  1. 08summit
    08summit Member
    new wiper blades on the sti for the snow!
    i can see again!!
  2. bora28
    bora28 New Member
    Just got done tearin' up Opus!
  3. Dynapar
    ^SSHHhhhh! do not mention that place. :shifty:
  4. zisson33
    zisson33 Well-Known Member
    Fresh transmission/differential fluid...a little Extra-S for my a.. Planning an oil change tomorrow morning.
  5. HiImBrian
    HiImBrian Member
    That's my rear tow hook. The fronts are in fact welded on.
  6. Dynapar
    Dang! I had hope that I could have pulled my fronts out. I guess I will have to come up with something else.
    I put a transmission in today, mostly. Had some huge issues with the roll pin in the shift linkage now my finger is all busted up.... going to slow progress.
  7. Lowrider
    Lowrider Well-Known Member
    Had a coolant flush done, replaced heater, upper and lower radiator hoses.
  8. JasonoJordan
    pulled out the raidiator and tore the front of the motor down to replace a damaged light weight crank pully and crank keyway key. the bolt on the crank pully came loose causing the pully 2 work its way out and break the key and the keyway on the crank pully. now in the market for a new lightened crank pully
  9. boomer
    boomer Well-Known Member
    If you need something to start with I have 2 factory tow hooks laying around. I'm sure we could come up with a way to mount them up front.
  10. Dynapar
    I have known a few people with this issue, and never have quite figured it out. I think I have a stock 2002 WRX pulley laying around somewhere if you want an OEM piece.
    My hooks were cut off. so I have part of them there but not the actual loop part. I wonder if welding the loop back on would hold up, or just come flying off. Might need to involve some engineers in the process.
  11. JasonoJordan
    thanks dyna i wanna stick with a lightened one if i can. i orderd a underdrive one by accident today but im hoping to get one ordered here in the next day or 2. reason it came off is i dont think that my freind and i got it tight enough after we finished the timing belt change. :(
  12. ricetiva
    ricetiva Well-Known Member
    i got bored and i did this(painted rims)
  13. blake
    blake Well-Known Member
    Paid off my car. Booyah!
  14. LASERBLUE135
    Now that is cool!
  15. Dynapar
    Gotcha. Was it hard to replace that key in the crank?
    You should lift it ;-)
    Congrats!
  16. blake
    Thanks guys! Its a really good feeling.
  17. ricetiva
    i do have 02 or 03 wrx suspension in it and from what i gather that is 3/4-1 in lift. if i wanted to go high(which i dont) i would have done the forester suspension and go 2 inches.
  18. Dynapar
    forester struts and some scorpion lift springs could get you 4 ;-)
  19. carl
    and then some jackson rally 2" tophat spacers for 6" :laugh:
  20. ricetiva
    no im good with where i am at lol
  21. bubba_crx
    bubba_crx Well-Known Member
    I'm obviously not... got stuck at my apt the other day... Do you need to get an alignment if u put on forester struts/springs? And does it hurt ur cv shafts at all?
  22. Shibbs
    Proper welds are stronger than the steel they hold together.
  23. putz
    putz Well-Known Member
    I installed a new blower motor, pass side headlamp, and screwed the driverside fender to the body (1/4 self tappers, NICE DIY body repair!)
  24. IzzySTi
    IzzySTi Well-Known Member
    Blew the trans in the 97 Leggy GT today, sounds like parts rolling around when in gear, FML now looking at an 02 Forester with 112xxx, for bout 9g
  25. Lowrider
    Degreased/washed the engine.... and also had a title transfer processed.
  26. bubba_crx
    Zip tied the crap outa my inner fender liner, since it decided to fall off and smash into pieces on my way home on xmas... sorta like new, lol... cept a few little missing chunks, bit it's one big piece again..
  27. LASERBLUE135
    crossed 100k miles. She's in the garage at 100,001 right now.
  28. Dynapar
    Since you will be having the front struts off you will most likely need an alignment since the front camber is controlled by one of the lower strut bolts. If you were using the same struts and bolts you could mark them and re-align them. The rear alignment should not change. Although there is a chance that by raising the car you will shift some of the pivot points which could change your alignment. For example the rear trailing arm will have more of an angle on it which could lead to some more rear caster. stuff like that.
    I am not sure of the flexibility of the CVs and DOJs on the EJ stuff. I know that running a 4" lift on the older style Subarus is doable (GLs, Brat, Ect..) it does increase your axle angle which will put some more stress on those components. However how long they last will depend on how hard you are on them. I recall Chux exploded a CV on a trail up at gilbert, but that was involving lifting wheels and such.
    I am picking up more part at the dealership today :). I am hoping to have my car running tonight/tomorrow.
  29. stuffelse
    stuffelse Well-Known Member
    So this evening I decided to do the air filter in my Legacy. What a friggin production. I'm not sure if it's just the filter I got (wix) or if the airbox is normally that tight. I had to remove it from the car and squeeze the crap out of it just to snap down the clips.
    Far and away the most difficult air filter I've ever done, but at least I know there's NO WAY unfiltered air is getting in there.
  30. Dynapar
    had some more slow progress. got the hubs on, ebrakes re-installed and set, calipers back on, driveshaft in, attempted to un-mangle the front support dealie, tore down and cleaned a rear axle for new boots. Tomorrow is going to be a long rough day, but I am hoping I can finish.
  31. Mr. Derek
    Mr. Derek Well-Known Member
    I'm not sure what the legacy air box looks like but on the wrx if you slide the end without clips in to place then open the other end just far enough to slip the filter in it's alot easier. That was the only way I could find to easily get my k&n filter in.
  32. ofspunk7
    Picked up some new wiper blades. My OEM wiper blades decided to cut the glass (in a few places) on my car during my trip to/from STL. LAME!
  33. blackcherrypsm
    blackcherrypsm Well-Known Member
    put in a new duralast gold battery in the subie, hardwired the radar detector in, painted my winter wheels with red caliper paint (looks good and mild), and washed it
  34. stuffelse
    There was no easy way to do this! the airbox has plastic clips on the bottom and metal snap clips on top and sides, but the gasket on the air filter was just too damn thick to close easily. Thing's tight as a drum now.
  35. kmw1191
    kmw1191 Well-Known Member
    well it wasn't today, but Wednesday I put in 2 pioneer speakers in the back, fixed the front right speaker, and added a subwoofer :eek3:
    I would almost be willing to say that I may have the slowest, and now loudest 94 wagon on here :laugh:
  36. hella_sti
    hella_sti Well-Known Member
    washed my car by hand at one of those diy jobbers, their air blower was "broken" so my windows froze. So I drove around for 10 min with the heat cranked, bingo. I love having a perfectly clean car before the temps go subzero, it stays so nice and clean with everything frozen solid.
  37. stuffelse
    Valve adjustment inspection, new valve cover gaskets, oil change. Despite the butt-cold temps outside, the Mr. Heater did a sweet job of keepin the 3-car garage comfortable.
    SOHC WIN. Nothin like quick valve adjustments with no shims. :)
  38. Lowrider
    Replaced the Air filter & gave it a wash
  39. speedyham
    speedyham Well-Known Member
    I cut 18 lbs of unnecessary steel off the car today. It's getting pretty hard to find weight savings in that car.
  40. 02blubru
    not today, but I have been ordering lots of things for it...
    hids
    fog kit
    weather tech floor mats
    stuff to install after market stero
  41. IzzySTi
    Un-installed mudflaps (sorry tony not my style) and installed primitive racing skid plate, and drove around some!
  42. asujosh1
    asujosh1 Member
    Installed my Perrin downpipe!
  43. zisson33
    Installed my boost gauge today in the air vent. Looks good, but I need to fix the illumination wiring. No big thing... :biggrin:
  44. psychorunner
    psychorunner Member
    Installed a custom air/oil separator...just waiting to see how much oil it'll clear out of the system now...
  45. WRX1
    Nothing yet, but this afternoon (if it starts), a new battery will be going in.
