  1. euro
    euro Well-Known Member
    oil change, washed it (discovered more touchup paint then there is rice in china) and decided i need new tires
  2. masube81
    masube81 Well-Known Member
    Summer wheels back on. alignment done, paint front lip back to black to match the bottom line side skirts and diffuser.
  3. Subie Lovers
    Took a picture of it!!!
    turkeylord, Ctracey218 and phi11 like this.
  4. tangledupinblu
    (Yesterday) took the rims/tires off of the RSVX and threw the winters from the WRX on it(thank God for the universal usage of parts between the two)! Put the summers on the WRX. Sheen and i did the rear rotors, pads, bled the brakes, and put new-used WRX calipers on the back of the RS! Still need to do the Master Cylinder though as i have about 50% braking in it right now. Lol
  5. ryjacobs
    ryjacobs Well-Known Member
    First wash of the year yesterday. ImageUploadedByTapatalk1367166843.837463.jpg
  6. thakrazymule
    thakrazymule Active Member
    "Flushed" or more diluted the power steering with some fresh ATF. Stuff in it looked like old oil. No red to be seen. Took 2 quarts before it finally looked clean. Then did some spirited driving. Car was running awesome today! Not sure if it was the weather, or the Shell gas I put in, but I swear it seemed a little faster then normal today. Also pulled 25 MPG highway, a new personal best! :D
  7. TMF
    The gas stations are probably off of the winter blends now ;)
    Plus I noticed yesterday that I finally hit peak boost again...probably the warmer temps!
  8. Weird0
    Weird0 Well-Known Member
    Just installed my jdm tail lights yesterday. Then it rained last night, now I have to re-real the lights since water got inside one! Uuuurrrrggggg
  9. TMF
    Put on my summer wheels yesterday and put the muffler delete back on.
    I was curious what the muffler delete sounded like from outside the car (mainly for the autox decibel limit concerns), so I took a quick video. (yea, I'm a dork). Don't mind my missed shift on the way back :mad:
    JuStaWRX and ofspunk7 like this.
  10. Shane86
    Shane86 Well-Known Member
    I stole some wheels from the WRX, and threw them on the legacy.
    I can confirm 245/40-17 fits fine on a 17x8 +45 wheel, with no rubbing at stock height.
    tangledupinblu and turkeylord like this.
  11. tangledupinblu
    Newb!
    Sounds good!
    ofspunk7 likes this.
  12. STiCH
    STiCH Well-Known Member
    Swapped out the winter wheel setup with the stock setup.
  13. 03subyR
    03subyR Well-Known Member
    Switched to E85 thanks to Nuke and NF team.
  14. Kenny06sti
    Kenny06sti Member
    Got the potenzas mounted today, now that the snow is gone until next year..(I hope)
  15. euro
    someone didn't check the forecast....
    Mr.Tran likes this.
  16. Kenny06sti
    Kenny06sti Member
    Brutal.
    euro likes this.
  17. xluben
    I thought I saw you going from University to 694 last night!
  18. phi11
    Stripped some parts off and sent them to costa rica.
    atacamaR likes this.
  19. 03subyR
    It was me :)
  20. JuStaWRX
    Last photo shows worst of center caps... before I acquired them, they were winters, and I have been using them for summers. For those looking to Plastidip wheels, this was a very simple way to give a fresh look to some old, scuffed up wheels. Maybe next summer, I will switch up the color. Thanks OfSpunk7 for introducing me to the product! I bought a few extra cans; now to decide what else to dip.... I'll try and post another photo once I get them on the car.
  21. ofspunk7
    Can't wait to see them on the car.
  22. silver03
    Picked up freshly powder coated satin black wheels!
    tangledupinblu, idget and phi11 like this.
  23. STI_guy
    STI_guy Well-Known Member
    Just got done doing my timing belt,water pump, and thermostat.
  24. derp
    I put oreilly fogs on the probe.
    needed moar light output.
  25. ofspunk7
    Over my lunch break I replaced my broken fogs. Last weekend i discovered I had one fog light busted up (only three months old) and the other was cracked around the base and fogged up. Today my new fogs came in the mail (Amazon). I was stoked to find my fog lights $50 cheaper then I had paid on Amazon with my prior purchaces. Now this is the 3rd time I have ordered fogs off of Amazon for my car. The first time I got them they were 100% perfect. Then I had to replace the passenger side this past winter/fall thanks to a rock. I got the same foglight but picked it up through a different vendor. They sent me the correct light with the wrong mounting hardware. I had to remove the old hardware off my broken light and swap it to the new setup. Today I was happy to find that the new company I used on Amazon (3rd vendor) sent the correct hardware.... however they didn't include the brackets (nuts) or new bolts. WTF!!! So once agian I had to strip the bracket/nut off of the old mount and reuse my screws. However, those were just minor issues. The new fogs work great and I am happy to have my HIDs back in.
  26. turkeylord
    turkeylord Well-Known Member
    Got a couple pictures from Tim@Powder Keg today :)
    He'll ship them Monday, tires should get mounted Tuesday, and I should have them on the car Wednesday night!
    BroCo and Subie Lovers like this.
  27. tangledupinblu
    Pics or it didn't happen!
    Now you just need to hit up Chris at Flawless Front Ends and get them covered! My headlights have been holding up much better with the clear protecting them from the oxidation and rocks! ;)
  28. CarpalTomO
    CarpalTomO Well-Known Member
    Removed some rusty aftermarket fogs from my light bar, mounted my horn behind the grill, and swapped some quick releases into the rear strut bar after cutting the trim caps to hide the mounting ring.
  29. Subie Lovers
    Or you can have me pick them up for you and they'd be on the OBXT by Monday ;)
    turkeylord likes this.
  30. badbennyb
    I've driven it a couple times this year, that's something. Started a list of what's been done to it just in case I have the guts to sell it. Hmmmm, we'll see. I've been telling myself I'd do it for some time now but haven't yet.
  31. JuStaWRX
    Finally put on the plastidipped summers. I'm very happy with them! ImageUploadedByTapatalk1367773027.785154.jpg
    Unfortunately, I also was able to see closer many of the battle wounds that she has sustained over the past couple years. Very saddening...
    03subyR and ofspunk7 like this.
  32. DIRTY D
    DIRTY D Well-Known Member
    sporting the summer set up with new sways front & back with ne 20130505_130032.jpg w end links, ridin rails now
    Rswrx and ofspunk7 like this.
  33. ryjacobs
    Sheen detailed my car on Saturday and Nuke tuned it this afternoon. Great weekend! :)
    Thank you both!
    idget, ofspunk7 and turkeylord like this.
  34. xluben
  35. SCIFIDELITY
    SCIFIDELITY Well-Known Member
    New summer wheels and tires installed.
  36. WLGT
    WLGT Well-Known Member
    New "summer" tires, Bfgoodrich g-force sport comp-2:)
  37. thakrazymule
    Had Discount Tire in Stillwater rotate and re-balance my tires. And fix a slow leak, valve stem was the culprit.
  38. TMF
    Nice! Got a bigger pic? They kinda look like Rotas...but I could be wrong.
  39. derp
    Subtle solutions alternator cover
  40. BroCo
    BroCo Well-Known Member
    They look great! What powder coat color is that? I want to get my silver BBS done.
  41. xluben
    I can confirm. Photo if needed.
    derp likes this.
  42. derp
    I wouldn't mind seeing your photo :)
  43. CLee89
    CLee89 Member
    today I put on my cat back exhaust that I recently purchase from a member of mnsubaru forums. Thanks prezawagon, the exhaust sounds great. Not to loud and has a good low tone. I also tinted my back tail lights which to my opinion looks pretty bad ass. Wish I could show you guys some pics but maybe later when I have more time. Also installed headers on a acura TL type S today, wow that car was easier than I thought it would be. Feels like I accomplished a lot today.:)
  44. SCIFIDELITY
    I'll try to upload a larger one. Flickr hates me. I need to find a different hosting service. It felt like doing battle just getting the tiny one uploaded. You are correct though, Rota G-Forces. I pretty happy with how they look.
  45. DTAphotography
    DTAphotography Member
    Painted, cleared and buffed the taillights. ImageUploadedByTapatalk1368067865.163088.jpg
    turkeylord and atacamaR like this.
