  1. Dynapar
    I put more gas in my car. It seems like this is all I do lately. I got 29.5 MPGs which is good. I was going to was the salt off my windows with the little scrubby things at the gas station as well but they were all frozen into the containers. which sucks cause my windows are pretty bad now, I was in the middle lane passing a salt truck (in the right lane) last night and he turned on his salt sprayer and got my whole car. GGrrrr!!!!
    More importantly I need to wash my headlights.
  2. TSTRBOY2004
    mounted up the winter tires onto the rims.. will install them soon
  3. PRA4SNO
    PRA4SNO Well-Known Member
    bought 2 gallons of undiluted coolant/antifreeze, project for the weekend, pull my thermostat (its not seating right and leaks a tiny bit), drain radiator, etc. Refill.
    I'm gonna go 40%cooland, 60%water. I dont need the low temp protection out here, it only gets below freezing like 6 days a year.
  4. retreif
    snow shoes
  5. Squiggly
    Squiggly Squiggly
    put my winters on last night. pics of said gheyness will be in the thread shortly
  6. Dream
    Installed a hitch! :)
  7. TSTRBOY2004
    spark plugs, fuel filter and p/s belt.... decided against installing the snow shoes till maybe next seeing as it will be high 40's all week...
  8. gc8
    gc8 Well-Known Member
    got the snows put on...I'll post pictures later in the winter setup thread :)
  9. PRA4SNO
    Got my coolant/antifreeze flushed, and took the thermostat out, smoothed out the thermostat housing edges, and RTV'd it before putting it back in. Hopefully no leaky this time.
    I ended up only using one gallon of the antifreeze/coolant, and it ended up a 50/50 mix.
    Little did I know our coolant system was only 7.7L. The last Coolant flush I did was on my chevy's 350 where I used almost 4 gallons. I get to return the extra coolant and get my moneys back, probably spend it on injector cleaner or something.
    Need plugs and a new battery too, so I decided today.
  10. scoobypwnz201
    Timmy my man threw on an intake on my car...tomorrow i change oil and he shows me how to change/flush tranny fluid (NEEEEDDSS ITTT)
  11. 02blubru
    Shibbs installed a gmbcs and bullwinkle tuned it for me today. It is a brand new car!!
  12. Shibbs
    Called around for a few people to modify my downpipe for me so I can use it. :(
    Anyone good with welding and willing to help me?
  13. StatGSR
    StatGSR Well-Known Member
    well we (grayguy and myself) pulled the motor on the wagacy to see finally see the damage to the clutch from last years ice race.... lets just say the damage is epic and i will have pics up tomorrow night when i get it all put back together.
  14. carl
    dropping gas tank ftl
  15. TSTRBOY2004
    cough cough...
  16. TSTRBOY2004
    I need to get a couple of things done and get one of these balltinkle toons
  17. prezawagon
    prezawagon Well-Known Member
    I finished putting the new bearings in the rear knuckles for my disc conversion. Now I think I just need to find some 10mmx1 banjo bolts and washers for the rear calipers and pick up a set of rear brake pads and I'll have all the parts finally.
  18. 02blubru
    everything go okay??? did I get you all the needed hardware and such?? how did those hangers work out?
    get a gmbcs before you have him do it. It will allow for better waste gate control (is what I understand) which equals more boost :)
    I should take you for a ride, it is a completly new monster now with a good tune on it!!!
  19. TSTRBOY2004
    ^^^ well I have to figure out if I can openecu the ecu I have which is an ecutek tune.. save that files then do it.. if not then I need to send my old ecu in to be fixed first
  20. PaulasaurusREX
    Yesterday I seafoamed and replaced spark plugs which was far easier than I had thought it'd be. I didn't get nearly the Spy Hunter effect from the seafoam that I thought i'd get but there was some white clouds for sure.
  21. PRA4SNO
    no more coolant leaking out of my suby! Temp stays a little lower now too.
    On the docket: New battery and spark plugs, get a tune, clutch, pressure plate, new front rotors/hp pads, good brake fluid. All that will have to wait until after the holiday season, spending too much money on plane tickets lately.
  22. Paul Revere
    Finally installed that $9 skid plate I got :)
  23. AWDimprezaL
    wooO!!! ;)
  24. Paul Revere
    I know right!
  25. Grayguy
    Grayguy Well-Known Member
    I took the front clip off one 93' T-leg and put it on the other. Now I just need to swap over 4 doors, all the brakes, the interior, put the tranny together and install it, and put the 22t back together...i need more time...
  26. subynate
    subynate Well-Known Member
    you need less cars ;)
  27. 02blubru
    got my remote start installed
  28. Paul Revere
    ^Bill's car is sexy fyi!
  29. Grayguy
    Just because even if no one s home there's 7 cars here? Phh, I just need less cars that don't run/drive.
  30. subynate
    lol yea true that get at least 1 running
  31. PRA4SNO
    I returned my extra gallon of coolant for my $10 last night. I am really noticing a tranni shudder, and a late grab on my clutch, so getting my flywheel resurfaced and a new clutch and pressure plate are now on the top of my list.
    Woot for spending moneyz after xmas
  32. ZoisSTI
    ZoisSTI Member
    Put my Blizzaks on. Oh let it snow!:biggrin:
  33. Tim the Plumber
    Just got the car back from the paintshop where they fixed the clear coat that was chipping off :( this wednesday the snowtires go on
  34. hella_sti
    hella_sti Well-Known Member
    I did a 11 hour detail on my subaru yesterday, washed, clayed, polished, polihed some more, alky wipe, quick detailer wipe, wax, buff=arms falling off even when I used my new pc orbital buffer. I'm glad there are no more swirls though and my paint feels soft now, yum! THe day before I installed my $30 group-n tranny mount (hella of a deal) and my tic trany x-member bushings, shifting is 100X better.
  35. 9blackmax6
    looked at my dirty whore in disgust thinking that she hasnt had a bath in a month
  36. olegrad
    olegrad Well-Known Member
    cleared my headlights and "jdm" tail light conversion.
  37. Rusty
    Rusty Member
    added a little synthetic mobile 1 oil to it. it seems to use a use a little bit per few thousand miles
  38. wall of tvs
    LOL, now it will use even more.
    Mobile 1 synthetic is notorious for disappearing. ;)
  39. BlueBeauty
    BlueBeauty Active Member
    My subie took all my leafs to the recycle center. Wagons FTW! :)
  40. TSTRBOY2004
    dirty.. what is your definition of dirty.. this is mine... (pictures dont really show it.. been 2 tone for almost a week.. no use washing it..the next day I go back on dirt/mud roads anyways)
    oh and I put mah winters on... gotta put the skid pan back on though after doing the other work the other day...
  41. scoobypwnz201
    ^^^ pff thats thats pathetic..lemme take some pictures of my car sometime
    my dirtiness ownz your dirtiness
  42. TSTRBOY2004
    um this is from daily driving dirty.. not going out of my way to get dirty.. trust me.. I am sure I have pics of better then you think...
    and you say pathetic.. I have yet to see A PIC of your car... your avatar is NOT yours..
  43. scoobypwnz201
    i seriously WISH it was my car hahaha :( but you have seen a pic of my car..if you look in the newbie forums..way way back in june lol.
  44. boomer
    boomer Well-Known Member
    I'm sitting on the side of the road with a flat and a spare that doesn't clear 4 pots. A certain someone owes me a new spare that works on my car. This sucks.
  45. Gridlocked
    Bought a Holiday unlimited wash pass!
