What engine?
Discussion in 'Modifications And Maintenance' started by slowrex53, Sep 9, 2009.
  1. slowrex53
    slowrex53 Well-Known Member
    hey all, i was wondering if anybody knows what is the newest year wrx engine(USDM) i can drop in my 02 wrx. I dont want to do any wiring. I know if i was to get a STI there is issues with a AVCS.
  2. Shibbs
    I think you're pretty much stuck with a 2.0 if you don't wanna work with any valve timing stuff; however I know of a few people using an STI block with WRX heads successfully.
  3. slowrex53
    thanks for the info, but thats what i have right now and cant seem to get a reliable setup. I just got done putting my third hybrid setup in it and with in 200 miles it spun another rod bearing! I just want to start fresh with a complete different engine.
  4. Shibbs
    Buy my 07! lol
  5. slowrex53
    LOL, i hear that!
  6. Nuke
    If you are willing to look for the 2.5l harness, then you can swap it over.
    You will need the pedals also.
  7. slowrex53
    well i wanted to stay away from that. Nuke do you know of anybody first hand that is competent enough to assemble a hybrid engine? I wouldnt need the block split just my good piston put in and my heads put on.
  8. Nuke
    Check your PM. :cool:
  9. Michael48
    Michael48 Member
    Brian you need to just swap everything with the wiring and your computer and go to a JDM Sti long block :) Good luck the 7th engine will be the charm :eek4:
  10. AWDimprezaL
    Something is definatly up if you have gone through that many engines, check your oil ever? what kind of tuning do you have? gas you run?
  11. wall of tvs
    yes, you're doing it wrong, haha
  12. slowrex53
    OIL? What oil?! LOL, J/K. Ive touched base with Matt @ RS. He will be the next to try and figure this out. From the little ive talked with him on the phone i feel cofident that he will be able to help me through this.
  13. AWDimprezaL
    He will absolutely be able to help you, I'm not sure what happend with your other engines, but I'm sure it has something to do with the builder. (not that I even have any idea who it was) Matt is one hell of a mechanic.
  14. slowrex53
    Good, im glad to hear that!
