  1. xluben
    It is a 59.5mm compressor inducer. Just like all 60-1 turbo's. :)
  2. techguymaxc
    techguymaxc Well-Known Member
    Right, I just mean I haven't seen too many people running 60-1s. Usually it's a smaller 20G or a bigger Blouch/PTE/FP/Garrett.
  3. Aluminati
    Aluminati Vendor
    It sounds cooler with 60mm ;) lol
  4. xluben
    I agree. Just round up. It's only 0.5mm. :)
  5. ryjacobs
    ryjacobs Well-Known Member
    Advans are on.
    Weird0, TMF and tangledupinblu like this.
  6. TMF
    Like! But almost makes me sad...I miss those wheels.
    ryjacobs likes this.
  7. Krazylegz1485
    Feel like I've got a pic of that license plate in my collection...
  8. ryjacobs
    Mine?
    Krazylegz1485 likes this.
  9. Krazylegz1485
    Yes. I've been making a collection of auto-related custom plates. I'm almost positive I've seen that one somewhere.
  10. burtonboy00
    burtonboy00 Well-Known Member
    Put on my summers and went mudding
    clajiness and EricS like this.
  11. phi11
    Replaced both front axles on the '07 OB.
    One was seized in the hub, but with luck, a 20 ton press, and a Subielovers, we got that old axle out w/ no problems.
    tangledupinblu and EricS like this.
  12. Jake underwood
    Jake underwood Member
    Installed my prosport evo boost gauge and my solid solutions vent pod. Now it's time to get the SMY hood, wideband and oil pressure gauge.
    Aluminati likes this.
  13. Aluminati
    Aluminati Vendor
    I went fast and it was fun!
  14. MNGman
    MNGman Well-Known Member
    Installed Redline shift boot, E-brake boot in perforated leather, and arm rest cover in smooth leather. Kind of a pain, but not too bad.
    On a side note; Got Tires?
    joebush44, Weird0, TMF and 3 others like this.
  15. Krazylegz1485
    What are the baby Hoosiers for?
  16. MNGman
    My housemate has an FMOD for autocross. Think like a small indy looking car with a 500cc snowmobile engine.
    It is an absolute riot to drive!
    Ryan FailRad and clajiness like this.
  17. jrocket74
    jrocket74 Active Member
    Got my Perrin brass shifter bushing in, and my Rally Armor flaps on..
  18. '05_STi
    '05_STi Active Member
    Installed my custom painted tail lights on my 14 WRX. Smoked red with smoked clear. (painted by Brian -"nexson" on iwsti) Can't say enough about the quality of his work!
    Cotts612 and Aluminati like this.
  19. matt03
    matt03 Member
  20. euro
    euro Well-Known Member
    ordered some aero clips so I can mount my Yakima bike rails.
  21. techguymaxc
    New FPR and DW300c fuel pump + Nuke tune @ 24 PSI. Should be at least 400WHP now based on how it feels compared to before when it dyno'd at 350.
  22. burtonboy00
    I tested the AWD to see if it was still working, and it is. 1" Lift is probably the best thing I've ever done to this car.
  23. TMF
    Are you still on the 1000 cc injectors? Happen to know what your duty cycles were?
  24. techguymaxc
    Still on the 1000s, IDCs are 96-98 according to Nuke.
  25. tonyv
    tonyv Well-Known Member
    Stock Turbo?
  26. techguymaxc
    Not with 400WHP. I have a PTE 55mm stock location turbo.
  27. tonyv
    How's the lagg on that turbo? I haven't seen much about it on forums
  28. techguymaxc
    Not bad, full boost by 4000, peak torque at around 3700. Holds power to 7000. It's a ton of fun on the street.
  29. tonyv
    Thanks for replies. Didn't realize you posted your mods on previous page. lol. That killer B header probably helped a lot too with the spool.
  30. briancustoms
    Thursday night I de-resonated and modified a free WRX midpipe to fit my '12 base model Impreza 2.0i 5-door. My MagnaFlow muffler section wasn't quite loud enough. Adding the midpipe made it a bit louder than I wanted, but I'm dealing.
  31. pbedroske
    pbedroske Well-Known Member
    For about a week I've had stumbling during acceleration while on boost at about 4k rpm and occasionally flashing CEL but I was unable to read any codes. So with my limited time, on Saturday, Seafoam treated cleaned MAF, Monday, changed oil and fuel filter. No dice. Last night (Tuesday) I cleaned battery terminals, checked drivers side ignition coils and plugs, then checked and cleaned the crank position sensor. So far today success! No more flashing CEL when on boost. coil nearest battery seemed a little loose, crank position sensor wasn't too dirty. IDK. according to my torque app I got 32 MPG on the way in to work, usually 28.5 at best.
  32. euro
    oil change, air filter, continued trying to make all of yakima's $@#@$ fit together properly...
    ps. the aero bars are crap.
    Ryan FailRad likes this.
  33. TMF
    Just out of curiosity...why?
  34. euro
    out of 4 accessories I've owned for yakima racks (with the aero clips for mounting) only 1 of them actually fit properly without modification. the bike rails needed to be modified to clear the wide bar, my old yakima basket had to be modified to clear the wide bars, my original bike rack would have never worked. The only thing that was direct bolt-0n was my snowboard clamps.
    example bike rail
    mine I ended up using a lock pliers and bending the lip in the front up so the clips would clear.
  35. Krazylegz1485
    2x4's and wood screws FTW...
    euro likes this.
  36. supremekizzle
    supremekizzle Member
    Put on the stock STI axle back exhaust I bought from @763WRX... sounds awesome. Just a little more grunt than stock, but not obnoxious.
    763WRX likes this.
  37. derp
    Got the Jazzy aux-in mod done last night at Sheen's. Also installed a prosport halo boost gauge with Sheen's help the other day.
  38. Krazylegz1485
    Wife and I did a thorough clean of the garage and house in preparation for mega sale next weekend. Found my keyless entry remote after having misplaced it back in November when the motor died. Having said that,
    I locked the doors for the first time in 6 months!
  39. Sjogun
    Sjogun Active Member
    EricS and Aluminati like this.
  40. leelt
    leelt Member
    Just got done installing the 08-11 wrx/Sti blacked out headlight housing on my 14 wrx and setup my hid low beams and my led drl/high beams and my led turn signals and so far I'm loving it a lot now just waiting on my jdm foglights
  41. JuStaWRX
    Needed a quick project, so I started putting in the Diode Dynamics LEDs in the FXT. I got the dome light done in about 1 minute, but the map lights were a PITA. I am sure that there has to be an easier way to do that, but what was my saving grace were some long twisty ties that I used to help get them in the right way. This weekend I hope to get the little panel light in the cargo area.
  42. clee
    clee Member
    Protune yesterday just a simple stage 2
  43. tangledupinblu
    Ronnie FTW!
  44. Aluminati
    Aluminati Vendor
    De badged my trunk lid and added a neat sticker. Then for a short period of time, my friend re badged my trunk lid.
    EricS, burtonboy00, joebush44 and 3 others like this.
  45. joebush44
    joebush44 Well-Known Member
    Limited rear spoiler...15hp gain easily
    JuStaWRX likes this.
