xluben's Silver 2002 Bugeye WRX Sedan
Discussion in 'Photo & Video Gallery' started by xluben, Jul 15, 2013.
  1. derp
    Jesus Christ. That is a fast ****ing car. Please be careful when doing that **** on public roads.
    Terry Ammerman and Ryan FailRad like this.
  2. Ryan FailRad
    Took this screen shot of my phone when I paused it, looks pretty cool, figured I'd share it with you Ben.
    Aluminati and Peder like this.
  3. xluben
    Sold the RPF1 setup. I'm back onto the stock wheels for now.
    Terry Ammerman likes this.
  4. Terry Ammerman
    For some odd reason, I think it looks better this way.
  5. xluben
    I think it looks way better. I just wish the wheels were a little wider.
  6. Zombie
    Zombie Well-Known Member
    Ryan FailRad likes this.
  7. derp
    Blammo
  8. xluben
  9. xluben
    My new street tires arrived today. They are 26x9.5R15 Mickey Thompson ET Street Radials. The new wheels won't be here until next week.
  10. retreif
    slightly less ribs and grooves then those Federals...
  11. xluben
    Yeah, and the treadwear rating is 200 lower. Haha.
  12. Nhibbs
    Nhibbs Well-Known Member
    Are those considered cheater slicks?
  13. xluben
    Maybe my definitions are wrong on this, but I'd consider these a drag radial. And they're one of the more "street-friendly" drag radials (Hoosier drag radials are softer and just have two straight grooves in them instead of an actual tread pattern).
    I think of a cheater slick as a bias ply slick that has a groove in it to meet DOT regulations. Those are going to be far softer compound and sidewall (like the Mickey Thompson ET Street (not ET Street Radial) or the Hoosier Quick Time Pro).
    I also did some glamour shots with the slicks that I have. These are true bias ply slicks with no tread at all. Track only use.
  14. TMF
    Glamorous indeed.
    When are you going to cage it? Isn't a cage required at some tracks for anything under 10 seconds?
  15. xluben
    NHRA:
    • Roll bar is needed at 11.49
    • Roll cage is needed at 10.99 or 135mph
    • Parachute is needed at 150mph
  16. Ryan FailRad
    So when does it get caged?
  17. xluben
    Probably never. Possibly someday.
    tangledupinblu and Ryan FailRad like this.
  18. Ryan FailRad
    Well correct me if I'm wrong, but you've kind of just screwed yourself then haven't you?
  19. xluben
    It's a street car. If it only gets a pass or two at the track before getting booted then that's just how it is.
    toyotanos and Ryan FailRad like this.
  20. TMF
    What, you don't want to wear your helmet and harness on the way to the grocery store? :alien:
  21. xluben
    Too hard to get kids out of the back. LOL.
    skubi1 likes this.
  22. skubi1
    skubi1 Well-Known Member
    Be like this ding a ling and mount a bottle at your child's feet. Picture 371.jpg
  23. tangledupinblu
    I give my kid the bottle.
  24. Scott
    Scott Well-Known Member
    That bottle could keep them kids in a great mood.
    tangledupinblu and skubi1 like this.
  25. xluben
    Quick shot of mine from last night. Still need to paint those horns...
    EricS and JuStaWRX like this.
  26. xluben
    Edited another shot from the other night.
    I'm hoping to get the new wheel/tire setup on today.
  27. xluben
    The new set of wheels arrived today. They are going to be used with the Mickey Thompson Street Radials. They are 15x7" Rota Slipstreams in Gun Metallic.
    Quick shot of them mounted:
  28. tangledupinblu
    Meaty!
    tehfuzz likes this.
  29. Scott
    I like the color of the rims. When you get tired of them next week let me know.
    Ryan FailRad and my97gt like this.
  30. xluben
    I have two sets of them now. Planning to keep them around for a while I hope.
    More shots of the new wheels and tires mounted up.
    On the car:
    JuStaWRX, Scott, TMF and 1 other person like this.
  31. TMF
    Looking good! It looks like they are quite a bit taller than stock, so you should have a [longer] gearing advantage, right?
  32. xluben
    Yep, they are 26" tall. My RPF1 setup was only 25" tall so these should trap higher. I still don't think I'll be finishing in 4th, but at least I won't have to worry about redline in 5th. Haha.
  33. MNGman
    MNGman Well-Known Member
    So, this will be a total newb question.
    Is the 15" tire with the huge sidewall to give you the opportunity to run a lower tire pressure and get a maximum contact patch?
  34. xluben
    Not really for contact patch. More for sidewall wrinkle. A soft sidewall helps the car hook on the launch. Stiff sidewalls are much more likely to spin.
    Neither of these tires are ones that you would want to try to turn quickly with. They are not made for cornering. They're just for straightline grip.
  35. MNGman
    That was my next guess after I thought about it a bit. Are you sure you don't want to give them a turn on a road course? You could go with really heavy springs and let the tires do all the suspension work.
  36. belalegosi
    belalegosi Well-Known Member
    You run the risk of breaking the bead seal on the tire.
  37. TMF
    Another noob question...how are you releasing the clutch on launch? Just a quick release? I'm assuming you're trying to avoid too much slippage and probably aren't side stepping it either...
  38. xluben
    Yeah, that's the risk if you push them too hard. My car has stock suspension and no sway bars so it's not going to be very good for road course anyways. Maybe I'll do the parade lap. Haha.
    Yeah, somewhere in between those. My single disc clutch doesn't allow for a lot of slip so I usually just find the friction point and then quick let it out after that.
    Typically clutch cars can do better with full slicks (instead of drag radials) because the extra soft sidewall is even more forgiving on the launch. Auto cars have been doing some crazy good times with drag radials lately.
  39. xluben
    Drove it to work today. Camera phone shots from in the parking lot. Rubs in the rear. Needs to be rolled more...
    Ryan FailRad and tangledupinblu like this.
  40. xluben
    Some better photos from in the daylight.
  41. tangledupinblu
    Instead of lowering the suspension, just get big tires to fill the fender gaps! Vary niiice!
    Nhibbs and Ryan FailRad like this.
  42. xluben
    Event: 1/4 Mile Testing
    Ambient Temp: ~70°F
    Elevation: ~1,200ft
    Weather: Sunny and Clear
    Tires: 26x8.5R15 Hoosier Bias Ply Slicks on 15x7" +35 Rota Slipstream Wheels
    Car: 2002 WRX Sedan
    Tuner: Nuke @ NF Performance
    Transmission: 2012 STI 6 Speed
    1/4 Mile ET: 9.94s
    1/4 Mile Trap: 139.4mph
    60': 1.49s
    Target Boost: 35psi
    Target AFR: 11's
    Fuel: E85
    9.9s @ 139mph @ 35psi on E85
    Full Build Thread:
    http://forums.nasioc.com/forums/showthread.php?t=2528768
    Engine:
    • OEM 2012 STI 2.5L Case
    • OEM 2012 STI Heads
    • OEM STI Nitrided Crank
    • OEM STI 11mm Oil Pump
    • OEM STI Gasket Set
    • CP 99.75mm 8.2:1 Pistons
    • Manley Turbo Tuff I Beam Rods
    • ACL Rod and Main Bearings
    • ARP Head Studs
    • GSC S1 Camshafts
    • GSC Beehive Springs w/Retainers
    • GSC Valve Seals
    • Torque Solution Motor Mounts
    Intake/Exhaust/Fuel:
    • Precision 6266 Turbo
    • KillerB EL Header
    • Fobia Fab Modified for FogLight Mount
    • Fobia Fab Fender Exhaust Dump
    • Fobia Fab Oil Sump
    • TurboWerx Exa Pump Mini Oil Scavenge Pump
    • Custom AN Oil Return Lines/Fittings
    • Treadstone FMIC
    • TurboSmart 40mm EWG
    • TurboSmart Race Port BOV
    • TurboSmart FPR 1200
    • Electronic Boost Controller
    • 04 STI Fuel Pump Hanger
    • Walbro 465 Fuel Pump
    • Boost A Pump
    • ID2000cc Injectors
    • IAG Fuel Rails and Lines
    • Treadstone 4" Velocity Stack
    Drivetrain/Transmission
    • OEM 2012 STI 6MT
    • OEM 2004 STI Driveshaft
    • OEM STI R180 Rear Diff
    • OEM 2004 STI Front Axles
    • DSS 800HP Rear Axles
    • Anarchy Motive Shift Knob
    • Kartboy Short Shifter
    • Kartboy Front Shifter Bushings
    • Karboy Rear Shifter Bushings
    • Torque Solution Tranny Mount
    • Torque Solution Pitch Stop Mount
    • ACT HD Pressure Plate
    • ACT 4 Puck Unsprung Disk
    Suspension/Wheels:
    • 15x7" +35 Rota Slipstream Wheels
    • 26x8.5R15 Hoosier Bias Ply Slicks
    • 02 WRX Struts
    • Eibach Pro Kit Springs
    Interior/Electronics:
    • MapDCCD Differential Controller
    • MapDCCD Wheel Speed Signal Processor
    • ProSport EVO Boost Gauge
    • ProSport EVO Oil Pressure Gauge
    • AEM Wideband O2 Gauge
    • Odyssey Slim Battery
    Exterior:
    • Seibon CF RS-Style Flat Hood
    • OEM Fog Light Covers
    • Impreza Wingless Trunk
    Drove the car 2 hours each way to the track and back (on Mickey Thompson ET Street Radials w/Hoosiers in the backseat).
    tonyv and JuStaWRX like this.
  43. JuStaWRX
    AWESOME! Congrats on 9s!
  44. Ryan FailRad
    Oem fog light cover*
    Ps, when does the next turbo go in? You've got to be bored of this one by now...
  45. xluben
    I won't switch until I feel I've maxed this one out.
