  1. wagonsrumble
    wagonsrumble Member
    Yea I havent had any problems with Napa parts or parts from Welle auto supply either. I would never go to autozone for any parts cause most of their counter guys dont know what theyre talking about. And I can see the distance thing but come on lol. If I had to get a part from oreileys I would but thats only if Napa couldnt get it or something like that
  2. Ryan FailRad
    When you have to make 4 trips to oreileys and you end up putting on 30 miles to and from oreileys for a belt... There's not enough difference in the world to justify me tripling the distance I will drive someone else's car to try parts.
  3. wagonsrumble
    wagonsrumble Member
    Agreed. But with Napa we couldve gotten the belt closer to the right size the first couple times so you wouldnt have to keep going back but I guess I see your point in the distance factor and it not being your car
  4. Ryan FailRad
    Good luck guessing the size of a belt being used in a custom application lol.
  5. Krazylegz1485
    My parts store can beat up your parts store...
  6. phi11
    What ever happened to measuring? Take a piece of string and lay that **** out and measure it!
  7. Ryan FailRad
    That measured out to 37.5 inches.. Trust me, that was the first thing I tried, for some reason it was no where near close. Needed almost 2 more inches of belt
  8. tangledupinblu
    Operator error.
    GregRoot198521 likes this.
  9. Ryan FailRad
    We think it's because the string went down into the grooves on the pulleys and the belt doesn't lol
  10. tangledupinblu
    Next time use bigger string!
  11. Ryan FailRad
    Next time, I'll do it in the parking lot at Napa :rolleyes:
  12. wagonsrumble
    wagonsrumble Member
    Lol Im fine with that if it doesnt spill any fluids on the lot you should be fine
  13. tangledupinblu
    Ryan always spills some of his fluidz.
    GregRoot198521 and Ryan FailRad like this.
  14. tangledupinblu
    Ryan's always spilling some of his fluidz.
    Ryan FailRad likes this.
  15. Ryan FailRad
    Usually an unmentionable fluid, then many, many tears.
    GregRoot198521 and Kneel Weiß like this.
  16. twiztid_rs
    twiztid_rs Well-Known Member
  17. Shancaldazar
    Bought two craftsman bench grinders. A 1/3 horsepower model and a massive 35lbs 1Hp Industrial model. These are from when grinders were actually rated accurately in their horsepower. Both of these are the super durable block motor models. Gigantic copper windings for the brushless motor. The 1Hp model takes about 2 minutes to completely wind down after the power has been turned off. Also missing a few pieces, but I can probably make most of them. Probably some of the best bench grinders ever produced.
    phi11 and TMF like this.
  18. TMF
    After a shipping issue, this finally showed up. Got a chance to use it for removing lugs to rotate the tires and I love it so far.
    Milwaukee M18 Fuel cordless impact, 3/8 drive, 200 ft-lbs max torque, 18v lithium ion (2), brushless motor, only 6 inches deep (easy access to tight spots :rolleyes:), 3 torque settings, and a handy led light. Northern Tool had a $50 off coupon, so it was just a hair over $200.
  19. turkeylord
    turkeylord Well-Known Member
    After sitting for over a year... :facepalm:
    In the last month:
    :) ~300 miles on her so far. :cool:
    pillboy, tangledupinblu and TMF like this.
  20. Ryan FailRad
    What's the water pump sprayer thing for?
  21. turkeylord
  22. turkeylord
    Just realized I posted this in the wrong thread, meant to post in the "What did you do" thread. :facepalm::asshat:
  23. TMF
    Isn't it easier to just pull the ignition fuse and crank it a few times before starting? I do that every time I take the car out of storage. I suppose that method could cause some minor wear in the initial cranking phase, but it is pretty easy...
  24. turkeylord
    I did that too actually. All of the prime.
    belalegosi likes this.
  25. TMF
    Ooo but I like the guy's idea for having a sprayer for filling rear diffs and/or transmissions. That would make life much easier!
    Ryan FailRad and turkeylord like this.
  26. turkeylord
    Picked up these too, definitely made the job a lot easier.
  27. xluben
    Outfront has stated to use a 38" belt. Are you sure yours isn't too tight? Where do you have it within the sliding bracket?
  28. Ryan FailRad
    It is almost as tight as it can possibly go on the sliding bracket. I can show it off at tonight's meet if I get there early enough and you stay late enough, otherwise I'll still be in the area of im not at digbys
  29. xluben
    Is it locked down somewhere in the middle of the movement range of the sliding bracket? Or is it just all the way at the lowest point?
  30. xluben
    I got mine installed. I ended up with the same belt (39.25"). It is borderline too big though. I am going to be looking for a 28.5" one when I have time.
  31. Ryan FailRad
    @xluben I took these photos as I went. They are yours to use if you'd like.
    Of the many belts I used, 39.25 was the smallest I could slip over the pulley that would still work correctly.
  32. xluben
    If you expand the post I quoted you can see that I have mine installed. The 39.25" fits over with plenty of slack. I'd like one slightly smaller but they didn't have anything when I went.
  33. 763WRX
    763WRX Well-Known Member
    Picked this up @GrimmSpeed today. Thank you guys for the awesome service over there!!:thumbup::thumbup:
    phi11 likes this.
  34. Ryan FailRad
    What other mods do you plan to do?
  35. Ryan FailRad
    Maybe your alternator is a small amount smaller than mine?
  36. CoyoteKyle
    CoyoteKyle Well-Known Member
    Stopped by GrimmSpeed this afternoon. Interrupted their lunch a little bit. Well, Art's lunch anyways. Poor guy set his hot dogs on the damn ground.
    Anywho... got the new intake and an EWG setup. I was gonna get the EBCS, but they were all out. Next up, I need to get it all installed and tuned!
    Thinking about a fuel pump too.
    Ryan FailRad and phi11 like this.
  37. Ryan FailRad
    Mbc for the ewg setup bruh. It will hold a steadier boost.. The ebcs tends to flutter, or at least that is what I have gathered.. Orr you could do a combo of the two and have the ebcs run the dd tasks and all that and have it so that the mbc controls it for WOT!
    CoyoteKyle likes this.
  38. CoyoteKyle
    Well, hell. Now I have things to consider!
  39. 763WRX
    Only time can tell :rolleyes:
  40. Aluminati
    Aluminati Vendor
    My Super Trapp muffler arrived for my ewg dump pipe. Having Fobia weld it on with an extension. Thanks for the help @TMF
    TMF likes this.
  41. Ryan FailRad
    What does that thing do now?
  42. Aluminati
    Aluminati Vendor
    Makes things less loud.
  43. tangledupinblu
    *FACEPALM*
  44. Goalie
    Goalie MNSubaru Goaltender
  45. tangledupinblu
    Oh no you didn't!! Nice Chris, real nice!
