ocie's 2003 WRX
Discussion in 'Photo & Video Gallery' started by ocie, Nov 4, 2016.
  1. tangledupinblu
    Wise advice right thur!
    MrBlue likes this.
  2. MrBlue
    MrBlue Well-Known Member
    Ha! I learnt it at the skool of hard knox.... had to pull a bunch of stuff on the passenger side twice.
    ocie likes this.
  3. ocie
    ocie Well-Known Member
    Gotcha. I've only recently had the gas smell, but I'm sure it'll continue happening unless i actually replace stuff. Upgraded fuel rails aren't going to be necessary for me lol.
    All very appreciated advice! Should I just call up Morrie's tomorrow and ask for 4-5 feet of fuel injection hose and fuel line clamps? Not sure how much I'd actually need.
  4. Krazylegz1485
    Any Napa/O'Reilly's/Advanced/Auto Zone should have it. No need to go to a dealer (in my opinion). It's cheap enough you could easily just get a bunch and either toss whatever is left or keep it on hand for future projects.
    ocie likes this.
  5. tangledupinblu
    Just make sure that you buy some upgraded clamps. The clamps are where they fail, every time!
    ocie likes this.
  6. pillboy
    So what constitutes an upgraded clamp? Obviously the OEM ones do not do the job (unless they have redesigned it or make some other change in material or something), and I don't think the old style worm gear clamps are an acceptable alternative for any and all underhood applications anymore.
  7. ocie
  8. tangledupinblu
    pillboy likes this.
  9. idget
    The worm gear clamps are fine as long as the slotted sections don't contact/dig into the hose. Personally, I'd be more concerned about accessibility to tighten them later (as mentioned above) and quality (since it's in a fairly hot area).
  10. ocie
    I like those! I believe 11-13 mm is the size I need, since it meets the 5/16-1/2 SAE range. Thank you for posting this Josh!
    I was thinking avoiding the worm clamp would be better.
  11. pillboy
    I believe what I had seen was in reference to using worm gear clamps on plastic hose nipple applications such as radiators. The worm gear clamps do not spread clamping force evenly around their circumference and can cause a stress fracture of the nipple. I assume the hard fuel lines are metal and this possibility doesn't really apply in this case. I was just making a broad statement since we were talking about hose clamps.
  12. ocie
  13. MrBlue
    The ones @tangledupinblu posted are the correct replacement, they apply even clamping force all the way around without biting into the rubber line.
    You will need to check & retighten them when it gets below 0*, the factory hardline shrinks and then leaks.
    ocie and tangledupinblu like this.
  14. tangledupinblu
    ^what he said.
    MrBlue likes this.
  15. Krazylegz1485
    I must've missed the part where you said you're taking the intake off. Disregard the part where I said this will be difficult. Having the intake off will make this job infinitely easier.
    Also, I'll second or third the use of those non-slotted style clamps. Way better for fuel lines.
    You got this!
    MrBlue, ocie and tangledupinblu like this.
  16. ocie
    Haha thank you for the extra motivation. I picked up the AMR aluminum inlet pipe. The intake is gonna have to come off to get that to fit lol.
    These are the non-slotted clamps I ordered: https://www.amazon.com/gp/product/B0727Q4K6X/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Took a little sleuthing on Amazon but they're out there.
    Krazylegz1485 and MrBlue like this.
  17. ocie
    Anddd I'm just reading this now. Are you saying the 18-20mm ones that I need? I was under the impression the diameter of the 5/16 hose is a little under 1/2? I think the ones I ordered will suffice as they're not the worm-style clamps.
    Krazylegz1485 likes this.
  18. tangledupinblu
    Nope, he just meant that they are the right style clamp.;)
    Krazylegz1485, ocie and MrBlue like this.
  19. MrBlue
    This!
    You ordered the right ones.
    ocie likes this.
  20. ocie
    Money. Thank you both for that haha.
  21. ocie
    I think you bit off more than you can handle, kid.
    I attempted to remove the manifold last weekend and realized how disorganized I was, so I installed new spark plugs and called it a day. Looks like I'm going to wimp out and get a Perrin inlet...
  22. tangledupinblu
    Boo this man!
    ocie likes this.
  23. Krazylegz1485
    Boooooo!
  24. Krazylegz1485
    BOOOOOO!!!
    You got this, man!
  25. MrBlue
  26. joebush44
    joebush44 Well-Known Member
    You might be able to get away with just unbolting the mani so you have a few extra inches to play with (not remove it entirely). I've also found that unbolting the PS pump from the block and moving it out of the way (don't have to disconnect any of the PS lines) will free up some extra needed real estate to sneak the new inlet in.
  27. ocie
    Yeah yeahhhh.
    This made me chuckle though lol.
    You're thinking this route would allow me to get the cast aluminum inlet pipe in?
  28. joebush44
    Yep, that's how I got my AMR inlet on and off when I had it/changed turbo
    ocie likes this.
  29. idget
    ^what he said.... you don't really need to remove it completely... just get enough slack to lift the passenger side a few inches... those fuel hardline to manifold bolts are kind of a pain in the dick to get to.
    ocie likes this.
  30. ocie
    Thank you both, that does make me feel a little better. I've also noticed that AMR gives you a lot less **** than APS. Am I dicked if I don't get my hands on the additional hoses and what not?
    http://www.airpowersystems.com/wrx/intake/install.htm
  31. joebush44
    I can't say for sure what all you'll need for hoses. The only thing plugged into my inlet one of the ports that goes to my EBCS. With my AOS, BOV and evap delete, the other ports on the inlet are plugged. I don't think you can source a brand new APS inlet these days unless it's NOS from someone hoarding parts. You should be able to reuse your stock hoses with the AMR pipe, but you might have to get creative with some new hoses and/or reducers to mate them from the inlet to your existing hoses if the vacuum ports on the inlet are too big for the stock hoses. I remember I had to grind down one of the ports so I could fit a smaller hose over it without having to run a reducer, essentially making the circumference of the port smaller so I could fit the smaller ID hose on it (if that makes sense).
    ocie likes this.
  32. ocie
    So, update. I did indeed wimp out and install the Perrin inlet today which was still a pain in the ass, but it's in. I no longer have a stutter/hesitation when I put the car in first or reverse like i did previously, but I'm still not hitting boost.
    I checked the turbo as @joebush44 suggested, but it has minimal shaft play and freely rotates. I think a stop at JM may be in order to get a real diagnosis.
  33. joebush44
    Maybe take a look at your vacuum line routing going to and from your EBCS. Assuming you have a VF series turbo or the stock td04 the stock wastegate spring pressure would be around 9psi. So if you're peaking at around 9psi the EBCS or vac line routing is suspect.
    Port 3 connects to a high-pressure boost source (there is a vacuum nipple on the turbo compressor outlet). Port 2 connects to the internal wastegate actuator vacuum nipple and Port 1 should be routed back to the turbo inlet.
    I'm guessing you didn't reuse any of the stock boost control vacuum lines, but just in case...There is a "pill" in the stock 'T' vacuum line going from the compressor housing to the wastegate...you want to be sure you're not still using the line with that pill in it with the 3 port controller
    Good luck!
  34. ocie
    Thanks @joebush44. JM actually put the EBCS on the car before my tune last summer, so it looks like they did indeed replace the lines.
    I checked the wastegate and it seemed to move freely and didn't have any hesitation or get stuck when I moved it back and forth. The preload seems normal too. I sprayed a good amount of PB blaster onto the wastegate arm/c-clip anyway and took my car out for a test drive. It hit maybe 4-5 pounds of boost per my gauge but it didn't hold the pressure at all.
  35. joebush44
    Bizarre. You could try hooking up a vacuum line going directly from the wastegate to the turbo compressor, bypassing the EBCS all together. That should give you ~9psi (wastegate pressure). If you hit 9 lbs, I think that would rule out a turbo or wastegate mechanical issue. If you still don't hit about 9lbs, then you've narrowed it down to either the turbo or wastegate. Just throwing out some ideas...
    ocie likes this.
  36. ocie
    I'll be doing that this week for sure. Thank you for all the help, Joe. It's very appreciated.
  37. ocie
    I am starting to think my clutch gave out. I've been needing to rely on lower gears to get up to highway speeds and then putting it in fifth when I'm cruising. This is my first manual vehicle, so things like this just wouldn't have crossed my mind to begin with... It's just shy of 127,000 miles, but I have no idea if the clutch has ever been serviced.
    Would that make sense at all, even with my boosting issues?
  38. Krazylegz1485
    When my clutch went out in the Legacy I could basically floor it in gear and watch the tach race up. There was a pretty distinct spot where you could feel it give out and the rpm's would lift as it slipped.
    Maybe if the clutch is slipping you're not getting the motor under load like seems to be required in order to build boost.
    joebush44 and ocie like this.
  39. ocie
    This idea came to me while I was reading your Legacy thread lol, but that's my exact thinking. If I'm in fifth gear going say, 60, and I apply any pressure to even slightly accelerate, the RPMs spike up until I let it go and can feel it grabbing again. This happens in fourth too. Hill starts have been a pain in the ass lately too. A clutch replacement is a little more than I want to try and tackle too. :(
  40. Krazylegz1485
    That stinks. Might've found your issue, tho.
    What's your experience like with a wrench? It's really not that bad, just labor intensive. And you need the room to work, of course.
  41. ocie
    I've never attempted anything like this nor dropped the transmission before. I have a feeling I'd be in a world of hurt if I was attempting this on my own the first time around.
