WRX MT/AT Ecu?
Discussion in 'Modifications And Maintenance' started by PimPreza_WRX, Aug 26, 2009.
  1. PimPreza_WRX
    So I have read that both MT/AT WRX ECUs are the same. Is that true?
  2. PimPreza_WRX
    Also i have read that 02-05 ECU's are all interchangeable
  3. Nuke
    the 02 wrx ecu is both AT & MT
    03-05 are either AT or MT, BUT can be flashed over to AT or MT.
    As far as swapping ecus, I know 02's can work on 03's and vice versa (you can even flash an 02 to an 03 and 03 to an 02), but I'm not sure about the 04-05 (I'm assuming they can)
  4. PimPreza_WRX
    Thanks for the info Nuke. This I really need to know.
  5. Dynapar
    IIRC there is 1 pin on the 02/03 WRX ECUs which tells the ecu if it is a auto or manual. you can change this over by completing/disconnecting the circuit to this pin. I forget which one it is, but it is a neat system.
