  1. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Secksay hatch is secksay.
  2. euro
    euro Well-Known Member
    it's not the nozzles, the solenoid pump for the front jets isn't working but the back ones are. I'll unplug it to check if the contacts are ok before ordering another one
  3. thakrazymule
    thakrazymule Active Member
    I know you said its not the nozzles. But just for future reference. A torch tip cleaner works awesome to clean them if there clogged. U get several different sizes to push in there.
  4. JasonoJordan
    What year is it I think I have a spare pump laying around.
  5. euro
    2005 sent you a pm also
  6. 03subyR
    03subyR Well-Known Member
    I like your licence plate.
    Windchaser likes this.
  7. ofspunk7
    I like the mint green 10 speed hanging from the roof!
  8. boone1186
    boone1186 Active Member
    Installed Perrin CAI and wowowow jet engine turbo sounds weeeeeee! I think it added Atleast 59 hp..
  9. thakrazymule
    Changed the oil. Gave it a good bath, inside and out. Including some leather treatment. And replaced some worn out plastic pieces with some sexy silicone.
  10. euro
    ordered a scangauge cable so i can start using my scangauge II
  11. ofspunk7
    Ordered ARP Headgasket Studs from IIR.
  12. Chux
    Put the engine back in it, put plates and insurance on it, washed it and took it for a drive....
    Got this car a couple weeks ago. Crank bolt had backed out (again):
    Looks like the crank sprocket was cut off the last time around:
    And the bad side....
    Jerk deer
    Going to drive it for awhile to make sure the kinks are worked out, and once the fender and mirror are fixed, it will be for sale
  13. JACKRBT
    JACKRBT Well-Known Member
    Installed a Nameless axleback exhaust.
  14. yarpirate
    yarpirate BANNED
    Plowed some snow
    boone1186 likes this.
  15. ofspunk7
    Took off a few parts. Thanks to Ben, Ryan, Nick and Mike for helping out.
    Headgasket sludge.. i think i had a bad setup since day one (factory). More then a few lines looked like this
    Blown gasket and rusted POS exhaust bolts. Not quite straight.
    SurlyOldManMN likes this.
  16. Tash
    Tash Well-Known Member
    Not going to lie, my arms hurt. I'm also sad that other bolt didn't break, I can't claim to be strong now :(
    ofspunk7 likes this.
  17. Starkall
    Starkall Active Member
    Just turned over 4k miles, and I hit a snow bank :) may possibly need a new front bumper. Or just deal with the slight spider webs in the paint and tiny crack by the passenger side vent that popped out. Lol **** it, it's just a car I guess
  18. ofspunk7
    Motor out
    atacamaR and 03subyR like this.
  19. euro
    slid into a snowbank and gouged the paint a little on the fender and door, ffffffffff. i wish i had a cool story to go with it other than **** ice.
  20. svxninja
    svxninja Well-Known Member
    I know the roads are horrible, I slid into a sign trying to make a turn maybe going 15 miles an hour. Luckily was not driving the subaru
  21. cloudpost
    cloudpost Member
    Car was stuttering and throwing a ton of codes recently - misfire, idle, MAF overload, Cleaned the MAF sensor, replaced the fuel filter, and did an oil change (Its the first time its seeing synthetic! T6 baby!) Took it out on the back road and the symptoms didnt come up like it usually does. Hopefully that solved my problems!
    I also found some corrosion on my MAF sensor :mad: so I ordered a used one off NASIOC. Even if my problems are solved, maybe ill get better MPG
  22. GiMp
    GiMp Well-Known Member
    Ordered a few Items
    Grimmspeed Up Pipe with Turbosmart EWG 45 - New Style
    Grimmspeed Adjustable Wastegate Bracket
    Grimmspeed Crank Pulley
    Subaru Master Gasket Set
    Grmimspeed TGV Gaskets / Up pipe gaskets
    Gates racing timing belt kit with all pullies and water pump
    Killer B Oil Pickup / Splash tray
    AEM Oil Pressure Gauge
    I ordered these Thursday night at 6pm CST from Josh at Import Image
    Grimmspeed got me the crank pulley, gaskets and IWG bracket shipped Friday and to me already on Saturday! Thanks guys!
  23. NastyLeggySS
    Lift and align.
  24. BugIedIzzy
    BugIedIzzy Well-Known Member
    Then bled the brakes
  25. WLGT
    WLGT Well-Known Member
    Washed it, changed the oil to Rotella T6 for the first time, flushed brake fluid, installed grimmspeed heat shield and next week, install the master cylinder brace and finish up the E85 tune:).
    I'm done with modding/upgrading, only thing left is SS lines but I'll wait until I see a deal on some locally
  26. SurlyOldManMN
    :coffee:
  27. cloudpost
    cloudpost Member
    Cleaned the IACV and replaced the gasket in hopes of it solving my jumping idleing problem... NOPE! :(
    Super annoying as it is causing my RPMs to dip and surge when accelerating out of 1st and 2nd!
    EDIT: FIXED IT! muahaha feels good! Turns out it was the cruise control cable being too tight. I must have re-positioned it when I was cleaning my MAF!
    EDIT: Nope... It came back in the morning. WTF :mad:
  28. svxninja
    Replacing thermostat and flushed heater core
  29. mdstahl
    mdstahl Member
    Had a P1443 evap code show up the other day. Cleared it yesterday... Showed up again. Figured it was the one of the vent/drain tubes froze up from some of the recent snow packed up underneath between the lines. Thankfully was able to get the car thawed out and it went away.
    On the bright side look at what showed up at my door today, wooohoo! ....haven't technically installed them yet, I'll give an update once I do. :)
    -Swift Sport Springs
    -Motegi MR118 18x8 +45
    tangledupinblu and boone1186 like this.
  30. Glock_Turbo
    Glock_Turbo Well-Known Member
    changed spark plugs, fuel filter, oil change, pcv. car started to drive sluggish, thumping and hesitating on 5th gear on incline and accelerator, was about to tear the whole car apart, but a $8 MAF cleaning solved the problem. stage 2 back in business!
  31. WLGT
    Finally finished my winter(e7o) tune, pulls were all around 330whp. Vf52 has power to red line:eek:
  32. SurlyOldManMN
    Nice! Similar wtq figures?
  33. Straitup D
    Straitup D Well-Known Member
    added yellow fogs, and fixed the multi switch in the fozz
  34. derp
    ignored it again. no wheels, no attention. hurry the **** up tax man
  35. mrrhode04
    mrrhode04 Well-Known Member
    TGV deletes.
  36. Nuke
    lol it's a dynapack, go figure
  37. Essemo
    Essemo Member
    last saturday my friend brian helped me install a new down pipe and a cobb SF intake. Then we took the car to NF to get tuned. :bounce::) Then on sunday I installed some new HID's and today I put in the illumination kit
    MNBubba likes this.
  38. SurlyOldManMN
    Hopefully found it a new buddy. We'll see come Wednesday.
  39. 03subyR
    How long did it take you? This is something I want to do but it's not my favorite install.
  40. mrrhode04
    It probably took about 6 hours, the longest part is to remove the divider and fill the holes
  41. Glock_Turbo
    waiting for my tax refund than getting my fuel pump, injectors and getting it tuned at Devoted too.
  42. derp
    Ignored it again. Havent been into the parking garage in a week.
  43. jblewis
    jblewis Well-Known Member
    On Saturday, I changed the spark plugs. The FXT had been feeling a little hesitant at low RPMs, and gear shifts. The old plugs didn't look bad, but the car feels better with the new ones... Of course it could just be from disconnecting the battery and forcing the ECU to relearn. I'm glad they are a long-interval service item.
    On Sunday I went to Sears and bought a couple socket extensions that would have made life a lot easier on Saturday.
  44. NastyLeggySS
    Firestone champion hps saturday
  45. stiv5
    stiv5 Well-Known Member
    Put in a new starter last week. Starts like a Champ now.
