Forester SJ XT Enthusiasts
Discussion in 'General Subaru Discussion' started by Clem, Oct 24, 2016.
  1. JuStaWRX
    I've had no issues with it yet on the '14 FXT, however it did happen once on my 04 WRX. The only big issue I had with the FXT was the seat upholstery cracking (photos in my thread). SoA replaced it on a "goodwill" contingency, and haven't had issue with it since.
  2. Clem
    Clem Active Member
    Standing water?!?! Geez!! I'm also glad they replaced the tail light, no questions asked.
  3. Clem
    Clem Active Member
    Gearing up for my first "long" distance journey in the Forester. Slapped on some Blizzak DM-V2s (225/55 18) and cargo box. Ready for about 3.5-4k miles in the next 3 weeks. Lots of pictures to follow.
    Decided to run my Work Seeker CXs for another season. I would love to swap them for some Work Emotion D9Rs in 19x9.5 +38, but the finacials are telling me to wait. Going to have my Summer setup powder-coated matte black and use the OEM tires for the summer until they are worn. Hoping 2018 I can switch my Summer setup, but we'll see.
    My Spring-time list has started:
    Isolate and fix numerous rattles within the cabin.
    Replace front Harmon Kardon speakers (still undecided, but will probably go with Polk).
    Install sound dampening in the front passenger/driver doors.
    Install 10" sub (most likely in tire well).
    Slam it!! (Spring time)
    Most likely do some fender modifications.
    Maybe some front accents lights in the bumper.
    Replace exhaust hangers and correct my skewed Nameless CBE.
  4. Cartman08
    Cartman08 Member
    09 XT owner here so hopefully you don't kick me out of your club lol, but I was wondering if anyone had a jdm "F" emblem lying around.
  5. clajiness
    clajiness Well-Known Member
    Which box did you put on your XT? Is it still the stock height? I ask because I'm interested in getting a box for mine, but my garage door is about 7' tall, and I know it'll be tight.
  6. Clem
    Clem Active Member
    I bought the box from a friend. I think its a Yakima Sport something... its pretty bulky compared to the more streamlined boxes out there. I'm lowered to about a 2 finger gap all around and when I put the box on in the garage, I realized it was too tall to make it out of the garage, so I had to take it off and back out of the garage before reinstalling it.
    I also have the Thule Crossroad Railing installed. Maybe with a lower profile setup and box you could have clearance. I haven't yet measured my
    clearance, but I need to do so before I leave.
    https://imgur.com/a/nwO8i
    clajiness likes this.
  7. Clem
    Clem Active Member
    Get outta here!!!!! I did have some, but they ended up on my home stereo speakers.
  8. Cartman08
    Cartman08 Member
    Fine - I'll start a better SH club! :) They would look better on my car then your speakers...lol
    Subtle solutions have them but for a whopping $170! There was one on eBay a couple weeks ago for $70 - should've pounced on it:(
  9. TMF
    I pulled a trailer for the first time in the FXT, and I installed the Rally Innovations rally light bar (replaced the SSD bar that I had before). The Rally Innovations bar is way more stable, and it didn't require removing the bumper for install (only the grille). There was a little be of trimming on the stock skid plate and side plastic trays, but nothing bad. I'm liking it overall, but still need to get my Hella's re-installed.
    As far as towing, the FXT did great! The empty trailer is 850lbs and I only had a couch in it, so probably under 950 lbs total.
    I'm not sure what you're planning on hauling in the cargo box, but you might want to consider one of these:
    http://www.harborfreight.com/500-lb-capacity-deluxe-cargo-carrier-66983.html
    They have them on sale occasionally for $40, and you can use a 20% off coupon, so it comes down to $32. I just picked one up this weekend at that price (the sale ended on Sunday unfortunately). When I need to carry stuff in it, I plan on using a large rubbermaid tote (for protection and easy cleaning) and strapping it down. I'm also hoping that I have enough clearance from the bumper to haul a set of tires on it (to save my interior a bit).
    JuStaWRX likes this.
  10. TMF
    Oh yea, and I went to the Audi Club's Ice Driving event on Saturday...I'll upload a video eventually. It was absolutely awesome, and they are having several more.
  11. Clem
    Clem Active Member
    I'm just going to be hauling snowboards and snowboard gear.... keep all that wet ish out of the back.
  12. Clem
    Clem Active Member
    1st leg of my road trip to Denver is complete. Traveled ~600 miles.
    According to my MFD, I was averaging 20.4 MPG, traveling 90% of the time at ~80 MPH using the adaptive cruise control. Tires were inflated to 40 PSI, one other occupant, running 91 octane (no stations along they way had 93, which I normally run) and ~150 LBS of gear and a roof box. Weather conditions were good... 50°F and slighlty windy.
    On the return trip I plan on logging actual data to figure out true MPG.
  13. TMF
    Nice! And your MPG actually makes me feel a bit better (although I wasn't worried). With snow tires, ski rack, and going about 75 MPH on the highway, I can't get more than 22-23 MPG's. I think the ski rack takes away 2-4 MPG's, esp at higher speeds.
    Also, I've found that the MFD MPG display always reads 1-2 MPG's too high compared to calculating the mileage using distance driven and gallons added. My past Subaru's have been off by the same...damn you Subaru for false MPG optimist-ism!
    In other news, I got my Hella's mounted on the new Rally Innovations bar. Next, I'm planning on adding an LED light bar on the underside of the bar. I may eventually move the Hella's underneath (although that will screw up the beam pattern) and/or remove them and/or get smaller LED pods for the top side of the bar....because right now the Hella's are blocking a fair amount of the intake for the intercooler ducting :rolleyes:
    Cotts612, Clem and JuStaWRX like this.
  14. curly2k3
    I suppose I can post here too, since I picked up a '14 FXT Touring, also in White Pearl.
    clajiness and TMF like this.
  15. tangledupinblu
    Clem likes this.
  16. Clem
    Clem Active Member
    Wheres the car porn?
  17. curly2k3
    so damn needy.
    Clem, JuStaWRX and tangledupinblu like this.
  18. TMF
    Welcome! Yet another white one...
  19. tangledupinblu
    Very nice! Does it come with a hookah holder?
  20. derp
    work seekers? gonna need pics
  21. curly2k3
    There's always a possibility
  22. JuStaWRX
    SWP 2014 Foresters are soooo dumb...SAID NO ONE EVER! Congrats on the purchase!
    I have to say too, I am extremely envious of the Touring.
  23. curly2k3
    Definitely a different place to spend time in, compared to the R53 with sport cloth seats and suspension. I'm liking it so far, hopefully I can keep it somewhat stock.
  24. idget
  25. curly2k3
  26. Clem
    Clem Active Member
    I have some photos on my DSLR I need to touch up when I get home, but she made it Taos, NM. Four passangers and snowboards... she sure did get dirty, though. Never in my life have I seen red ice and dirt built up so thick. I was rubbing hardcore ice-to-tire on the rears on the return leg.
    Brought 'er to a Pay-n-Spray and spent about 10 minutes hosing off all the ice, dirt and dust that I collected over the ~600 mile round trip from Denver to NM on back-ass, snowpacked mountain roads. I think some solid corner-balancing will be in the works come Spring time.[​IMG][​IMG][​IMG][​IMG][​IMG]
  27. TMF
    That snow looks amazing! PS, a plastic paint scrapper or wooden paint stick, or event better, a plastic paint scrapper duct tapped to a wooden paint stick work great for clearing snow/ice out of wheels and wheel wells!
    Clem likes this.
  28. Clem
    Clem Active Member
    So Adobe Lightroom isn't being very friendly, so I'll just post these in their original format.
    This one is before editing:
    After editing (This is my first attempt at editing photos.... probably a little overkill):
    The rest are non-edited photos:
    JuStaWRX, TMF and tangledupinblu like this.
  29. tangledupinblu
    Dirty gurl!!
    Clem likes this.
  30. TMF
    ^ I think foresters look better when they are dirty!
  31. clajiness
    In that case, mine is currently soooo pretty. :facepalm:
    TMF, JuStaWRX and Clem like this.
  32. Clem
    Clem Active Member
    Where can I go to have my fenders rolled? I've been to one place locally before and wasn't a fan of the pounding method. I'm also not comfortable renting a roller and attempting it myself.
  33. SkeetsWisconny
    This warm weather has me itching to start putting my exhaust plans to life but wanted to reach out to the local crew for input.
    I personally like the sound of the SPT catback best but I have yet to find an exhaust clip of one on an XT mated with a full turboback exhaust. I don't want the exhaust to be very loud when all is said and done. I was planning to do just the catback this spring to maintain warranty like most others and than finish the rest of the exhaust when i get closer to the powertrain warranty ending but now I'm considering just keeping the stock catback and replacing just the jpipe and midpipe (w/ highflow cats and tune) down the road as this will make things a bit louder but under control I'm guessing and to gain the performance and as I ultimately want most in the end.
  34. curly2k3
    I just want some sound from the exhaust, its just too quiet and docile.
  35. TMF
    It sounds daunting, but rolling the fenders yourself isn't tough. Rent the tool from Jeff the Alignment guy, and he will also likely include a heat gun. Use heat, take your time, and go slow, and it will turn out fine. I've done it on 2 cars with no issues.
    I'm guessing if you do a catted aftermarket j-pipe/midpipe/whatitisontheSJ with the SPT catback, it won't be much louder than the OEM j-pipe.
    Using the OEM midpipe with Nameless axle-backs (muffled or non) might be your best bet. Based on the videos, the Nameless axle backs aren't too loud with the stock midpipe.
    The WRX catback will definitely give you more sound, but mainly at low RPM's. It's quite audible, but I'm pretty used to it now, and it's not droney. The WRX catbcak tips does require that you trim the bumper, but the aforementioned Nameless axle-backs are an option as well, and don't require trimming.
    The WRX midpipe (no resonator) with FXT mufflers makes almost no sound difference.
  36. SkeetsWisconny
    Thanks for your feedback. So you're saying that u believe the midpipe replacement w/out a resonator won't change the sound much? If so, that is very surprising to me.
    On my old WRX setup I went with a high flow catted downpipe becuase Cobb claimed that the flow of their catted vs non-catted downpipe would not hinder performance for anything under 400whp and everyone knew non-catted dpipes were considerably louder vs catted and made whichever catback system u chose considerably louder...and smellier... and illegal. This is more than likely why I'll go with a high flow catted jpipe - to increase the flow and keep things quieter. But these are the further clarifications I seek.
  37. curly2k3
    I'm trying to get a buddy to sell off his WRX exhaust since he went full aftermarket, so that's good info. Anyone making extended hangers to reduce trimming the bumper?
  38. TMF
    I believe that it doesn't change the sound much because I compared them myself :) Here's a video...I only did a startup in the video with wrx midpipe + fxt mufflers, but there really is not an appreciable difference. Even the stock FXT midpipe with no mufflers wasn't that loud. But as soon as I went to the full wrx catback, it was much louder. I am curious what it would sound like with the FXT midpipe and WRX mufflers...maybe I'll experiment this spring.
    You'd have to hang it down pretty low...the quad tips do not fit in the existing openings at all. That said, once you trim the bumper, it doesn't look too bad - you can see what it looks like in my video.
  39. JuStaWRX
    Picked up: Grimmspeed Bro-Tie bracket/Hella Supertones/Wiring components right before Christmas, SmartTap from Diode Dynamics last week (~$50), a '16 WRX cat back last night ($125!!), a heat gun to get ready to cut the bumper today (8.99) . I think it's needless to say I am ready for some spring projects!
    I am just over 55k miles, which means warranty is up in a few thousand miles... not planning on much more, but if that changes, it can potentially start changing soon!
    Clem likes this.
  40. Clem
    Clem Active Member
    Would you be interested in offering a helping hand?
  41. curly2k3
    damn, nice score on the cheap exhaust
  42. JuStaWRX
    The itch for installation is here! I need to pick up some gaskets first, and am hoping to set a good few hours/ full day aside so I can get some test videos with the various set ups while it's all happening (stock, WRX midpipe w/Stock mufflers, WRX Midpipe with WRX mufflers... etc.) .
    Before I put mine under the knife, I'd love to see yours one more time. I have the heat gun and different cutting tools, but did you trim from both sides, or just one? My fear with this is that they will 1) Be uneven 2) Look like junk.
  43. boxerbull
    boxerbull Member
    You should check out last humans garage on YouTube. This guy does a lot of videos on his wrx and his wife's forester. In one of his videos he figures out that the tips come off the mufflers of coarse he figures that out after he installed the wrx mufflers and trimmed his wife's bumper .
  44. Clem
    Clem Active Member
    Just got the wheels back! Turned out amazing. Had them done at Adrenaline Powder Coating in White Bear Lake.
    [​IMG][​IMG]
  45. tangledupinblu
    Matte/Satin Black? They look fantastic btw!
