  1. pinjasaur
    pinjasaur Well-Known Member
  2. tangledupinblu
    A little tip for ya after all of that hard work. Get them covered with clear bra type material. I paid $60 to have mine wrapped on my bugeye after spending 5 1/2hrs sanding and polishing them. I sold the car 6 years later and they still looked just as good as the day that I restored them!
  3. euro
    euro Well-Known Member
  4. euro
    Finally got the H&R springs i ordered a few weeks ago. Had just enough time to replace the rears. Fronts will go in next week when i get a new driver front axle.
    tangledupinblu and pinjasaur like this.
  5. Butthau5
    Butthau5 Well-Known Member
    This weekend I installed a Perrin turbo inlet for a friend. Fixed a few leaks on his car, oil pressure switch and avcs oil feed line and then I over torqued a bolt on his power steering pump so I got to learn how to use a helicoil, fun times. Traded my time and suffering for a snowboard and $100. Good deal.
    pinjasaur, tangledupinblu and euro like this.
  6. MidnightImpreza
    New lugs to dress it up a little.
    pinjasaur likes this.
  7. Krazylegz1485
    Yet again contemplated driving it off a cliff. Noticed the wife's Forester running sporadically hot Saturday night. Fans were on and radiator was cold. Figured the thermostat was stuck shut but then I checked the coolant and it was low.
    Filled it up and ran it again and it seemed fine. Added a little to the overflow just for the hell of it. Monday she said she noticed it gets warm again for a second while they were in the sun, but pulling around into the shade it cooled right back down. I checked it, it was low, so added a little more.
    Last night I checked it and it wasn't quite as low as before, but now the overflow is full and I'm pretty sure it's pushing it out of there now as well (wet around where the overflow hose goes in).
    So... Anybody got a connection to a good running 2.5 in a junk car? This thing has 190k ish on it and has already had the gaskets done once at some point. I'm contemplating doing the minimal (head gaskets) and calling it good. However, with the mileage on the short block I'd consider just swapping in a complete long block (plus that would ideally save some down time).
    Only reason I wanna put any effort into this thing is it's allegedly a California car and it's actually pretty clean rust wise.
  8. silver03
    Once you have a replacement motor found if there is any I can get in your way and slow you down while doing this...you know how to reach me.
  9. MidnightImpreza
    Hit 50k on the 2016.
  10. SaggyWagon
    SaggyWagon Well-Known Member
    Not today, but took the wagon out camping a couple weekends ago, after a rainstorm. Subaru AWD proves victorious yet again. There was so much dirt/mud stuck throughout the suspension and undercarriage that the whole car would vibrate at 40mph. A solid 2 hours of pressure washing got it back to normal though.
  11. silver03
    Don't you hate it when you forget the mods you've already done and order stock replacements? 03 WRX needed rear pads/rotors. Best deal by far was Rockauto. I ordered stock replacement rotors forgetting that years ago I had "upgraded" to H6 rear brackets and rotors. Thank God I kept the original caliper brackets! So, if anyone is looking for H6 rear brackets I have a complimentary set for you.
  12. tangledupinblu
    Dug it out. Battery was kaput so I ran to White Bear Subaru and grabbed another. Car started but ran rough due to being parked for two months. Proceeded to swap on summer wheels
    And had a stud break off. Put everything away and walked away. Lol
    8D582435-DA58-46BB-AE9C-32CD2F82D019.jpeg 6919D009-2520-4600-872B-6F843D81C559.jpeg
  13. Krazylegz1485
    That's crazy. Bad car-ma or something... Haha.
    Actually, that's probably just the car's way of saying "Oh, now you want to play?! F you, guy."
  14. euro
    Lol it must be a subaru thing, my brat, 98,99 and 05 outback sports all had issues with snapping lugs including the time 4 snapped slowly while driving around Minnetonka
  15. silver03
    I feel ya brother. You're not alone. I've had 2 wheel studs break off over the years. Not hard to replace, but still...
  16. MidnightImpreza
    Double check torq specs! And stick to them.
    Krazylegz1485 likes this.
  17. euro
    Nah, i just upgraded to some arp studs that accept uggadugga specs
  18. tangledupinblu
    Maybe I should go that route. Ended up snapping two on the same wheel. Zero issues with the other 18 lugs. Dunno. If you look at the pics, they snapped off at the rim. So about half of each lug is still there.
    3 lugs are good enough amirite!?
  19. euro
    Thats how all my 05 outback sport ones were when i noticed i had 1 lug left.
  20. tangledupinblu
    Torqued to 90 lbs. based on Subarus specs
    MidnightImpreza likes this.
  21. Faber
    Faber Member
    Did it last Thursday, went Delicious Flex Fuel.
  22. Steve-o
  23. Butthau5
    I'll scoop these if you still have em
    Edit* or you could meet up with @thomas franz in Anoka.
  24. pinjasaur
    Put WRX pedal covers on the FXT today. Honestly a huge PITA.
  25. silver03
    They're yours. I will be back in town sometime this weekend. Let's look at next week.
  26. PJ171
    PJ171 Well-Known Member
    Where did you go for the tint out of curiosity? Looks great
  27. loxx0050
    loxx0050 Well-Known Member
    I finally changed the spark plugs on my 2014 Outback 3.6. Man was that a PITA but couldn't stomach the dealers quoting close to $600 to do the job and one local shop near me quoted 850.
    A bit overdue as I'm at 79.5k but the plugs weren't too bad that I pulled but definitely a bit worn. Was able to get it all done without touching the front motor mount (I've got small hands for a dude and was able to eventually get the coils/plugs out and new ones in). Lost some skin in my thumb but the knuckles are intact at least :thumbup:
    I really want to meet the Subaru engineers and management that sign off on the engine setup and placement. They all deserve a punch in the back of the head.
    While I was at it I also changed the plugs out on my wife's Honda. So much easier for that as I finish in 45 minutes doing that only because I've got butterfingers and dropped a coil into the engine bay. Took a bit to find it and fish it out.
  28. euro
    Vacuumed out a mouse nest under my manifold and hand washed thr dust and webs off of everything.
    Tundra buggy i dismantled the "rebuilt " engine after finding they hadn't installed woodruff keys on any of the pulleys and torqued down absolutely nothing.
  29. pinjasaur
    Changed the oil, transmission fluid, and rear diff fluid today. Transmission required funnel shenanigans.
    euro, tangledupinblu and LASERBLUE135 like this.
  30. tangledupinblu
    Hmm, that is not where I have always pictured
    punching them.
    the little guy sure keeps his car clean! That thing looks pretty cool
  31. pillboy
    "Funnel Shenanigans"
    New game in the App Store. Contains in-app purchases.
  32. predavore
    predavore Well-Known Member
  33. euro
    Yeah i showed him wiping my car down literally once and now he asks for wet rags to wash his car whenever he's near it.
  34. PJ171
    Need one of them new fangled flexible funnels lol, seriously though they are great for that job.
    Can't wait till my son is old enough to wrench on the Scoobie....
  35. pinjasaur
    Put a Koyo radiator, GS hoses, thermostat, and cylinder 4 cooling mod in the FXT.
  36. pillboy
    More funnel shenanigans?
  37. silver03
    cylinder 4 cooling mod?
  38. pinjasaur
  39. LASERBLUE135
    It’s a thing. My car has it (JM did when built motor). Little trick to cool that particular cylinder as it tends to get the most heat and is a week point
  40. Krazylegz1485
    The weak point is under the hood.
  41. tangledupinblu
    Not the Subaru(something more reliable). Luckily found this before something bad happened...
    ps, check out the jack in the second pic! Lol
    9CD00F0B-8126-4523-96DD-CFC669D8C4E4.jpeg E98DD064-F64E-4D14-9AD8-AAB686470FAB.jpeg 7949E8C0-9CAE-45B1-9E26-B001EC70962D.jpeg
  42. PJ171
    Oof, first question is how? Tred separation or road debris?
  43. pillboy
    Looks like you locked up the brakes while doing a buck and a half.
    That Harbor Freight floor jack looks like it has met its match with the Cargo Van Go.
  44. tangledupinblu
    From the looks of the back tires when they were removed, I would say tread separation/broken belts. The scary part is that I drove to Iowa and back a couple of times on them. The passenger side didn’t have the hole at the time as I’ve inspected the tires multiple times since purchasing the van. The plan was to buy all 4 replacements because old. Unfortunately, I’ll need to wait a few before I can grab the new front set.
    pic from the internet. But this is what the driver side rear looked like. Looked like camber wear.
  45. Krazylegz1485
    Weird. Isn't that a straight axle in the rear?
