WRX redo project
Discussion in 'Modifications And Maintenance' started by ChristianO, Nov 16, 2011.
  1. ChristianO
    ChristianO Member
    I have a wrx with 100k on it and im looking to just swap out all the wear products, bushings, bearings, links etc.. to keep its drive nice, any recommendations.
  2. BroCo
    BroCo Well-Known Member
    100k, just do the timing belt. The motor should have a lot more left in it, depending on the mods.
  3. chris02rex
    chris02rex Well-Known Member
    I wouldn't replace anything until its worn out. Unless you wanted to upgrade things like sway bars or bushings.
  4. ChristianO
    ChristianO Member
    yea i was looking to replace the bushings, sway bar, lateral links, end links
