  1. tangledupinblu
    Ooontz ooontz ooontz!!
    Krazylegz1485 likes this.
  2. Krazylegz1485
    Calm down, it's only 150 watts... Haha.
  3. silver03
    2000 legacy (2.5) alt ps belt too loose. Tensioner as far up as it could go. Horizontal tightening bolt rubbing on belt. What the heck? Turns out the belt off the 99 legacy is a half inch shorter than the 00 and thus using that belt solved the issue. Early 00 build using 99 leftovers?
  4. Jason C
    Jason C Well-Known Member
    Awesome! I want to lift my WRX an inch or so to give it a tad more clearance.
  5. Mi_Ke_nnedy
    Mi_Ke_nnedy Active Member
    Do it!! Monster-Truck-RX? IMHO, WRX just looks so good a bit taller.
    I went a tad higher than stock by using the "stock-height" springs from King. Bit of a misnomer - they seem to be wound to stock dimensions, but are firmer than stock so simply don't compress as far when the weight of the car is on them. Never measured height before installation, but seems to be 3/4" higher or so.
  6. JasonoJordan
    The coil steel diameter is just massive on these king springs. Also handles the weight out off the tongue on my obxt much better then the lowering springs I had. I have a hammock mount I built that comes off the hitch receiver. With my old springs I would compress the rear suspension down to the bump stops if I didn't use a jack under the hitch to help hold the weight. These new springs barely sag 1/2" with that same setup.
  7. klutz
    klutz Well-Known Member
    the wife and i enjoyed a weekend up in Lutsen, but had to drive through some terrible blowing blizzard conditions. The kind where you go 30 in a 65 and can't see the taillights 45 feet in front of you? That kind. Well the WRX handled it great and I never once felt out of control. Felt bad once we got to some clearer conditions and 4 lane roads as I zipped by the nervous nellies.
    AWD for the win!
    silver03, Cotts612 and tangledupinblu like this.
  8. tangledupinblu
    I learned that downshifting with the wrong tires in slick conditions makes you dori dori when you don’t necessarily want to dori dori.
    Kneel Weiß likes this.
  9. tangledupinblu
    I heard Lutsen got 13 inches of fresh pow pow today!
    TMF likes this.
  10. Cotts612
    Cotts612 Well-Known Member
    Rev match yo!
  11. tangledupinblu
    No matter what i did she was all over the place! Scariest drive that i have ever taken in my life hands down.
    Cotts612 and Kneel Weiß like this.
  12. subie-roo
    subie-roo Well-Known Member
    Oh how I miss RWD ;)
    Cotts612 and Krazylegz1485 like this.
  13. tangledupinblu
    It’s funny because once I owned an awd Subaru, i said never will i own a non-awd car again. Yet, here i am.
    klutz, Chux and Kneel Weiß like this.
  14. Lazieboy
    Lazieboy Member
    Also ordered Front sway bar end links, front sway bar bushings and lower ball joints. I need an alignment so I figure I'll replace those first, then alignment.
    Also might get rid of the front noise.
  15. JasonoJordan
    I have some snow tires and wheels I will sell you ;)
  16. tangledupinblu
    :p I have some sucka! It’s just going to take alot of work to get them swapped around. But thanks(again):confused: for the heads up!
  17. JasonoJordan
    Lol why it gunna take alot of work?
  18. TMF
    Just store it over the winter man...
  19. TMF
    I had a surpringly very productive weekend of working on cars...I wasn't planning on doing any car work, but the weather was somewhat warm, and the garage floor was dry.
    Finished the 90k maintenance on the wife's Outback (PSA: Motive Power Bleeders are awesome):
    And finally installed the hitch on my Outback (the hitch arrived before the car did and has been sitting in the box for months):
    Next, I need to get over to my storage garage to replace the 2 broken rear wheel studs on the FRS that I failed to replace prior to storage :confused:
    JuStaWRX likes this.
  20. klutz
    How was the hitch install? We want to get one for the wife's 2011 Outback so curious as to the install review!
  21. TMF
    Very easy, although I do recommend a second set of hands for when you need to bolt up the hitch. I recruited my wife lol. This is the second hitch that I've installed, and I've been kicking myself for not putting hitches on every other DD I've owned.
    I highly recommend etrailer.com - they have very detailed install videos for nearly every car, and their prices are great too. I've always had excellent experiences with them.
    Here you go:
    https://www.etrailer.com/Trailer-Hitch/Subaru/Outback+Wagon/2011/75673.html?vehicleid=2011301542
    FYI, using a hole saw first to drill the hole (1" instead of 1 1/8") and then cleaning it up with a step bit is much easier than drilling the entire hole with a step bit. I have both bits if you want to borrow them for install - let me know.
  22. JasonoJordan
    Just out of curiosity why did you go with a class III receiver? Did they up the tongue weight rating for later years? For instance on my 2005 outback the tongue weight rating that the sub-frame can support regardless of class of hitch is 200lbs.
  23. TMF
    Several reasons...the price was nearly the same as the class II 1 1/4" hitch, higher tongue weight rating (600 lbs...I should probably look at the car's limitations though), higher towing rating, more universal for accessories (the Harbor Freight cargo carrier is 2"), etc. I figured I might as well have "more" for essentially the same price.
  24. JasonoJordan
    Well if price was nearly the same and they don't make a class II 2" receiver for your car then yea I would of done the same. I will be changing mine on my wagon from 1 1/4" to 2" in the near future.
  25. MNcrew952
    MNcrew952 Member
    I drew it! Its been a rather slow day at work.
    klutz likes this.
  26. MidnightImpreza
    Went for a little drive to Menards tonight. Took the long way. 20180224_202600.jpg
    jubella2, MrBlue, subie-roo and 3 others like this.
  27. skubi1
    skubi1 Well-Known Member
    Wife drove my car. Hers is stuck at the bottom of the driveway (crap tires.)
  28. silver03
    Took my car to Kohls, Sears, Old Navy, Costco, JCPenney, Pier 1, Home Depot, Lowes, dollar store,, festival and target tonight. Funny thing was I never did stop to go in any of those stores. Oh yeah, Dick’s Sporting Goods as well. It was a parking lot tour of the funnest magnitude.
  29. JasonoJordan
    Wife says you guys got a pretty good dump up there so far in Coon Rapids
  30. silver03
    Our driveway has 6 inches as of about a half an hour ago.
    JasonoJordan likes this.
  31. MrBlue
    MrBlue Well-Known Member
    Swapped the winters to the temp daily while the wagon gets some upgrades 20180224_120913_resized.jpg
    Krazylegz1485 and silver03 like this.
  32. Chux
    After listening to metal-on-metal for a few days, I finally did the brake job on my XT6. My old boss/current AutoZone rep convinced me to give the new Duralast GT pads a try. Did that and the premium coated Duralast Gold rotors.
    Up on my sweet Harbor Freight long-frame jack:
    20180228_171531
    by Numbchux, on Flickr
    And new stuff installed:
    20180228_174752
    Full setup, SVX 1 1/16" bore master cylinder, 2002 2.5RS front calipers/pads/rotors, stock XT6 rear rotors, 1988 Nissan 200SX rear Calipers (rear ebrake conversion), Centric braided stainless lines all around.
    Did a bed-in last night, and this morning, I was impressed. Best brakes on a Subaru I've ever owned. Spring will have to tell how they stack up against my Celica (although I have a brake upgrade on the shelf for it, too....).
  33. tangledupinblu
    New school BRZ, meet old school RS!
    1EA109B1-3DB2-4619-9845-250D35333BA3.jpeg FB82EB0C-37DA-4DBA-B47E-3D4A4A289AB2.jpeg
    pcwerk, jubella2, joebush44 and 5 others like this.
  34. JuStaWRX
  35. tangledupinblu
    Thanks J!
  36. skubi1
    Perfect winters for that car!
  37. tangledupinblu
    Agreed! They almost look too good! Makes me want to run them in the summer. Hahaha
  38. JuStaWRX
    Took advantage of the nice day and did a hand wash.
    EDIT: It's raining now. Like clock work.
    subie-roo and tangledupinblu like this.
  39. Lazieboy
    Lazieboy Member
    Replaced front endlinks and sway bar bushings.
    Feels way better wish I got the parts for the rear.
    Old bushings were 20mm and new ones 21mm ride feels good and noise gone.
  40. tangledupinblu
    Man those bushings were toast!!:eek:
  41. JasonoJordan
    Removed rear swaybar from the wagon. Installed trickle charger in the brz engine compartment. Changed oil on wagon. Changed cabin air filter on the wagon.
  42. TMF
    How many miles did you have on the original? I might need to do this on my wife's Outback.
  43. pleiades
    pleiades Well-Known Member
    Where did you route the power supply cable? I've thought about installing one of these in my bugeye since it hibernates in my garage all winter but have yet to sort out a clean way to do it.
  44. JasonoJordan
    Wires have not been routed yet but will get tied back with the other wires running through that same area. Its really only the positive and negative lead the other one is just a standard plugin for an outlet so easy to just flip the wire up and connect it for the winter.
    Reason I went with this is because it then frees up my battery charger for other tasks as well as my current battery chargers fan is super loud and annoying tone so trying to work in the garage with it running was a major source of annoyance for me.
  45. subie-roo
    Finally got this sweet bug deflector on yesterday. Today a much needed oil change and differential fluid too. Driving through the buckets of snow tonight remind me why I love my little Outback so much.
