Does anybody know where I can buy paint for PSM? I've found TouchUp paint but I'm looking for spray paint(rattle can). Thanks , Josh
Yep, Welle will put any paint color in a rattle can if you give them the paint code. GrimmSpeed has PSM on the shelf.
You can buy clear coat and hardener from napa for under $15, bring it to welle and they can mix it and put it in a rattle can. Otherwise, buy a cheap 1.4 mini paint gun (Matco sells a decent sata knockoff for around $70) and a 150 psi or higher air compressor. Might be a little much of an investment up front but if you use it on any major panels it'll be worth it because the paint/clear will lay a lot nicer than a can.
