  1. Lazieboy
    Lazieboy Member
    131k. It's worth it.
    TMF likes this.
  2. Lazieboy
    Lazieboy Member
    Just bought it and drove it home. 170 some miles one way. Was in Plymouth,mn
    110k mi. On it now.
    silver03 and tangledupinblu like this.
  3. unhguy78
    unhguy78 Well-Known Member
    My relay on my Hellas failed in my garage yesterday; almost went deaf pulling the fuse. Took the Jeep through the storm to AutoZone for a new relay; now only one of the horns work :( another spring project I guess...
  4. jubella2
    jubella2 GC8 FTW
    You're running some major camber on that bad boy!
  5. JasonoJordan
    Yea I cant remember what I had Jeff set it at but it was substantial.
  6. tangledupinblu
    Plowed through 6 inches of snow this morning in Maplewood in the BRZ. Streets were unplowed as well but it did great with the General snow tires!
    Not a winter car...pfffft. If it wasn’t, why would it have heated mirrors and seats!?:)
  7. jubella2
    jubella2 GC8 FTW
    I remember Jeff referenced your specs when he set mine up but he must have ignored them to keep me at a more daily driver value.
    The only issues I've had is dragging the floor in deep snow and not being able to clear the ice chunks that fall off the rockers of the car in front of me. The 16s look good on there with meaty tires.
  8. tangledupinblu
    The bottom of the series.blue looks like a matchbox car! It has plastic skid plates that cover nearly the entire bottom to decrease drag. With a little momentum through the deep stuff, it’s almost like a sled! Hahaha
  9. klutz
    klutz Well-Known Member
    How hard of a project is that? Any special tools needed? Asking for a friend who's obviously not as handy as me :)
  10. Lazieboy
    Lazieboy Member
    Not bad. Although my neck and hip were sore afterwards. Floor jack, 12-15mm wrenches and sockets. Allen wrench to stick in the old one to get off and one of mine striped out,but vise grips saved me from sawing it off. Clean threads and wd40 couple times.
  11. tangledupinblu
    Vinyls are officially off-(after 8 hours of patience, a heat gun, and fingers bleeding) Now she needs a bath! Who needs a 2.5YBRID WRX!?
    3A43793F-6CAC-4D6A-A04D-A4EEAC394502.jpeg BF2754E3-97DA-4CE1-863E-A793B63BDC4C.jpeg BEE02595-5316-4964-8582-70B8A2504EDD.jpeg
    silver03, MrBlue, ocie and 4 others like this.
  12. Lazieboy
    Lazieboy Member
    Tonight I transfered 300watt kicker amp and 12in Rockford amp into the Legacy.
  13. Lazieboy
    Lazieboy Member
    Rockford sub (correction).
  14. Lazieboy
    Lazieboy Member
    Bumper had road rash on it when I got it, I made it look a little bit better. Heated it up bent it into place and screwed it. I think I am gonna get some of the paint match vinyl wrap material from colorxlabs.com to make front bumper and few other spots look better.
    idget and jubella2 like this.
  15. unhguy78
    Did you have to take the bumper off? Someone hit me while I was parked and I'd like to try and try to salvage the shape to wrap the bumper as well. Advice appreciated!
  16. TMF
    Use hot water and/or a heat gun and you should be able to push out the dent (there are tons of videos on youtube). You might be able to remove some of the scratches with rubbing compound as well.
  17. JasonoJordan
    I am with Jordan on this. That looks like a pretty easy dent to pop out and buff out most of the paint transfer/scratches.
  18. unhguy78
    I tried prying the dent out, sounds like heat is the key missing element to my method?
  19. JasonoJordan
    Gentle even heat is key.
    unhguy78 likes this.
  20. JuStaWRX
    Took off the snow wheels/tires (I like the look of them much more than my "summer" all seasons on the OEM...), oil change, and rear brake pads (OEM --> StopTech).
  21. Lazieboy
    Lazieboy Member
    I just used a small bottle torch from work. Got a little too close too quick and burnt some paint,but alwready had road rash in the spot.
    What I found is get your hand on the back of the area so you can feel the heat (temp) and slowly push it out and hold it untill it cools.
    unhguy78 and silver03 like this.
  22. silver03
    Anyone here replace the radiator fans in a white bugeye tonight? I felt a moving of the Force.
  23. Lazieboy
    Lazieboy Member
    No. I did find this the other day. Scared to pull it out. Tugged on it a little and it's in there.!
  24. tangledupinblu
    Yup! Cody came over and we got the fan out without much issue. But non-turbo car fans and turbo car fans are not created equally. Despite that, a quick rewiring and she’s as good as new! :thumbup:
    silver03 and Krazylegz1485 like this.
  25. GrawvyRobber
    GrawvyRobber Active Member
    Just got my AP in the mail yesterday and flashed to stage 2 91 today!
    Loving the feel of 1st and 2nd now.
  26. silver03
    Wait til you get to third!
  27. GrawvyRobber
    Still not brave enough for 3rd!
    Usually stay in 2nd while on the highway.
    ocie, silver03 and tangledupinblu like this.
  28. silver03
    Not my subaru, but our Escalade ESV blew out a brake line. Thankfully, Kim was able to pull over quickly and safely. Get under the truck and find it is the top inside line running from the ABS junction box located just in front of the left rear wheel that follows the frame forward crossing the truck under the radiator to the front right right wheel. That was hard enough running that new line, but got it. So go to bleed brakes, and the bleeder screws snapped off on three of the four calipers (both fronts and LR)....aaargh!!! In the end I got a bonus complete brake fluid flush I guess.
  29. JasonoJordan
    Were you able to get the old bleeders to let go and replace them?
  30. silver03
    Ended up buying three new calipers.
  31. tangledupinblu
    I swear that you “secretly enjoy” when things happen on the cars or maintenance stuff is due. :D
    jubella2 and Krazylegz1485 like this.
  32. silver03
    When it's planned, I do like it. Not the surprise stuff, which seems to happen more with older vehicles.
  33. tangledupinblu
    But “secretly”. It’s ok that you don’t want to share outside of your safe space.;)
  34. Chux
    We're taking our '04 OBK VDC to South Carolina in about a week, so I've been giving it a careful once over.
    New pads in the rear. It had a stuck caliper pin at each of the 4 corners (whoever was in there last did not use brake lube, probably just anti-seize or generic grease, it was baked completely dry). Pushed the fluid out of the calipers, and got some fresh fluid in the system. Dug a set of classic Impreza split-fives out of storage, and had some new H rated General Altimax RT43s (the higher speed rated ones have a lower treadwear warranty, but are actually rated higher in virtually every category, including wear, on tire rack) put on them. Subaru tire program has free 2 year road hazard coverage, too.
  35. Lazieboy
    Lazieboy Member
    I installed some side mirrors with blinkers off of my twins turbo. Re pined the wires in connector then just needed to splice wires into blinkers. I was hoping it was gonna be plug and play but no. Also installed some red LED's under the seats and in trunk. Then cleaned out the throttle body and air intake to fix the low idle when at a stop.
    powdered toast man and Jason C like this.
  36. Jason C
    Jason C Well-Known Member
    Cool. I installed the STI side blinkers on my 2017 WRX. Fortunately, mine is the Limited that has the factory wiring already in the door so it was pretty much a plug-n-play affair.
  37. tangledupinblu
    Loaned it to @pleiades . Hahaha! She’s a “parts runner” today!
    MrBlue and pleiades like this.
  38. pleiades
    pleiades Well-Known Member
    And she ran like a champ! Thanks again!
  39. MidnightImpreza
    jubella2 and tangledupinblu like this.
  40. JasonoJordan
    How you feeling about your decision this morning?
    TMF likes this.
  41. MidnightImpreza
    I run all season tires. No worries!
    JuStaWRX and TMF like this.
  42. tangledupinblu
    I was going to say something to him, but ya know. Lol
    MidnightImpreza likes this.
  43. Chux
    Lessens learned this weekend
    Found out the low fuel light in the XT6 seems to have failed.....the hard way :(
    Found out that with some work with a mini-maul will make it possible to stow an inflated 215/65r16 tire in the spare well in the back on our 04 Outback
    Found out that a mini-maul will tear the metal in the spare tire well
    Found out that brand-new General RT43s don't suck in the snow.
  44. MN_XV_712
    MN_XV_712 Well-Known Member
    Brought one of these this weekend, LAX can't come soon enough now!
    klutz, jubella2, JuStaWRX and 3 others like this.
  45. JuStaWRX
    My envy is so real. I love the idea of these! Curious to hear how you like it after a few uses! I didn't go that extreme, but got myself a little roof gear as well last night.
    klutz, MN_XV_712, jubella2 and 2 others like this.
