  1. derp
    Finally got around to dynamatting the rear hatch.
    Weird0, DIRTY D and silver03 like this.
  2. MNGman
    MNGman Well-Known Member
    Look at all that extra weight!
    I would like to do this to mine to make it a little quieter, but look at all that extra weight. :)
    Looks good. Provide an update on the change in noise levels.
  3. russellmn
    russellmn Well-Known Member
    Did some Subienuts in the fresh snow...
  4. derp
    Not that much weight, i Got the superlight stuff so it's not that heavy.
    Doesn't seem to do much on throttle, but it has definitely quieted down some reverb and buzz on idle.
  5. turkeylord
    turkeylord Well-Known Member
    Finished engine build, installed in car, fired it up, and got in 40 break-in miles. :D
    TMF, russellmn, SCIFIDELITY and 3 others like this.
  6. Ninja 4 Life
    Thanks to Jwhy, I now have an Accessport and stage 1 tune. Stage 2 to follow quite shortly. Let the madness begin!! :)
    Jwhy, turkeylord and tehfuzz like this.
  7. TMF
    Good night STi :(
    Better rest well and get ready to run in the spring :devil:
    Winter to-do list:
    -install adjustable rear lower control arms
    -remove front control arms and get new bushings pressed in
    -remove downpipe and have wideband sensor bung relocated
    -install racing seat, harnesses, and harness bar
    boone1186 and Weird0 like this.
  8. Subie Lovers
    Sno-Ballzzz!!!
    phi11 likes this.
  9. derp
    20131204_124755.jpg Winter mode engaged
    turkeylord likes this.
  10. Weird0
    Weird0 Well-Known Member
    I did some tough scrubbing and cleaned out my rims!
  11. freeze2104
    freeze2104 Well-Known Member
    Got the smy cluster and boost gauge installed
    Jwhy and tehfuzz like this.
  12. Stuart
    Stuart Well-Known Member
    tossed on a new set of AltimaxArctics and discovered that my rear pass caliper isnt firing properly.
  13. WLGT
    WLGT Well-Known Member
    Went to see if it was better to pump the brakes on ice or let abs do its thing. Pumping stopped sooner without hitting the cones most the time. Abs took twice as long to come to a stop and hit the cones all the time.
  14. JuStaWRX
    Installed my front StopTech pads, and found that the front driver's side caliper may not be doing too hot... very uneven wear, which led to the squealing from the warning tab... now the search is on for a replacement. Wish the funds were there to upgrade to a brembo set... hopefully got it all worked out though. Also thought about trying for the gauge pod but was not feeling that ambitious today.
  15. Buddy
    Buddy Well-Known Member
  16. derp
    I'm having any rust cut out and new metal welded in while i'm deployed, so fuggit.
  17. xodad2
    xodad2 Well-Known Member
    New window installed. Ready for tint tomorrow.
  18. Brayden Hebl
    Brayden Hebl Member
    Put this little baby on for a shift knob... Straight up custom
    ImageUploadedByTapatalk1386730061.007778.jpg ImageUploadedByTapatalk1386730083.706458.jpg
    tehfuzz, DIRTY D and GregRoot198521 like this.
  19. Krazylegz1485
    Changed out the idler pulley on the A/C tensioner. Damn thing was whining like crazy.
    Got home and noticed a little steam coming from the front end. Couldn't find any wet spots anywhere. Seriously hoping this damn radiator isn't leaking somewhere out of view.
  20. kickin_81
    kickin_81 Well-Known Member
    The waterpump bearing had been seizing making my FXT grind, squeal, and die at idle. Fuji_K so open heartedly forced me to work on it last night in my cold garage but he has unique tastes for heat and music. :D $400 in parts later, the car drives like a champ again.
  21. russellmn
    Chasing down an intermittent fuel leak under the intake manifold... pretty sure I've found it and will replace the soft line tonight if I can get at it. Hoping I don't have to pull the intake mani...
  22. JasonoJordan
    You know there. Is a tsb for that right.
  23. russellmn
    Got a link??? Is it a recall? Or just a TSB? And it applies to '04 STi??
  24. JasonoJordan
    Recall 02-03 wrx for sure. Get ahold of the dealer it may be for your still as well as that's the same coupler they replace on the recall on the 02-03
  25. russellmn
    My car was not part of recall... I did a temp fix to hold me for a couple weeks when I'll do t-belt, water and oil pumps, and pull intake to replace all 3 soft lines.
  26. Medic_538
    Medic_538 Well-Known Member
    Changed out rear shocks, installed r180 and dss custom axles.
    Nhibbs likes this.
  27. Nhibbs
    Nhibbs Well-Known Member
    Nice! I have the same setup. What year 6 speed did you end up with? And what clutch did you decide on?
    I now have my 07 6 speed, r180, dss rear axles, and Fx400 6 puck clutch installed and I absolutely love it.
    Been meaning to write a review of the clutch because it is that awesome but too busy.
    Hope you are happy with your setup!
  28. Medic_538
    I found an 04 with 60k on it. I have the same clutch as you. I am just waiting on the mapdccd to show up so I can wire it up and install the transmission. Good to hear you like the clutch, that was the hardest decision for me to make.
  29. Nhibbs
    Oh nice, I have the dccdpro but am thinking of selling it for a mapdccd. I should have done more research before buying it.
    The clutch chatters a bit at first but smooths out after a little bit. The pedal feel is seriously softer than stock though and I got the HD pressure plate. Clutchmasters did some magic.
  30. Jwhy
    Jwhy Well-Known Member
    Gave my Daisy a wash. It was finally warm enough to do so :D
  31. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Seconded on clutchmasters imbuing their products with witchcraft. I have an FX350 with about 15k'ish on it after frying a couple HDSS's. The difference in pedal feel is almost insulting. If it CAN be that close to stock and still function, wtf is everyone else doing, especially ACT?? That's assuming it holds up though. I seriously baby the transmission now so it will be hard for me to paint an accurate picture of how much abuse it can take.
    Nhibbs and turkeylord like this.
  32. turkeylord
    Haha, my father-in-law was laughing at me and my incredulity regarding the pedal feel of my FX300 when I drove my car for the first time. He was like. "You re-build the entire engine and THAT's what you're going on about?" :D
  33. Nhibbs
    I will not be babying my tranny so I will let you know how much abuse it can take. That was my only concern as well but it certainly can hold the torque!
    The mechanical engineer in me wants to know exactly what they do to make the pressure plate so good but I didn't really look too hard at it before the install.
    The best way I can describe the feeling of the clutch pedal is it is almost like a compound bow in archery. When you have the pedal down to the floor it takes no effort but when you release it, it springs up with a increasing force somehow.
  34. my97gt
    my97gt Member
    Replaced the starter and welded my exhaust back on today.
  35. xodad2
    Early Xmas present from the wifey. Window tint looks nice 1386963688629.jpg On a sad note, i lost the rest of my mod money replacing the alternator:censored:
  36. euro
    euro Well-Known Member
    took the front two wheels off to unpack the ice from around my wheels and struts. I think i'll be replacing the factory mudflaps with something that doesn't collect as much snow.
  37. Kneel Weiß
    Kneel Weiß FUMP BDI
    Finally washed the BRZ. My god she needed it.
    Jwhy likes this.
  38. jdhunter6
    jdhunter6 Member
  39. BaconPancakes
    BaconPancakes Member
    Brake flush, adjusted ebrake cable, washed it, went sideways
  40. Ninja 4 Life
    Installed downpipe and stage 2!
    tehfuzz and Jwhy like this.
  41. Jwhy
    Went stage 1 with Cobb sf!
    tehfuzz and Ninja 4 Life like this.
  42. BaconPancakes
    Put it on precious cargo duty.
    Taken with a potato in low light.
    SCIFIDELITY likes this.
  43. phi11
    finally installed the winter bumper/grille and light bar.
    (don't want to wreck the summer bumper and lights)
    and it looks like the carwash did the antenna delete for me, thanks!
  44. idget
    Did you at least steal the car wash?
    derp, Nhibbs and pillboy like this.
  45. russellmn
    Not mine, but I've all but finished the cage other metal work on 858 v2. Will be ready for powdercoat tomorrow...
    Deride and Nhibbs like this.
