Wheel question?
Discussion in 'Modifications And Maintenance' started by joe bretto, Jan 4, 2013.
  1. joe bretto
    joe bretto Member
    Just wondering what is the widest wheel that will fit On an 04 wrx. I'm thinking 17x8 or 17x9 will either one fit. Thanks
  2. tangledupinblu
    You can probably fit 10" wide with modifications. Pretty sure that you will need a fender roller to get anything bigger than 8'' on there...but i could be wrong.
  3. readymix
    I don't see why you couldn't hold a 17x9 with a decent fender rolling on an 04. Offsets will play a factor as well. What wheels and tire sizes are you looking at?
  4. tangledupinblu
    ^Do 8's fit without rolling?
  5. joe bretto
    joe bretto Member
    Looking to use tires off an sti. Don't want to roll the fenders just wondering biggest width I could. 17x8 work just fine?
  6. idget
    Yeah that's fine. 05-07 sti's came with 17x8 +53ish wheels stock.
    Which tires? re070s or dunlaps?
  7. tangledupinblu
    STi tires will work fine without a roll if you're talking stock Potenza's?
  8. tangledupinblu
    ^OMG i double posted!
  9. idget
    hopefully not... they'd be at least 5 years old if take-offs
    Stuck686 likes this.
  10. joe bretto
    joe bretto Member
    Sorry just looking to use the stock tire size off an 04 sti and some Rota grid 17x8 of possible
  11. idget
    Yeah, the grids typically come in 17x8 +48 in subaru fitment. Look for the newer hubcentric ones. a 225/45/17 winter or as tire might be a little stretched but most summer tires will fit nicely on there. The actually widths differ between brands and models. Check tirerack for specific tire to wheel width fitment.
  12. joe bretto
    joe bretto Member
    But the grid will for right on there summe me rims only
  13. idget
    Did you lose half the keys on your keyboard? wtf
    BroCo likes this.
  14. joe bretto
    joe bretto Member
    Summer rims only. Just want to bolt them right up without any mods
  15. idget
    it will be fine
  16. joe bretto
    joe bretto Member
    Lol auto correct iPhone
  17. joe bretto
    joe bretto Member
    Thanks!
  18. joe bretto
    joe bretto Member
    The only ones I can find (ebay) are 17x9 I take these are to big for stock anywhere else to buy these rims?
  19. Moleness
    Wheeldude.com
    LawnMaster and ofspunk7 like this.
  20. ofspunk7
    This is where i got my grids. Good people to work with.
  21. readymix
    Yeah, 8" wide with an offset in the 45-53 range should be fine using stock sti tire sizes.
  22. joe bretto
    joe bretto Member
    To fit 17x9 what would I have to do?
  23. readymix
    You said you wanted to use STi tires in a post earlier, you wont want to use those on a 17x9. Still, to run 17x9 on a wagon, you will absolutely need to roll the rear fenders. You wont be able to run the stock STi tires on them. You would probably want to run a 245-40-17 on those as that will give the closest correct circumference for that width. Anything you get from Wheeldude/Rota will likely have the correct offset for your vehicle, so I wouldn't worry too much about that.
  24. joe bretto
    joe bretto Member
    i want to run the rota grid in 17x9 with whatever tires words my 04 is a sedan still have to have the fenders rolled? or will the just fit on
  25. readymix
    I am going to assume that my translation is correct and say that you will still likely have to roll fenders. Do you have any suspension modifications? If you are lowered at all you will definitely need to roll fenders. You can't just say "with whatever tires" because that is where the spacing comes into question for the fenders, and the offset, and the ride height. There isn't just some magic combination of wheels and cars that just works. The Impreza line of vehicles in 2004 all base their tires off the STi 17x7.5 BBS + 225-45-17 tire. A 17x8 wont change things much. But adding another inch to that is adding 1.5 inches of increased width. That will required wider tires than stock, and if you are lowered at all, you will need to roll the fenders because the fenders were not made to handle that width stock. There just isn't space.
  26. Woot
    Woot Well-Known Member
    What offset are your grids?
  27. ofspunk7
    18x9.5 Rota Grid - Gold (5x100/e38/56.1)
    So 38
    EDIT: I ended up getting the 73.1 Hubs with the 56.1 Hub rings. Wheeldude stopped selling the 56.1 Subi specific Grids in that size.
  28. that-dude
    that-dude Well-Known Member
    question? i got some rota tarmac in 18x8. it currently have some 225/40/18 tires on them. i want something meatier. something like 235/45 or even 245/45. oh im planning to lower the car by 1.5 this springs. let me know if those fitment will work with or with out any fender rolling. thanks
  29. JasonoJordan
    what vehicle is this on...
  30. pillboy
    Patience is strong in this thread.
    Ctracey218 likes this.
  31. thakrazymule
    thakrazymule Active Member
    Careful JJ. I asked the same question the other day in a for sale and got yelled at because I didn't guess by the persons avatar pic. Lol :D
  32. readymix
    Careful. In this instance, the person he is asking doesn't have a pic of his car as his avatar. And in this instance you can't search Google for "what car does the user that-dude, on MNSubaru, drive" and get an answer. You could have, however, looked at the avatar of the person in that for sale thread, saw that he had an 04-05 WRX sedan, and then went on Google to find the exact specifications for the HKS HiPower catback exhaust for that model, and also found videos of people with that exhaust, revving their car and driving around.
    And if you feel like poking mods for laughs, you picked the wrong one.
  33. thakrazymule
    Haha. I wasn't actually refering to you about me looking up what the exhaust was. That i should have looked up. I was refering to what someone else said after you suggested i do a google search.
  34. Stuck686
    Stuck686 Well-Known Member
  35. that-dude
    It's a 02 wrx sedan. Sorry was posting while at work.
  36. derp
    The status quo called, it wants its Rotas back.
