2011 Impreza tail light painter
Discussion in 'Modifications And Maintenance' started by GNUOJOUNG, Mar 21, 2012.
  1. GNUOJOUNG
    GNUOJOUNG Well-Known Member
    Hey guys,
    Anyone know of a good shop that could paint my tails red with the turn and revers clear?
    A new place in Brooklyn park, VIP Motorsports, dunno if they are any good, charging $200 to remove old paint and apply new paint. (yes I painted them myself but didn't apply enough clear so they have started to fade...)
    Thanks
  2. ryjacobs
    ryjacobs Well-Known Member
    Why not strip the paint and then just use one of the vinyl kits?
  3. GNUOJOUNG
    I just like the painted tails better. don't ask why, ha
  4. ryjacobs
    Fair enough!
  5. GNUOJOUNG
    any reputable custom paint shops in Hennepin county?
  6. ofspunk7
    I would suggest having a professional do it. I know you don't think that you like vinyl... but have you checked out the 08+ hatches that have vinyl done by Flawless Front Ends? A good vinyl job will look better than paint, IMO.
    Faded Red Tails look like crap.
    http://mnsubaru.com/threads/window-tint.28588/
    BroCo likes this.
  7. GNUOJOUNG
    i'll give them a call, see what kind of deal we can work out. thanx for the suggestion. i still need to remove the paint, been using DOT 3 brake fluid.
  8. GNUOJOUNG
    know of any paint thinners that are safe on plastic?
  9. issues
    issues Well-Known Member
    gel strip( its orange and smells like oranges) at homedepot I believe is I wouldn't use brake fluid.
  10. SubieFinest
    SubieFinest Member
    i would suggest you get the pre-cut red film to cover the lights or go to Chris Welckle to do the layovers instead of painting the lights, you never know when you want the stock look on it again.
  11. tangledupinblu
    I agree with all of the above statements referring to Flawless Front Ends and vinyl overlays. If you have any idea as to how expensive your tail lights are, you'll go with vinyl.;)
    BroCo, SubieFinest and ofspunk7 like this.
  12. GNUOJOUNG
    I'm going to give that Citristrip a try.
  13. GNUOJOUNG
    Citristrip worked great on the lens , but make sure you don't get any on the housing.
    I finished stripping the paint, and I have dropped them off with VIP Motorsports in Brooklyn Park.
    I hope he does a good job with the paint.
    I'll post pics once he's done with them.
  14. GNUOJOUNG
    Citristrip left white haze on lens, but the brake fluid cleaned that up with some good rubbing. the brake fluid works on the lense and housing without damage, but takes a LONG time.
  15. GNUOJOUNG
    yeah....VIP Motorsports in Brooklyn Park "Building The Best And Fixing The Rest"...yeah right, they took OVER A WEEK to paint them. all he needed to do was prep surface, mask it off then paint it with candy red and clear. what did I get?
    1. I got a messy masking, (I did a near perfect job and I'm not even professional)
    2. Paint color wasn't even what I requested. I told them to use candy red so that it would be translucent red like 99% OEM cars are, but instead they painted it with a base red with ZERO transparency
    3. there was red overspray on the housings and hardened chunks of clear coat on the housing. (proves they didn't even cover the housing when they painted it)
    4. too much paint was used, enough for it to run and create droplets
    5. took them over a week to make this mess.
    6. service is sub par, told them to give me a call when they masked it off so I could take a look at it before they painted it and they didn't.
    The people aren't bad, but they don't know what they are doing. They just opened not too long ago, maybe with experience they will get better, but right now I would avoid VIP Motorsports.
  16. GNUOJOUNG
    I'm having them strip the paint they put on and clear coat it and I'm going to buy overlays and have our buddy down at Flawless Front Ends install them.
  17. SubieFinest
    SubieFinest Member
    great idea! Flawless Front End put overlays on mine too.
  18. Starkall
    Starkall Active Member
    Does flawless make the overlay and install them for $80
  19. SubieFinest
    SubieFinest Member
    he have the overlays, not sure if he makes them or not. he just install them and cut to fit the lights for $80. took about 2hrs on mine, installing was the easy part, drying will need patients.
  20. Starkall
    $80 seems kinda steep but how do I contact this guy. I hate my clear tails. I want them all red.
  21. ofspunk7
    Vendor section
  22. xluben
    Pre cut vinyl is $60 for our cars, and is very difficult to install.
  23. SubieFinest
    SubieFinest Member
    i got a picture of all red before the guy cut the reverse part out. gimme a sec.
  24. Starkall
  25. tangledupinblu
    :rolleyes:
    ^What Ben said! Wait till you see how much work it is for him to cover them with all of those damn contours. It's well worth $40/light!
  26. ShortytheFirefighter
    Let me get this straight...
    You're ok with paying a shop 200 bucks to paint (and ultimately screw up) your lights, but suddenly 80 bucks is steep for a service that several members on here have recommended and have stated looks better than a set of painted tails?
    Just wanted to make sure the painkillers I'm on haven't screwed with my higher level thinking functions too much.
    For what it's worth, Chris did my '11 tails (and most of the remaining surfaces on my car) and he does great work. I would recommend him 10 times out of 10. Solid guy and great workmanship. I can't say enough good things about him.
  27. Goalie
    Goalie MNSubaru Goaltender
    Yep Chris provides great service.
  28. tangledupinblu
    This! I saw Brian's 2011 DubRX last week and damn near the whole car was wrapped with clear bra...could hardly tell tho! Good job protecting your investment brotha. Your pain meds have not screwed with your higher level thinking functions...btw.;)
  29. subie senior
    subie senior Active Member
    did the vinyl on my STI quite awhile back and they still look great. need a lot of patience or some one that has experience with vinyl graphics to install them. it ain't easy.
