Hey everyone I am looking for a place to take my car to get some work done to it. After spending time online and figuring out that the bolts or gasket on the back side of my turbo are leaking coolant and they need to be replace with the gasket and washers. So I guess I am looking for a place to buy a DP to finish my turbo back exhaust and install and tune for me. scene it will just save time and money in the long run just to do it all once why not.I live in La Crosse Wis and any info will help out and thanks for the input.
Another car "shop" is MAP. However depending on how much time you have and if you want to save money.... maybe Dan (Turbo Turtle) or Dave's Garage can help you fix or install what you need done. Then talk to one of the local tuners, tell them when you think your car will be fixed and try and set up a tune that day too (or next day). Might save you a few bucks, and maybe you can learn/help fix your car in the process.
correction I did mean to say oil instead of coolant and bolts and gasket need to be replace due to wear and tear they give out and leak. I want to put on my exhaust while they have to replace the bolts and gasket to save time in the long run
the oil feed line. gotcha. All of the suggestions made so far are good ones. They are all more than capable of taking care of the things you want done.
