Engine knock when cold??
Discussion in 'Modifications And Maintenance' started by joe bretto, Nov 20, 2012.
  1. joe bretto
    joe bretto Member
    hello i noticed this morning when i started my car i had a knock sound coming from the engine that goes away when the car warms up. Anyone have any idea's?
  2. idget
    post a video or be more descriptive. Could be anything from a heat shield to piston slap to rod knock.
  3. joe bretto
    joe bretto Member
    ok ill post a vidro tomorrow moring if its cold enough only does it when its 30 or lower
  4. Back Road Runner
    Normal.
    I'm not kidding.
  5. joe bretto
    joe bretto Member
    Thank you!
  6. joe bretto
    joe bretto Member
    I'm trying to upload a video but won't let me. The ticking noise seems to always be there. Can only hear it with radio and heat off!?
  7. idget
    Ummm... so its a ticking or knocking sound? Upload to youtube or photobucket or something and link to it.
  8. KSAL
    KSAL Well-Known Member
    Ticking might mean that you need a valve job, a knocking could be piston slap (common for subaru's and minor cases you can't hear it after it warms up) Any car info....?? Year/Model/Miles?? History?? MOds?
  9. joe bretto
    joe bretto Member
    2004 wrx exhaust but stock other than that
  10. joe bretto
    joe bretto Member
  11. joe bretto
    joe bretto Member
    this is what it sounds like when its cold not as loud when hot?
  12. joe bretto
    joe bretto Member
    Did the video work?
  13. bikerboy
    bikerboy Subie GOD
    It is not loud enough. Try putting the phone on the strut top or something.
  14. joe bretto
    joe bretto Member
    Ok ill try later
  15. AWDimprezaL
    If it goes away when warm its piston slap. Its a pretty common subaru quirk.
  16. joe bretto
    joe bretto Member
    Ya the loundness goes away but I hear a ticking always when my radio and air is off.
  17. Jerf
    Jerf Well-Known Member
    Every single Subaru I have owned (3) have all had this, including the tick, my 2.5i had the most tick, once it became louder I would change my oil and it would quiet down. It's Subaru love slapping :)
  18. idget
    The tick is likely valves. Post a better video or swing by a meet.
    The valve clearances tighten up over time (not good if they go out of spec) and get quieter (most people consider this good lol). So in short, get to know the noise(s) and learn to love them... or burn it to the ground.
  19. AWDimprezaL
    In theory they should get louder with time, the valve is slamming shut/pounding the seat. This is why you get cracked/burned valves on 2.0L wrxs. Adjust your valves at 105K, but the earlier the better.
  20. joe bretto
    joe bretto Member
    Where and when do people meet?
  21. 02_Rexxxy
    02_Rexxxy Active Member
    Welcome to the world of Subaru, switching from DSMs (3 of those pieces of...) to the WRX I thought my car was broken so many different times from all the weird noises/shakes I didn't have with my DSMs that I just learned to live with it...Changed oil with Schaffers 5w-30 synthetic and starting is a lot nicer from what it was when I first bought the car. Are you due for an oil change and are you running synthetic or what weight oil? That or like AWDimprezaL said about the valve lashing. No big deal. Just gotta get used to it in the cold.
  22. joe bretto
    joe bretto Member
    Ya I just changed it I use rotela t6 thanks for the info.
  23. idget
    There's a meet tonight. There's also an entire Events sub forum.
  24. joe bretto
    joe bretto Member
  25. joe bretto
    joe bretto Member
    not the best bu this is how it ticks all the time this time the car is warm
  26. svxninja
    svxninja Well-Known Member
    What was reading on your coolant temp gauge when you took this
  27. joe bretto
    joe bretto Member
    Normal temp?
  28. tangledupinblu
    When was the last oil change? Check the dipstick and let us know what the reading on it is.
  29. joe bretto
    joe bretto Member
    The reading is at the full mark.
  30. tangledupinblu
    Well then i suggest heading over to the Tuesday night meet at Old Chicago(Harmar) on Snelling and B2 tonight around 7pm if you can. I'm sure that someone could take a look at it there.
    I haven't really heard anything abnormal from the videos, but they aren't the best quality tho.
  31. joe bretto
    joe bretto Member
    I know sorry the crappy video (iPhone) ill see if u can make it.
  32. tangledupinblu
    Don't be sorry, you didn't make the crappy phones! lol. It would just be easier to diagnos in person. Just don't be too suprised if everyone says that it sounds "normal". I always get spooked when the winter starts and all of the noises start.(engine ticking, belts squeeling, etc.)
  33. joe bretto
    joe bretto Member
    Ya same here. Does everyone meet every Tuesday?
  34. tangledupinblu
