Winter Wheels On Yet?
Discussion in 'General Subaru Discussion' started by Vinnie, Oct 23, 2013.
  1. LawnMaster
    LawnMaster Well-Known Member
    Winter wheels/tires went on today. I've always driven on Blizzaks. I forgot just how squishy and squirmy the Blizzaks are; but I'm okay with that knowing the car is better prepared to handle whatever winter precipitation it might be faced with. I'll again have the opportunity to experience the harsh lake effect snow conditions several times while visiting northern Minnesota and Wisconsin, and the UP of Michigan.
    ...let it snow, let it snow, let it snow!! :)
    Subie Lovers likes this.
  2. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Blizzaks would be great if they retained their initial characteristics for more than a season and some change. I lean more towards winter performance tires now. They're adequate for severe conditions and very competent for the stuff metro area folks are mostly likely to see the vast majority of the time. Much less squishy.
    UP is a special place though. I'd be happier if I had blizzaks there...
  3. derp
    Dunlop wintersport m# for performance winter. Had them on my audi. Amazing.
  4. Grayguy
    Grayguy Well-Known Member
    I will rock my summer setup through the first few snow falls like usual, then back to my Nokians for their 6-7th season of awesome
  5. WLGT
    WLGT Well-Known Member
    2-4 inches tuesday night they say :)
    tehfuzz likes this.
  6. Schikane
    Schikane Active Member
    Switched out my summer rubber with WS70's and Momo Winter rims last weekend.
    Spent about an hour or so cleaning and waxing them before throwing them on the car. All ready for the coming of an Indian summer, lolz.
  7. Vinnie
    Vinnie Well-Known Member
    Do you guys store your summer tires inside or just leave them in the garage for the winter?
  8. idget
    Vinnie and boone1186 like this.
  9. boone1186
    boone1186 Active Member
    I read an article that suggests you clean them and place them in a plastic bag, example is a black contractor bag or something. Then force as much air out and tape up the bag. Store them in a climate controlled area such as your basement so they will see less temperature fluctuation. This is how I'm going to go about it this year.
    Vinnie and SCIFIDELITY like this.
  10. SCIFIDELITY
    SCIFIDELITY Well-Known Member
    ^This is good advice. They can dry (and millions of tiny cracks that lead to tire failure) rot in a cold garage.
  11. MNGman
    MNGman Well-Known Member
    I don't bag mine, but they do get cleaned and stored in the basement. I don't think you will notice much of a difference with your dd summer tires by not keeping them in bags, but you definitely want to keep them from freezing. Most say the bane of high performance tires is heat cycling. The more heat cycles, the less the rubber in the tire works. Freezing them is a big no-no. That's why most of us have already switched to winter tires, once the temps start dropping below freezing, into the basement they go.
    Most performance winter tires have dual compounds. The "sticky" rubber is available from new to about 6-7/32". They then become closer to an all season tirefor the rest of their life. I believe these also have multiple wear bars to check verify where you are in the life of the tire. Be aware if buying used performance snow tires, check the tread depth and make sure there is enough to justify the cost.
    boone1186 likes this.
  12. b00stWrx11
    b00stWrx11 Member
    ill be throwing them on tomorrow morning! Right before it comes down. hehe
  13. Schikane
    Huh, I've always kept both summer and winter tires bagged and stored in the garage. I have never noticed any cracking of the rubber.
    When I switch them out I just clean and wax the rims, throw a bag around each tire, and stack them in the corner. I'm even kicking around the idea of buying a tire rack next spring so I can get them off the garage floor.
  14. dang0
    dang0 Well-Known Member
    The nerd that I am, I recently emailed Dunlop customer service what the proper way to store the stock 2013 wrx tires/wheels (Dunlop SP Sport 01 or whatever). This is the reply:
    Thanks for contacting our website. We recommend storing summer tires at
    temperatures above 40'.
    The best place to store tires is in a clean, dry, sunless area away from
    strong air currents. Even though the rubber used to make tires is
    formulated to resist effects of sunlight, ozone and water, the life of a
    tire can be extended if exposure of these elements is minimized during
    storage.
    Stack tires flat so that the bottom tire will maintain its shape
    Wrap each tire with an opaque polyethylene covering to minimize the
    effects of oxygen and ozone. Most Goodyear retailers have storage bags
    made specifically for this purpose
    If tires are being stored outdoors, they should be raised off the
    storage surface
    If tires are being stored while mounted on rims, they should be inflated
    to 10 psi
    If they are put in storage during warm weather, the initial inflation
    pressure should be about 15 psi to offset the pressure drop during cold
    weather months
    How Not To Store Your Tires
    Don't store tires in an area that is wet, oily or greasy
    Don't store tires where they are subject to direct sunlight or extreme
    temperatures
    Don't store tires near electric motors or other ozone-generating sources
    Don't store tires on black asphalt or other heat-absorbent surfaces
    Don't store tires on or adjacent to highly reflective surfaces such as
    sand or snow
    Barbara
    Consumer Relations
    Schikane likes this.
  15. Schikane
    Interesting. I did not know about bleeding air out of the tires before storing them. As far as temps go, I will have to watch the temp gauge in the garage to see how cold it gets and maybe bring them in if it gets too low. Its usually much warmer than the outside temps. Thanks.
  16. kongzilla
    kongzilla Well-Known Member
    Always stored my summers in the garage in the discount tire bags on a tire rack. No problems so far.
  17. xodad2
    xodad2 Well-Known Member
    If I have all season tires do I need to stores them the same way as summer tires? Or should I just clean and bag them? I have no room in my house for them so they will stay in the garage.
  18. SCIFIDELITY
    bagging isn't the most important part, but i'm sure you have or could some garbage bags you could put them in. And the compound your tires are made of is likely less sensitive to temp changes since they are all seasons. My recommendation is to get them off the ground somehow (shelf, palate, etc).
    xodad2 likes this.
  19. WRX1
    Been storing them like that for the last 6 years I have been in this house. I always wear them out before I ever notice any cracking or anything like that.
    Weird0, SCIFIDELITY and b00stWrx11 like this.
  20. b00stWrx11
    b00stWrx11 Member
    So i just got my blizzak ws70 on today, as expected they are pretty squishy. Ive been reading online and people have been increasing the psi a bit(35-38psi) . What do you guys have you tires psi set at and have you noticed any difference in terms of tire wear?
  21. Stuck686
    Stuck686 Well-Known Member
    michelin xice is back on. not too squirmy, i kind of like the smoother ride lol
  22. DIRTY D
    DIRTY D Well-Known Member
    Discount tire for lunch to put the winter bites on. *************those guys rock*************bring it on
    tehfuzz likes this.
  23. MidnightImpreza
    Putting the winters on tomorrow after the first snow fall, LOL! I've needed new winters for a while and just went to Discount Tire last night to buy some and I'll be picking them up tomorrow. The place was as busy as a bee hive. I've always kept my summers laid flat, stacked, wrapped, and in the garage with no issues. No room in my townhome for indoor storage.
  24. Schikane
    I have mine set at 35-36 psi and they are still a little squishy. They really don't shine on dry pavement but as the temp drops and we get some snow pack the tires handle very well. This was my experience with them last year.
    I also think it has to do with you transitioning from street to snows, you are so used to the firm sidewall from your summers that no matter what you do the winter tires will feel squishy.
    b00stWrx11 likes this.
  25. AspitFire
    Just threw mine on the forester tonight
  26. Weird0
    Weird0 Well-Known Member
    I also installed mines tonight. It was really last minute @ 6 when the forecast claimed the snow fall was going to start.
  27. Subie Lovers
    Only problem I have with uneven wear or compromised handling is when there is no snow ;)
  28. derp
    Lol nice sled
  29. STiCH
    STiCH Well-Known Member
    Slapped my winter setup on the day before. Expect to see me rolling with them Blazin Pink wheels.
  30. derp
    barf.
  31. Tash
    Tash Well-Known Member
    Says the anal probe driver
  32. derp
    i'll come anal probe you
  33. Tash
    Not if I get to you first
    derp likes this.
  34. derp
    :swoon:
