  1. 02blubru
  2. Scuba Steve
    what are you doing? forged pistons? :yumyum:
    :eek4: this isnt a headgasket issue is it?
  3. 02blubru
    yes...
  4. Scuba Steve
    headgasket huh...that sucks.
  5. morganm
    morganm New Member
    I put some zip ties on it to hold crap together.
    You know you got a real Subaru when some stuff is held on by zip ties!
  6. tangledupinblu
    Spent 4-5 hours cleaning mud and grass from Sundays rally-x off/out of the car...funny thing is, i'm MAYBE half way done.:emo:
    But man it was fun!:woot:
  7. Moleness
    ^^^ That is one of the dirtiest cars I have ever seen
  8. 03subyR
    03subyR Well-Known Member
    That sucks man. Might as well get pistons and rings replaced for larger turbo:biggrin:
  9. greg donovan
    replaced an alternator belt, oil fill neck o-ring and a broken handle on the tailgate of the wagon.
    cleaned some windows too.
  10. carl
    andrew and i rode the failboat on everything today. well, really it was the parts fault mostly, this isn't going on (gussets too close on top and bottom)
  11. FastMatt
    FastMatt Well-Known Member
    That sure dosen't look like a fun ride at all. Bummer
  12. carl
    the coilovers themselves are pretty nice, I'm just a bit frustrated with the fit on the fronts
    (40mm bilstein, h&r springs, group n tophats, custom bodies)
  13. sniper1rfa
    sniper1rfa New Member
    Yeah, we managed to not do a lot of stuff today. :-/
  14. FastMatt
    They look great, but I bet they'll look (and work) even better ON the car!
    Good luck guys!
  15. jamusix
    jamusix Well-Known Member
    Got new tires today from the Tire Rack -- Bridgestone Potenza G 019's!! No they're not summers, but they're supposed to be a hell of a lot better than RE-92's. Can't wait to slap 'em on.
    Anyone want RE-92's with less than 4/32" tread remaining?
    ALSO installed some Kartboy front endlinks today. Good gawd what a difference! :eek3: Of course, I installed rear aluminum endlinks two weeks ago so the car's been pretty off-balance since then. ...until now! :biggrin::biggrin:
  16. 9blackmax6
    got these back :yumyum:
  17. modsuby
    modsuby New Member
    finally got it running today
  18. mke723
    mke723 Well-Known Member
    i installed my new to me bride ergo seat, then went and played to test her out, may need to go up a notch, but no more swaying in my seat, like a tree in a huricane
  19. mke723
    try a cobb nobb... the platic, or polymer, or what ever its made of is awesome, best feeling knob ive hand my hand on, woah, that didnt come out right...lolz.. any one wanna get their hands on my (shift) nob at locks meet thursday is welcome too... it will be the black dirty one
  20. WRX1
    Installed the sticky bar, updated the member list, start the next......
    Ahhh wait, wrong thread.:laugh:
  21. Streetrodder83
    Streetrodder83 Member
    Paid for my Nitto NT05s that just came in.
  22. morganm
    morganm New Member
    JB Welded my radiator. Some stupid press fitting where the fans bolt to the radiator started to seperate making a tiny leak. Ended up JB welding all 4 of those fitings just to prevent any others from seperating and leaking. This will get me by until I buy a new radiator.
  23. asujosh1
    asujosh1 Member
    Smashed it into a Audi.
  24. dhanso312
    dhanso312 Well-Known Member
    bought it.
  25. jamusix
    Got the new tires mounted & balanced. Can't wait to break them in...
  26. carl
    dual exhaust
  27. jamusix
    Silent seat belt mod on both drivers & passenger sides. Easiest, quickest, and most effective mod I've ever done (aside from the shift knob). :eek3: Took me 30 minutes for both, and it was my first time. That was also with hand-sanding, not a dremel... :cool:
  28. Scuba Steve
    fyi- duct tape works wonders. installed in 30 seconds...last for years
  29. jamusix
    Yeah, I considered that. This will last forever. :biggrin:
  30. ford0650
    ford0650 Active Member
    I found out the 04 sti has a speed limiter.
  31. bobafett04wrx
    bobafett04wrx New Member
    what was it?
  32. ford0650
    Limited to 155
  33. tjamz
    tjamz Well-Known Member
    Ordered some rod & main bearings, Cams, Springs & Retainers, oil pump, water pump, gaskets, etc... to go with the stroker kit.
    Starting to pull the old motor this weekend.
  34. RichWRX
    RichWRX Well-Known Member
    packed it for a 9 day trip to Florida!
  35. dmoo
    dmoo Well-Known Member
    o really?
    my subaru activity was spend a 15 min Homework break touching up wheel paint.
  36. KA-T_240
    KA-T_240 Well-Known Member
    Put on a JDM Bugeye STi hoodscoop!
  37. idget
    You missed it. We modified it into a cold air outtake.
  38. Bullwinkle
    Yup, this is a parameter in the stock ECU mapping. Very easily changed if you have access to a cable and laptop.
  39. ford0650
    I don't need any more at this point. that was enough for me
  40. Snowbum
    Snowbum Well-Known Member
    Over the weekend I did some work on the 1998 Leggy Outback. The waterpump gasket was leaking and it had an internal headgasket leak and the front differential bearings were on the verge of exploding. The vehicle has 160k on the body and 60k on the "new" ej25.
    I replaced the following:
    Timing belt
    Tbelt tensioner
    2 idlerpullies
    waterpump
    Headgaskets
    valve cover gaskets
    cam seals
    Intake manifold gaskets
    spark plugs (NGK Iridium)
    Genuine Subaru air filter/fuel filter
    I cleaned the surfaces of the pistons, ALOT of carbon build up on them pistons. I also got the carbon off the combustion chamber/valves.
    Installed a "new" 4eat with 104k on it. Replace all external seals, and replaced an inside cv boot.
    I think thats abooooot it.
  41. Snowbum
    She runs like a new car now.....shifting is smooth and there is alittle more power :yumyum:
  42. ScandiaWRX
    Tuesday I swore out load because I hit a pot hole a busted the sidewall on a tire that was less than a month old. So I'm driving the Leggy till the new one gets here Friday.
    Amy
  43. Bielke55
    Gonna be de-stickering it soon
  44. Moleness
    I would hope so ;)
    :yumyum:
  45. Shibbs
    Put a DVD player in the dash. :yumyum:
