  1. 55_MPH
    55_MPH Active Member
    I put in summer tires today…
  2. tangledupinblu
    Lol
    MidnightImpreza likes this.
  3. MidnightImpreza
    How's it feel to be right for once?! ;)
    About a inch plus in Mounds View so far.
  4. tangledupinblu
    :D<-feeling pretty smug right now. Thanks for asking!
  5. silver03
    04 Taillights in and working! Glad I did this Saturday. Never mind the upside down...
  6. tangledupinblu
    What “upside down” are you referring to?:p
  7. silver03
    Never mind the upside down. When I had initially loaded the image it showed up, well, upside down!
  8. tangledupinblu
    Well I upside righted you’re upside down.
    joebush44, Krazylegz1485 and silver03 like this.
  9. MinnesotaFTW
    I got a little something for myself. I also ordered a fuel pump hardwire kit along with the DCCDPro FuelPro. Now I'm just waiting for IPT to respond to my email so I can order my high stall :shifty:
  10. pillboy
    Looking at the background and the time of posting...are you in bed with your car parts?????
  11. silver03
    Put on the summers after cleaning them and the snows for storage. Silverado is close to Subaru, right? I mean both begin with S and in a vowel. Changed the oil/rotated tires on that truck yesterday. 265/65R18...my God are they heavy!
  12. loxx0050
    loxx0050 Well-Known Member
    This past Friday finally swapped out the winter tire set to the warm weather set with brand new rubber. Bought new Michelin Premier LTX from Costco for the Outback as they were on sale with practically free installation/tire disposal too. The stock Conti's that came with the car was down to the wear bars last fall (despite having something like 35k miles on them).
    Also had to replace a seized wheel stud on the driver's front. Impact wrench got it off eventually but took a bunch of threads with it. Had to buy a replacement stud and while I was at it bought a bunch of spares so I didn't have to run to the dealer without a functioning car (luckily my wife's car was available for me to use). For now I PB Blasted every stud and lug I've got then wiped them down. Will put anti-seize on later this summer (planning on replacing the pads/rotors sometime this summer).
    Last thing I did was try to adjust my headlights as they aren't aim correctly after replacing the bulbs last fall. This is the 3rd time of adjusting them and we'll see if I did it right (hard to tell since I can't get my car exactly level on jack stands and don't have the distance in my garage to 100% tell if it's right). I really want to punch the engineers' who approved the Outback design where you have to replace the bulbs by opening up the wheel wells.
    JGX_SG9 likes this.
  13. JGX_SG9
    JGX_SG9 Member
    Decided to do a full detail since we're finally coming out of the nasty winter months.
    I spent a ton of time pressure washing the underbody area, and got all kinds of gunk out from the wheel wells and engine bay. Gave it a quick wash, medium clay with water, prep wipe down with 50/50 70% IPA and water, fine clay with a clay lube, and a final quick wipe with the alcohol again. I wanted to be sure I got a perfectly prepped surface after applying a few layers of wax over the winter to protect it from the ridiculous amount of salt that's used around here!
    I'm a painter, not a typical detailer, so everything I use is body shop safe. That means it doesn't add any useless fillers to the surface. I just focus on pure correction and then protection over the work. I used a compounding pad on a DA polisher with 3M Perfect It machine Polish, polishing pad with the same polish next, and finished with a fine pad with Perfect It Ultrafine Machine Polish.
    I used Menzerna/Jescar Power Lock sealant, and Collinite 845 wax over that. It's a tried and true combo. Some doubt whether the 845 is really necessary, but I think it works great so I stick with it. Tire dressing is Chemical Guys Silk Shine. It's not specifically a tire product, but it's the only water based stuff I've found that doesn't leave a cheesy gloss shine, and works well for reapplication over itself without getting nasty.
    Then of course I had to go grab a few pics!
    ryjacobs, klutz, Chin and 6 others like this.
  14. MinnesotaFTW
    I just took the picture on my bed. All of my new parts are scattered around the room.
  15. euro
    euro Well-Known Member
    Adpater plate and flywheel for the ej22 arrived a few days ago. Test fitting for the engine support bar can now happen.
  16. MidnightImpreza
    20200420_203010.jpg Two flat tires on the way home from work. There was a road work sign blown down laying in the road around a blind corner. Didn't ruin the rims though.
  17. tangledupinblu
    That sucks!
  18. pillboy
    That sucks!
  19. TC Lgt
    TC Lgt Well-Known Member
    That sucks!
    pillboy likes this.
  20. skubi1
    skubi1 Well-Known Member
    AP came in the mail today, so I'm Stage 1 now! Hopefully that gets rid of my codes for my STi catback.
  21. OneGlanceMan
    OneGlanceMan Member
    Replaced my front Wheel Bearings, CV Axles, and took off my stock Turbo Inlet to install a better one.
    silver03 likes this.
  22. silver03
    Holy Hannah! boredom or necessity? I admire your ambition.
  23. pillboy
    Same here. I'm having a hard time with the ambition part when I don't know if I will be alive 6 months from now.
  24. OneGlanceMan
    OneGlanceMan Member
    You asking me? If so, both boredom and necessity. Lol
  25. tangledupinblu
    Pandemic modifications.
    OneGlanceMan likes this.
  26. pillboy
    He should have added battle armor and a turret machine gun for when the real nastiness of the pandemic arrives.
  27. tangledupinblu
    That is the Zom-demic.
  28. klutz
    klutz Well-Known Member
    I got some new Michelin Sport 4S put on, the stock Dunlops were on their last legs in the fall. Only put a few miles on them, but they feel great and are nice and quiet.
    minnesotanice and tangledupinblu like this.
  29. MidnightImpreza
    Summers are back on. I thank Derp for the tires.
  30. tangledupinblu
    I did a thing...
    Driftorz mode!
    griiiip!
    And detailed the interior because it NEEDED it!!
  31. pillboy
    I like the ramps.
    klutz and tangledupinblu like this.
  32. tangledupinblu
    Thanks, they’re custom!:D And the little orange ones are my sweet jump for my roller skates.
    pleiades and klutz like this.
  33. ryjacobs
    ryjacobs Well-Known Member
    Got the WRX started for the first time this year on Saturday and drove it about 25 miles. Time to break in the new motor!
    Edit: Nina waves hello, and enjoyed the drive!
  34. pleiades
    pleiades Well-Known Member
    This may be a divisive mod, but I did some vinyl wrapping the other day. I've always been unreasonably annoyed with the two different "carbon fiber" patterned plastics in the Crosstrek....
    I initially got some silver trim pieces to cover one of the patterns right after picking the car up, which helped but they glared a little and were kind of boring/cheap looking...
    So I decided to spice it up a little (it's my work car so anything I can do to make it more interesting helps) and wrapped the trim pieces...
    JaloP, Peder, tangledupinblu and 3 others like this.
  35. tangledupinblu
    Cruise with us Saturday!? @ryjacobs
  36. Mnelson
    Mnelson Well-Known Member
  37. pleiades
  38. tangledupinblu
    Krazylegz1485 likes this.
  39. Krazylegz1485
    This...
  40. Mnelson
    Sure did.
    Yes but forever a memory, instead of too many memories to remember. On to something different!
  41. pleiades
    Have you decided what something different is going to be yet?
  42. Mnelson
    I wanted to put the money into the mustang but work has my energy completely zapped, and I'm not that motivated to get going on it.
    I've been looking around and getting opinions today. The e92 m3 looks and sounds cool but zaps the Mustang budget. Then again, a 05+ mustang convertible would be cool too but a v8 costs too much and a v6 is too slow and sounds like garbage. Part of me would rather dive into an LS platform of some kind but I'm not a fan of older body styles and the new stuff costs too much.
    It's really hard to say im interested in any one thing. Though something classified as "cheap burnout machine" would work. I'm probably being too picky.
    I'm a little torn as there is also an option to pick up a obxt for a decent price... But I already have two (na) subarus (to fix) and feel like that's wasting my opportunity to try a different platform.
    :frantic:
    In the end, I don't know.. I didn't think i'd get this far.
  43. pillboy
    A new woman will take care of the extra cash that is bothering you.
    tangledupinblu and Mnelson like this.
  44. Mnelson
    I'm assuming that it's like cars, where if you have the funds to have two, then get two?
    I asked the current GF and she said she will consider it now that we have the bigger bed. :thumbup:
    Somewhat related, I swore to myself I won't get married until the house is done and the Mustang has 600hp. Gf asked if she can buy the crate engine to hurry that up. I think she's trying to tell me something.
  45. Krazylegz1485
    I'll be the first (and probably not the last) to say this, but this sounds promising...
    Mnelson, MidnightImpreza and pillboy like this.
