  1. jdhunter6
    jdhunter6 Member
    Rattle can for now i wanted to see how it looked and held up befor I pay 300 for the kit
  2. that-dude
    that-dude Well-Known Member
    sickspeed horn installed and a trunk cargo for all the junk.
  3. that-dude
    how many cans anyway?
  4. Jim C
    Jim C Active Member
    Been trying to track down some steam coming from under my hood. It took me a couple of days to find out what was going on. One of the water hoses connected to my turbo was brittle and leaking. I replaced it and knocked the banjo bolt loose, so I didn't think I'd fixed the problem at first. It's good now.
  5. jdhunter6
    jdhunter6 Member
    10 total 8 for my car and 2 for my wheels.
  6. SCIFIDELITY
    SCIFIDELITY Well-Known Member
    had my winter wheels (stock) and tires put on. Discount Tire does it free if they did the mounting originally. A very nice service for people like me that don't anywhere to store a jack, stands, etc.
  7. Jim C
    Jim C Active Member
    Got my car dynoed at RS Motors, came up a little lower than I expected at 329 AWHP. May try without the exhaust baffles next.
    Ron also fixed a water leak on my turbo that I missed.
    LawnMaster likes this.
  8. euro
    euro Well-Known Member
    gotta do some touch up on the passenger A pillar, it's starting to surface rust. Friday i'm having it checked out to see if i caught an early head gasket leak.
  9. needboxer
    needboxer Well-Known Member
    Second lifted Subaru, 1" paranoid fabrications spacers, 215/60-16's for a total of about 2.2" of lift.
    Also, Flapatax flaps.
    I did realize one of these wheels is bent though, so I need another, if anyone has one for cheap.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    wrxwied, JuStaWRX, Nhibbs and 3 others like this.
  10. tehfuzz
    tehfuzz Well-Known Member
    Hung out with Nuke and company. Took it to stage two with the tune and got a after market dp and boost controller on. Thanks again guys!
  11. euro
    what all did you have to order from PF to do the lift?
  12. GregRoot198521
    GregRoot198521 Member
    Going out on a limb and going to say the 1" spacers. I'd go with Subtle Solutions over PF though, had nothing issues with the dude there (at PF, not SS, had no issues with SS) and his parts.
  13. needboxer
    Yep, just the 1" spacers. I went with paranoid because it was about half price and a machinist friend of mine said he expects exactly zero issues with HDPE (as in, not being able to handle the job).
    The rear clearance is very scary while its jacked up off the ground, in fact I was touching on the left side, and had about 2mm on the right.
  14. xluben
    Subtle Solution's 1" spacer kit has threaded holes. This is much more likely to be incorrectly torqued and cause issues down the road. I do not know why they chose this design. I specifically asked this question in their thread on the Forester forum and it was completely ignored.
    The Paranoid Fab spacers are just normal through holes. You torque the bolts like normal, and the spacer is sandwiched in between. I much prefer this. I had no issues with my order through PF, but it was just one order with no real interaction besides payment.
  15. euro
    so you didn't have any issues with the factory strut studs being too short?
  16. xodad2
    xodad2 Well-Known Member
  17. needboxer
    Paranoid offers extended bolts, you knock out (literally) the original studs and install new bolts. These are held with a nylon nut to the tophat (if you choose to use it) which it has a recesses for in the machining of the spacers. This allows the nuts and spacer to stay in place during install, although, clearance is a bitch on the rear.
    It's really driving nice, gotta fix my front camber though.
  18. bduncs
    bduncs Member
    Got some new DWS's put on today! Forgot to get some pics before the tires were installed. 225x45x17
    [​IMG][​IMG]
    tehfuzz and Legsaucy like this.
  19. that-dude
    Fresh New tranny and diff fluid from nf on the fozz.
  20. MightyP
    MightyP Member
    Washed, clay barred and the first coat of wax. Tomorrow, coat 2 goes on.
    tehfuzz likes this.
  21. Weird0
    Weird0 Well-Known Member
    After a long frustration month, I finally got my clutch working the way it should. All thanks to NF Performance! Oh, how I miss driving my Subaru!
    Nhibbs likes this.
  22. Nhibbs
    Nhibbs Well-Known Member
    Oh hey! I think I saw you at NF yesterday!
  23. Nhibbs
    Put this in this morning and took it for a spin. The extra weight is awesome! And I like that it sits lower too. Shifts extremely smooth now. image.jpg
  24. GregRoot198521
    Quite aware, have used both companies 1" lifts, the SS Aluminum spacers were a lot easier to use, even with it being a used kit and the PO having partially cross-threaded a hole. All the holes were in the right place and the bolts were aligned correctly for the strut towers. 3/4 of the PF spacers were horribly misaligned, and I still had to use 2 people to tighten up the nuts on top. The extra cost for the SS kit is worth it, IMHO, and if I go the spacer route on this STi, I'll go with their kit again.
  25. Weird0
    Yes that was me. Sorry, I was in a bit of a rush so I didn't get to chit chat. I recognized your car parked out front. I was good to see yah though
    I see you got your heavy shift knob on. haha
    Nhibbs likes this.
  26. Vinnie
    Vinnie Well-Known Member
    It was a Cusco day for me:
    Cusco steering rack
    Cusco front lower arm bar
    Cusco power brace crossmember
  27. SCIFIDELITY
    Whiteline steering rack bushings. They made a big difference. Car feels more connected to the road; there's a lot more feedback and the car is a lot more responsive to my steering. I also met Vinnie, good guy, slick looking rig.
    ma_deuce and Vinnie like this.
  28. MightyP
    MightyP Member
    Finished waxing the car and decided I really need to invest in a power buffer. The paint feels awesome, but now every little blemish sticks out! And to prevent the comments/questions, I went with a paint sealant rather than a carnauba wax.
    It's kinda funny you just put on a weighted shift knob. I just went back to stock cuz my weighted knob got so cold.
  29. MNGman
    MNGman Well-Known Member
    apparently a certain group off Subaru owners pissed off the local deer population near County Road 7 a couple weeks ago. One of them decided to take its revenge this morning.
  30. bduncs
    bduncs Member
    Ouch. Sorry MNGman, hate to see that… Venison?
  31. Vinnie
    It was nice to meet you and put a face to a post!
    SCIFIDELITY likes this.
  32. DIRTY D
    DIRTY D Well-Known Member
    Let us know how it go's & how it feels driving. ***********nice************D
    Vinnie likes this.
  33. Vinnie
    Needless to say, im impressed! I put this on not thinking I would feel much but man., I was wrong. It stiffened up the steering tremendously. The stock steering is really messy and this tightened everything up........ a lot! I mean the car literally feels like one piece in the front.
    Next step is the rear. I bought some bushing inserts for the rear diff and subframe along with a Cusco power brace rear cross member. Hopefully it does the same for the rear as it did for the front
    DIRTY D likes this.
  34. DIRTY D
    pretty straight forward bolt & play any hassle with the install. **************thanks D
  35. tehfuzz
    what kind of shift knob is that?
  36. Vinnie
    Yep, just unbolt and bolt up. My cross-member bolts were really on there but after a half can of PB Blaster and a little bit of cusing I got them all un-fused
    I had another MNSubie member (@ma_deuce) helped me with the lateral brace install because there was no way my impact wrench would break the bolts. Surprisingly those were easy!
  37. Nhibbs
    Anarchy Motive. 1.5 lbs of milled steel. Xluben has some in stock, otherwise I think they are back ordered.
  38. tehfuzz
    Sweet. I am buying @Mike 's tonight . I am excited to check it out.
    Mike likes this.
  39. Nhibbs
    I have driven a fair amount with it now and I can say I am extremely happy with it! It isn't even too cold in the morning either, I guess it has a pretty thick powder coat. I was pleasantly surprised with it.
    MightyP and tehfuzz like this.
  40. TMF
    Oh ****! sorry to see that Glen...I guess we did stir up a few...
  41. JuStaWRX
    Replaced a headlight bulb, and noticed that one of the orange parking lights? (top corner, little orange fella) was burnt out. I picked up some replacements (one set of LED and one set of the regular bulbs) to replace that, but was curious (noob question...) of what is the best route of replacing that bulb. Does the whole headlamp assembly need to come out? If so, is there a need for re-leveling etc? Any pointers?
  42. Hagadorn
    Hagadorn Member
    What year? Mine where out when I got my car and u had to pull the whole light out. There was no need to re-level mine when I put them back in. Mines an 04 wrx
    JuStaWRX likes this.
  43. JuStaWRX
    Yup, 04 as well. Thank you!
  44. Vinnie
    Ok, perfect. I know right where it goes and how to install it this weekend
  45. FlawlessFrontEnds&Tint
    FlawlessFrontEnds&Tint Vendor
    Don't forget to torque the bolts to the specs they say, too:facepalm:
    Vinnie likes this.
