  1. Krazylegz1485
    I feel like this has been my exact frame of mind for the last 10+ years... Haha. Someday maybe I'll see it through.
  2. pillboy
    Which aspect, bed or crate?
  3. Mnelson
    Mnelson Well-Known Member
    Yes
    pillboy and Krazylegz1485 like this.
  4. Mnelson
    Decided to sacrifice the Forester for its engine. Planning to use it in the outback that has rod knock. Ended up finding an external head gasket leak so a quick swap turned into a huge project, which is expected with subarus.
    In other news... Anyone need a forester parts car?
  5. tangledupinblu
    Did you grow out your hair?
  6. Mnelson
    Only my ball hair.
  7. Krazylegz1485
    Proof?
    Wait... Nevermind. Haha.
  8. Mnelson
    Can't attach images over 5mb. Sorry man, just too big..
    But in all seriousness, the SO got to help disconnect most of the wiring harness and intake which was a lot of fun to do together. Hopefully next weekend we can pull the old outback motor and give the engine bay a good wash.
  9. silver03
    Goodridge lines installed on all four corners. Guy on CL a 10 min drive away...NIB with all hardware. How often does that work out?
    Cotts612, tangledupinblu and pleiades like this.
  10. pleiades
    pleiades Well-Known Member
    Nice find! I put the same ones on my bugeye a few years back.
  11. Vector
    Vector Rally Organizer
    I put the summer tires on the Forester. The car has used less than one tank of gas since March, so it wasn't a priority.
  12. ryjacobs
    ryjacobs Well-Known Member
    Hit 1000 miles on the new engine! Tune at JM scheduled in a couple weeks!
  13. euro
    euro Well-Known Member
    Bought another chassis to recieve the ej22 in my garage. Old chassis is being reworked to tube chassis mid engine.
    GrawvyRobber likes this.
  14. klutz
    klutz Well-Known Member
    I won the sad lottery a week plus back and spun on a rod on My 2016 WRX on the dyno. :(
    Wasn’t trying to do anything g crazy, just stage one. I guess it couldn’t happen to a nicer guy....
  15. tangledupinblu
    That sucks.
  16. klutz
    Yup. Wouldn’t have tried it had the vast majority of peeps having success. My fa20 was garbage apparently.
  17. tangledupinblu
    I would have never guessed that a stage one tune would be that devastating. Sorry to hear.
    plans?
  18. klutz
    I’m having JM put a new engine in and getting the stage one once I get through break in. It’ll be covered this time in case something goes wrong.
  19. ryjacobs
    Tuned at JM on Tuesday! It went well, I really recommend them!
    A1CFC920-3835-473A-85BF-536C079773BF.jpeg D498D997-FDBD-4977-9BC4-8BEE29D5E5B5.jpeg
  20. klutz
    Nice! I just got mine back. Breaking in period first but then can't wait to see how it does with the new cold air intake, tune, and new engine.
  21. loxx0050
    loxx0050 Well-Known Member
    Finally got around to buying and putting in dash cams.
    Pulled the trigger on some Aukey DR03 front and rear cameras as there was a sale on Amazon ($65 for the set + tax). Still had to buy a memory card (128gb Samsung High Endurance) and also bought a mirror mount carrier clip $10). It was so cheap I bought 2 sets and put the other one in the wife's car (she needs it more than I do based on an incident or two a whiles back :(). All said and done it came to $115 per car to get them up and running. Ran the cables in the headliner, front down the A-Pillar under the floor mat to the 12V accessory unit in the center arm rest and the rear through the top rails and snaked the cable through the rear door/hatch rubber wire protective boot. Did mostly the same for the wife's car too but could seem to get the rear headliner popped off and gave up since it was on one of those 95F days and I was sick of sweating buckets out there (mounted it using the sticky kit on the flat metal piece behind the middle child seat rear strap clip/bar).
    Word of advice, the Aukey Hardwire Motion Dectection kit is junk (that plugs into the ODB2 port). It kept power cycling/rebooting the cameras on my Outback every minute or so...non stop (on the wife's car (Honda CR-V it could get up to 2 minutes but would still constantly power cycle). Lots of complaints on Amazon that it doesn't seem to work properly with the DR03 model (but seems to mostly work with the DR02 and below models). It's not the cameras because when I plugged them into a AC power source (using one of the several dozen USB phone charger plugs I've amassed over the years) it worked fine when left on for 30+ minutes with no power cycling. Tested both hardwire kits in each car with each set of cameras. It didn't make a difference. Returned those immediately for my money back.
    Also, the night mode isn't the greatest so at night without good street lights it can't seem to capture license plates very well for the rear camera. Didn't look at the front very closely. But it's not like I bought a top of the line system so it's still better than the not running them like I was before.
  22. tangledupinblu
    At first I thought that it replaced your rear view mirror, lol
  23. loxx0050
    Yeah, the thing is giant in comparison to other systems and I can't hide it for stealth because of the 2.7"LCD screen.
  24. tangledupinblu
    -Removed, cleaned, and oiled my GS intake filter.
    -cleaned the MAF sensor(which looked as if it had never been cleaned before.
    -detached my front bumper to get it realigned. It was off and would not sit/connect properly to the quarter panel.
    -then I hit it with some Mothers Showroom Detailer. Just because
    7C1D501E-4EDC-4CE0-8F0A-45A37C64532B.jpeg 559FAC28-4E17-41E4-A2FC-E52994F693BB.jpeg 7AD6195A-7601-4F2E-967D-CAFFB46D1FF5.jpeg 3C6FBFCB-A73F-4DFA-B241-FE2639CC2C56.jpeg
  25. pillboy
    But did you water the hanging baskets?
  26. tangledupinblu
    Yes. They needed it, it was hot.
    pillboy likes this.
  27. Chux
  28. tangledupinblu
    35th Anniversary Edition! She’s a collector!:D
  29. Chux
    Too bad these are such a crummy "special edition". Total base model + H6, climate control and painted handles/mirrors. I just noticed they don't even have tweeters in the doors. My '00 even has those...
  30. Chux
    Bought a couple Foresters yesterday. Both in very rough shape, and priced accordingly. But we were thinking one could probably make the 150 mile drive.
    I've never thought much of rear VLSDs, never seem to be very strong. And with how beat this car was (and the fact that we didn't think it had one), I wasn't worried about the mismatched full sized spare (215/60r16) with 3 smaller tires (225/50r16). Made it abouT 40 miles before I could feel the diff binding up so bad on straight roads that I knew something was wrong. We pulled over and the rear diff was crazy hot to the touch, so swapped the mismatch to the front, but the damage was done. After about 10 more miles, it actually started on fire. Looked like the gear oil had boiled/blown out of the vent and/or side seals, and covered the diff, which caught fire. Not sure if the ignition was from the heat of the diff, or the exhaust, but either way. Luckily there was an extinguisher in the truck, so we got it put out quickly. Drove 10mph for about 2 miles to park it in a Dollar General parking lot in Luck, WI. Drove home and yanked the junker off the trailer, and came back for it. Got home after 2am.
  31. predavore
    predavore Well-Known Member
    all that and no pics?
  32. tangledupinblu
    Luck,WI...can’t make this stuff up
    Krazylegz1485, pillboy and Chux like this.
  33. Chux
    Yea, when we put the fire out, and looked down the road for a better place to leave the car, there was the sign that said Luck is 3 miles away....
  34. GrawvyRobber
    GrawvyRobber Active Member
    Can't thank @ericthegoalieman enough for the free antenna delete. Finally got around to pulling up the carpet (only the antenna goes underneath the driverside carpet.....) and pulled 'er out.
    Don't forget to remove and use the old rubber bushing(?) from the previous antenna. Small but cute mod imo
  35. predavore
    Ah... the good old days. I actually inspired that mod. I asked Justin to make it and he sent me the first antenna delete and windshield mount antenna. Such a nice clean mod. I eventually tried to paint match mine to blend it even further.
  36. predavore
  37. Chux
    Apparently I'm into 1st gen Foresters, now....
    And then there were 3:
    20200912_192112
    by Numbchux, on Flickr
    Wouldn't have been one of my projects without drama....in a lesson on why not to leave the ebrake on for extended periods, the left rear wouldn't release. I have a winch on the trailer, but it's a Harbor Freight ATV winch. It wouldn't have done it without the snatch block, I would have used a second snatch block if I'd had it.... and to get the trailer lined up with the car, the truck was sticking out in the road. Not to mention a few strange looks on the way there due to the car being backwards on the trailer, and the truck was involved in an accident this week, so the grill is gone, headlights held in with zipties, and bumper is all bent up. A true sight going down the road.
    [​IMG]20200912_153824 by Numbchux, on Flickr
    Not sure what the exact recipe is going to be, but hoping to make at least 2 good cars out of the 3. This silver '01 is very solid cosmetically. Lots of surface rust underneath from sitting, but some of the cleanest quarters I've seen on any Subaru more then a decade old. And the red '98 is an "S" trim, with the big ass moon roof, so I'm thinking that's the other shell that will survive. Although I have to figure out why the rear diff started on fire, since it doesn't appear to have a VLSD...
    tangledupinblu, Mnelson and JaloP like this.
  38. sneefy
    sneefy Well-Known Member
    Yeah, that might be important.
    tangledupinblu and Chux like this.
  39. JaloP
    JaloP Well-Known Member
    They do look good :thumbup:
    I used to think Foresters were ugly but for some reason I'm really into the first and second gen models
  40. Mnelson
    Every story has two sides. I feel bad I wasn't around to help but I'm glad you got it figured out and the old forester found a good home!!
    That isn't the first time that my street has had an impromptu road block and probably not the last.
  41. Chux
    Don't feel bad, I managed just fine. Just thought it was a bit of a comedy of errors :p
  42. tangledupinblu
    It wouldn’t be a good story if it didn’t have some shenanigans! Lol
  43. silver03
    Replaced this with a new OEM one yesterday. Hoping that gets rid of that pesky P1443 code on our 03 WRX. IMG_1333 smaller.jpg
  44. Chux
    I was sitting in my front yard yesterday, looking at my Forester collection.
    And then I looked in the garage and saw my welder.
    And then I spent 5 minutes on Paint.
    2020-09-17_08-32-52
    hmmmm. In my free time....
  45. derp
    do it
