  1. Bugeyejake
    Bugeyejake Member
    Where are you located? I’m out by green lake and luckily had a buddy do it real cheap. My fix is more so just to keep moisture out for now and buy some time.. I’m sure it’s stronger than it was with the crumbles in it but I’ll likely have to either put in entirely new towers or just swap everything to a rust free shell someday..
  2. briancustoms
    Repurposed a set of Outback/Legacy 18s.
  3. Krazylegz1485
    It's crazy how good those look with considerably less sidewall around them. Dang!
  4. briancustoms
    Ever since I first cleaned the set on my wife's '16 Outback, I thought they looked great and wanted to try fitting them on my Impreza. I finally got up the nerve and cash to hunt down a set and try it. I think they were worth it.
  5. tangledupinblu
    Agreed!
    Krazylegz1485 and briancustoms like this.
  6. jubella2
    jubella2 GC8 FTW
    Anyone changing tires this weekend?
  7. tangledupinblu
    Nope. But it’s pretty much time.
  8. Chux
    Went to pull the winter beater ('00 OBK) into the garage for some work a couple days ago, and it wouldn't start. P0336. So, after a considerable fight (outside, in the dark and rain) to get the old crank sensor out, I got a new one in and it started right up.
    silver03 and tangledupinblu like this.
  9. Chux
    Bugeyejake and tangledupinblu like this.
  10. Rally Steve
    Rally Steve Member
    75226389_10156315176866010_7533422905481232384_n.jpg We ran the Lake Superior Rally and finished 3rd on class and 5th Overall in the Regional event. Not bad for a new car, co-driver couldn't talk and driver that was very rusty. Also met some MN Subaru guys in Michigan!
    Chin, Bugeyejake, Cotts612 and 4 others like this.
  11. JaloP
    JaloP Well-Known Member
    Wrapped up the threads on my trailing arms in preparation for the winter. Gotta make sure they don't rust solid by mid December.
  12. Bugeyejake
    Bugeyejake Member
    Runnin errands today in my wagon, everything going great until i get back in the car from grabbing water (was my very last errand lol) and the temp gauge is climbing.. and climbing.. so i drove home in 1 mile-ish stints in effort to not overheat
    Hadn’t had this happen yet, was worried about possibilities.. so did some quick research, checked my coolant hoses and the lower one was dead cold, which was indicative of a stuck thermostat. Swapped that out with a new one and she’s right as rain! Love that it was a quick fix, one of the easiest I’ve done. Lol thank you Subaru!
  13. Krazylegz1485
    Good on ya for fixing it yourself.
    "Nicely done, Joey!"
    Bugeyejake likes this.
  14. silver03
    The ultimate WRX performance mod… Replaced the turn signal stalk!
  15. Subystar
    Subystar Active Member
    First wash and Ceramic coating (Cquartz UK 3.0)
  16. Subystar
  17. MidnightImpreza
    Put on winter set up this evening. After a slippery drive to work in Lakeville.
    Krazylegz1485 likes this.
  18. tangledupinblu
    I finally swapped mine last night with the threat of the “1/2 inch on the ground” that they forecasted for today.
    MidnightImpreza likes this.
  19. pleiades
    pleiades Well-Known Member
    I really like how those look on the BRZ. They just seem to suit the car even though they're what, a couple decades old now? I'm sure the traditional WRB over gold wheels color scheme helps that but still, one of my favorite OE Subie wheels.
  20. tangledupinblu
    Mine too, thanks
  21. Chux
    Started driving the winter beater ('00 OBK 5MT) over the weekend. Blower motor would only spin after smacking it (I had a snow brush that was just the right length to reach it from the driver's seat), and even then only just barely.
    Finally swapped the blower from the parts car. I would like to find the engineer that didn't leave enough room to get the blower out past the wiring harness and pull his fingernails off. I lost my temper and started breaking stuff on the parts car to get it out, but had to do some serious fiddling to get it in the driver.
  22. tangledupinblu
    And you’re a patient guy! Must have been a true PITA
  23. Chux
    Usually....yes. It just didn't make any sense. All the mounting hardware for the blower itself was very easily accessible, but the wiring was just in the way, and the retainers for the harness were not accessible. The harness was considerably more pliable on the car that had been driven recently, so that helped. If either component were moved 1/2", it would have been a 1 minute job, or if the harness was a couple inches longer...
  24. tangledupinblu
    Well you can chalk it up as a victory anyways! I’ve wondered many times who designs this stuff. Obviously no one that actually rolls up their sleeves and does the work on them!
  25. Krazylegz1485
    Yep...
    Chux likes this.
  26. Chux
    I've had this AuxBeam 22" Flood/Spot light bar hanging in my garage for several years (I bought it for the '04, but I did LED low beams, and didn't feel the need for the bar). So I mounted it up the other day.
    20191114_180426
    by Numbchux, on Flickr
    Just cut, drilled, and bent some 1/8" steel to make some brackets that tie into the radiator mounts
    20191114_180449
    It's not as strong as I'd like, so it wobbles a bit on rough road. But the road where I use it every day isn't too bad, so good enough.
    It's just wired to the stock Fog Light circuit, next project is to rewire it to the Hi beam circuit so I can flick it off quick when another car comes.
  27. GrawvyRobber
    GrawvyRobber Active Member
    Replaced my front endlinks. Really want to put in some new LCA and other bits after seeing a new piece next to all the rust....
    Also put on my winters that I got for freeeee.
    Realized after test driving that I had the bolt and nut on the wrong side. Had to flip it around because it was rubbing on tight corners.
  28. Chux
    You've got your links flipped upside-down. They should ride above the control arm (that'll fix your rubbing issue, too).
    Krazylegz1485 and GrawvyRobber like this.
  29. GrawvyRobber
    :censored:
    Chux and Krazylegz1485 like this.
  30. Chux
    I pulled a broken grill off my parts car and attacked it with a sawzall to clean up the install.
    2019-11-18_02-42-25
  31. tangledupinblu
    Looks nice!
  32. silver03
  33. Chux
    Tried to take some yesterday, but my camera just adjusted for the extra light, so it just made my driveway look more yellow...
    It's plenty of light, but I wish I had bought 2 smaller bars/pods so I could aim them off to the sides. Even with the Amber covers over the spot lenses, and the flood lenses left alone, I wish I had more light in the ditches.
  34. tangledupinblu
    Don’t we all!?
    silver03 and Chux like this.
  35. Cotts612
    Cotts612 Well-Known Member
    Put my winter tires on today. Good timing, they're forecasting 6-7 inches Tuesday night!
  36. tangledupinblu
    Bring it on!!
    Cotts612 likes this.
  37. RichZilla
    RichZilla Well-Known Member
    I've got a set of factory STi BBS Wheels and Hakka tires for sale for anyone not prepared!!! Listed in the parts for sale area...
  38. JaloP
    Left it in the garage... I measured 24" while clearing the driveway, I don't think it'll get through that...
  39. Cotts612
    My car did a thing! Now I gotta think about replacing the timing belt, water pump ect. In a few months.
  40. tangledupinblu
    Welcome to the “cracked 200k club”!
  41. pleiades
    Replaced the rear wheel bearings on my wife's Legacy this weekend. The left side has been howling for who knows how long, thankfully I happened to take it for a short drive last week and noticed it. Just over 100k on it and that's the first major thing I've had to do in 4 1/2 years, so I guess I can't complain too much. Didn't look horrible when I took it out but definitely in need of replacement. Screenshot_20200112-190545_Gallery.jpg Screenshot_20200112-190607_Gallery.jpg
  42. GrawvyRobber
    Finally finished my HID retrofit on my bugeye. Wish I could say it went smoothly and without error.
    I ordered everything from TheRetrofitSource about a year back. I initially was blowing fuse after fuse. After some testing I was able to pinpoint that one of the XB35 ballasts I purchased was defective. TRS customer service was fantastic and sent me a new one in a week.
    The headlight assembly was new from Ebay.
    This was a huge learning experience for me and I am very excited to do another set, and to do it on my Frontier as well.
    Holy **** what a difference at night!
    silver03 likes this.
  43. tangledupinblu
    Looks great! Nice work
    GrawvyRobber likes this.
  44. Krazylegz1485
    This has been on my list of "I wish I could do this" now for like 10-15 years...
  45. GrawvyRobber
    JUST DO IT!
    This is my favorite mod to date. It's a lot easier than one would think. I will totally help if you ever want to give it a swing. I was very nervous to bake the lenses on /offd and Dremel work on the reflector bowl. TRS has a harness that is basically plug and play.
    Idk why I wanted to torture myself by doing this in the winter, in my detached, uninsulated garage....
