WTB replacement clutch for my 2006 WRX
Discussion in 'Want To Buy : Cars/Parts' started by pksublime, Jul 14, 2017.
  1. pksublime
    pksublime Well-Known Member
    pretty darn sure it's crapping out on me...so yeah i need a new one
  2. Krazylegz1485
    Buy an Exedy replacement kit online?
  3. tangledupinblu
    Or at the dealership. I think that they are only a couple hundred dollar bucks.
    Ntxhuav_Khang likes this.
  4. MrBlue
    MrBlue Well-Known Member
    ^^^ Dollar bucks....HA!
  5. pksublime
    so how hard is this to perform?
  6. tangledupinblu
    Much more challenging than an oil change.:)
  7. Krazylegz1485
    What kind of experience do you have under the hood? The clutch replacement itself is pretty "easy", it's just getting to it that's the problem. In my opinion, it's not really that difficult (skill wise), it's just a bunch of labor (I pull the motor).
  8. choukhang
    choukhang Well-Known Member
    I got a used one from 07 wrx was taken out at 30k give me text if interested 612_250_2139 Chou thanks
  9. pksublime
    well if they only last 55k, a 30k is over half it's life gone
  10. pksublime
    my mechanic is quoting like $1400 for parts and labor - sheesh, i figured these things would last longer than that for that much
  11. Krazylegz1485
    I did my clutch at somewhere between 140-150k on my car. Judging by how hard it was to split the motor and tranny, I can only assume it was the original clutch. I've got 190+ on it now and it's showing no signs of slowing. I wouldn't be expecting to replace one every 50k or so unless you're planning to beat on it daily.
  12. idget
    Clutch life is hard to quantify via miles. Even duty cycles. Figure however long your oem one has lasted is about how long the replacement one will last.
    As far as cost. Figure $600+- on labor at shop rate. You can figure out the parts cost on your own (clutch, throw-out bearing, pressure plate, pilot bearing, and flywheel - resurfaced or new).
    Eazy_E_Rich likes this.
  13. pksublime
    does age itself ever factor in to this? low miles but over 10 years...
  14. Skinnman
    Skinnman Member
    Still looking for a clutch? if so I have one, used but in good condition.
    612-889-4610
  15. pksublime
    Clutch has been replaced - thanks for the advice and help everyone
