20-22)
  20. subie senior
    subie senior Active Member
    put the stock wheels back on with the all season tires on them. my son was a little upset that i took the Volks off the car. thought i had more time yet before i would need the other tires. would rather do it now than to wait until it is snowy and cold. IMG_0695.jpg IMG_0865.jpg
  21. silver03
  22. Threshld1
    Threshld1 Well-Known Member
  23. silver03
  24. SurlyOldManMN
    Officially hit the break in mileage on the new, new HDSS. Looking forward to remembering what boost feels like.
    Ctracey218 and turkeylord like this.
  25. Juks
    Drove while it was snowing. Officially scared the **** out of me. Gotta love the U.P.!
    Almost time to break out the rex...the asphalt has been begging me not yet, but I think the time is near.
  26. atacamaR
    atacamaR Well-Known Member
    picked up the new ride this morning :D
  27. ofspunk7
    ^ awesome, welcome back
    atacamaR likes this.
  28. tangledupinblu
    God those wheels are amazing. Your bro letting you borrow them, or did you buy???
  29. atacamaR
    they are part of the deal. I wasn't sure when i first saw them, but they've been growing on me quite a bit. Bonus is you don't see them around ever
  30. tangledupinblu
    I've only seen them once before. Never on a street driven car tho! Big "plus" to the fact that they are one of the lightest wheels that you could ever own!
  31. atacamaR
    No doubt they will make a fine summer wheel. :) It also will make it harder to choose my other car when I eventually make it up to BIR.
  32. stoooo
    stoooo Well-Known Member
    Took it wonderland...
    DSCF2876 by stoooo, on Flickr
    (OK, technically not *today*, but it's taken a while to upload all the pics.)
    Ctracey218 and tangledupinblu like this.
  33. tonyv
    tonyv Well-Known Member
    took my car out the impound lot.
  34. atacamaR
    switched out some exhaust bits and went from too loud/drone-y to too quiet, meh.
  35. svxninja
    Finished Retro fit
  36. gc8
    Installed my new (to me) Cusco rear strut bar.
    Also, learned that if you take the seat belt off and it turns upside down...it will lock since it thinks the car rolled. Had to search for a fix so if this happens to you, just bolt it back into it's normal position and give the belt a good yank. It should come unlocked.
    SkeetsWisconny likes this.
  37. Jkdfiend
    Jkdfiend Active Member
    Disconnected the DRL and loving it. I feel like I'm in control again. :frantic:
  38. atacamaR
    replaced cam sensor driver side, still waiting for 2nd cam sensor to arrive. Hopefully, this will solve the cel that comes on only at idle/below 1200rpms. Also broke out the black plastidip and hit the sti/impreza badge. I still need to get to paint the S U B A R U badge though.
  39. turkeylord
    Drove mine down to Jordan on Saturday to pick up this beast for the wife:
    atacamaR and gc8 like this.
  40. tjkolb
    tjkolb Member
    Delivered the car to Nuke on Sunday...time to replace the blown motor! :) Excited about the outcome...not excited about my checking account...lol
  41. stoooo
    Dropped it off at the storage place. No idea when I'll be seeing it again :(
  42. JuStaWRX
    ImageUploadedByTapatalk1350609172.559091.jpg ImageUploadedByTapatalk1350609185.381650.jpg ImageUploadedByTapatalk1350609209.565679.jpg ImageUploadedByTapatalk1350609220.615034.jpg ImageUploadedByTapatalk1350609233.093372.jpg
  43. JuStaWRX
    ^installed Maddad Whisper today. Great sound! loved my Greddy evo 2 system, but very happy with the new set up. Videos hopefully will be posted soon.
    EDIT: So, after getting the current system off, the midpipe from the Maddad did not quite fit into the the ERZ. That little lip (very technical term) was about 1/8'' too wide, so I ground it down and got it to fit much better than the photo showed. Afterwards, cruised from New Brighton to the MOA and back, and am extremely happy with the in-car noise level, and the sound when she gets a little push.
    (I also took off the summer, wheels, and put on the all-seasons for the winter. Even though it is just going from 17''s to 16''s (from those in the photo to the stocks) the stocks just look so small. In a winter or two, I may have to make my "summer" wheels into my winters, and actually invest in a decent set of summer wheels...).
  44. idget
    15min knuckle install on the rsvx last night. front springs and radiator hose guard this weekend. It's like I own the car again lol
    Thinking about a 12a rotary swap in a Subaru. 360 maybe?
  45. tangledupinblu
    :confused:
    You did "finish" pretty quick.
