  1. GregRoot198521
    GregRoot198521 Member
    I keep checking it every day or so, no rubbing (at least no signs of it) and no coolant issues. I'll keep monitoring it though.
    Ryan FailRad likes this.
  2. Ryan FailRad
    image.jpg Lol that tab?
  3. tangledupinblu
    No Failradian, that is the upper resevoir. Greg broke his radiator. You lose!
    Did you ever find a replacement resevoir, or are you actually using that beaut? I haz one...
  4. Ryan FailRad
    I'm using that one. It works just fine, little bit of jb weld and a brass fitting did the trick. I wouldn't mind having one that wasn't repaired though lol. Maybe with the turbo? ;)
    Ps im pretty sure he broke the upper reservoir
  5. Scott
    Scott Well-Known Member
    Sounds like a part out party @tangledupinblu garage. Everyone must bring own tools and plenty of cash to fill my pockets. Being that I am the organizer of the event. I get first shot of a bigger turbo and addons. And the pshhhhhh part.:thumbup:
    Please no loud noises. The baby will be sleeping.
    Ryan FailRad and tangledupinblu like this.
  6. clajiness
    clajiness Well-Known Member
    Installed my dash cam today. I chose the Cobra 825E based upon it's features, and the inclusion of the suction cup and adhesive mounts. It's a little pricey, but I liked buying a known brand. I also installed one of the Dash Cam Store's installation kits. http://thedashcamstore.com/installation-kits/ Being able to keep the wiring clean by piggybacking off of another fuse makes me happy. So ya, expect lots of videos of ****ty drivers in the future! :)
    JuStaWRX likes this.
  7. MNGman
    MNGman Well-Known Member
    Summer attack mode.
    AST 4150 Coils, Enkei RPF1 in Gunmetal.
    idget, Aluminati, JuStaWRX and 3 others like this.
  8. GregRoot198521
    Believe it was that one actually. Tapped it with my elbow, so figured an upgrade was worthwhile.
    Wrong, but partially correct. My rad was starting to seep, but it was still working. Failrad didn't fail (for once), but my rad was on its way to.
  9. tangledupinblu
    Shhhhh, don't tell him that!
    Ryan FailRad and GregRoot198521 like this.
  10. Ryan FailRad
    I lose!!
  11. tangledupinblu
    Yes you do.
  12. Ryan FailRad
  13. MNGman
    Finally got around to installing some gauges and a SMY gauge hood. PODI gauges, the fonts are as close to Subaru as you can get without copyright infringement. The color was supposed to be dead on, but I am seeing a little bit of a difference. I haven't installed the temp gauge sending unit. Still up in the air on whether to use for water or oil temp.
  14. tangledupinblu
    Looks really good!!!
  15. Ryan FailRad
    I would do oil for the winter
  16. iridium7777
    iridium7777 Well-Known Member
    did you move to russia while you're at it?
  17. clajiness
    Nope, but with things like this out there, I like the little bit of protection it gives me.
    Plus, who doesn't like internet shaming ****ty drivers once in a while?
  18. tangledupinblu
    "You didn't see the red light!?"
    LMFNAO
  19. Shabbaru
    Shabbaru Active Member
    Arguably my favorite thing I've done to my Forester since I bought it, GR STI seats in my SG9 XT.[​IMG]
    twiztid_rs, ryjacobs and clajiness like this.
  20. TMF
  21. atacamaR
    atacamaR Well-Known Member
    NF driving school prep: repairs...
    sprung a leak
    target acquired: replacing center diff in the 6spd
  22. tangledupinblu
    Went from my hella tight wrb stockers, to my hella light Rota's...son! :unsure:
    Ipotato camera ftw
    twiztid_rs, Cotts612 and Ryan FailRad like this.
  23. Cotts612
    Cotts612 Well-Known Member
    Just got my wheels aligned at Northwestern tire for $69.95! They're running a special for this month on alignments, and I did even know about it when I dropped the car off this morning. Surprise!
  24. TMF
    My car was going through withdrawals so it was time to hit the boost booze again. Back to E85 but on the new turbo :)
    I need to make a build thread one of these days.
    Ryan FailRad, tonyv and Aluminati like this.
  25. pillboy
    Took the snow tires off. After 9 winters (I don't have a long way to drive to work, so the snows see only about 3,000 miles a season) the Dunlops have surprising little weather checking, and what little they have is between the tread blocks...the sidewalls look great. I think I can get at least one more season out of them.
    twiztid_rs and tangledupinblu like this.
  26. Shabbaru
    For sure going to hack up a GR STI aftermarket axle back for my next exhaust after photoshopping this... [​IMG]
    twiztid_rs and JuStaWRX like this.
  27. alzilla
    alzilla Member
    Got my 30k service done at Morrie's and had them install my Perrin catback:
  28. Shabbaru
    See that's what I want on my forester
  29. Ryan FailRad
    @tonyv has a good candidate exhaust for that project
  30. silver03
    Nothing fun...replaced front right CV axle on the 05 Saabaru. I learned (thank you @Todd), to float that clip on the transaxle end in wheel bearing grease and use the axle as its own slide hammer when installing. I just couldn't get it all the way in. Never had that issue before.
  31. atacamaR
    Replaced the center differential this weekend. I dropped more than a few f-bombs trying to slide center diff and extension case over those two 2-piece needle bearings. If i ever have to do this job again a lift or taking the transmission out of the car is the way to go. It's just not any fun crawling around doing everything on your back.
    Worked on my first timing belt change too. I pulled timing belt and avcs cam driver side. NO filter behind the oil line behind that left side avcs cam. I was hoping to find a dirty one at the banjo there. :banghead: I'm going to flush the hard line on that side but really out of ideas on my ongoing avcs issue.
    fav. quick pic of the weekend:
  32. twiztid_rs
    twiztid_rs Well-Known Member
    That looks great, but with the design of our vehicles you will have to do a ridiculous amount of fab work to get the dual exit look to work out. The fuel tank on the passengers side is going to be the biggest issue. I'd love to have this on my Forester as well but it would be tough to pull off. If you manage to make it work make sure to document it, I'd love to see the process on it.
  33. TMF
    I think a fully custom fabbed quad exhaust will be the "easiest".
  34. Shabbaru
    This guy did it, all he had to do was cut up the crash bar under the bumper a bit and cut some holes in his stock bumper!
  35. techguymaxc
    techguymaxc Well-Known Member
    Got it dyno'd @ RS after a turbo upgrade by NF (PTE 55mm stock location). Low boost results (18 PSI) look strong, pulls hard to 7k now, just need to get a bigger fuel pump and then we should be able to make a bit more power at around 23-24PSI.
  36. Ryan FailRad
    What fuel pump are you currently running? Moar info please! Lots moar info!
  37. techguymaxc
    Running a DW65c in-tank 265LPH pump.
    Go fast bits:
    ID 1000's
    2005 STi FPR (for GR stumble)
    South Bend Clutch - Stage 3 Endurance (rated at up to 595 lb/ft)
    IAG TGV's with 3mm phenolic spacers
    KS Tech 73mm CAI
    Invidia 3" cat-less downpipe
    ETS TMIC with taped endtanks (DEI Reflect-a-cool)
    Killer B Holy Header & up-pipe
    Tial 38mm EWG with open dump
    SPT cat-back (came with the car)
    Perrin 3" inlet
    Air pump delete
    Turbosmart Kompact BPV
    Grimmspeed EBCS
    PTE 55mm stock location turbo
    PTP turbo blanket
    header/downpipe/uppipe wrapped in DEI Titanium
    other parts:
    AEM UEGO AFR/boost gauge - dash mounted in ATI single gauge pod
    Killer B alternator & radiator shrouds
    Kosei ultra lightweight 17s
    Hankook RS3s (255/40/17)
    black & red Rally Armor flaps
    Torque Solution short shifter + bushings
    That's everything I can remember... Running E85.
  38. Ryan FailRad
    What fuel pump are you going to switch to?
  39. Aluminati
    Aluminati Vendor
    Saw your car at NF Saturday when I stopped by. I run the dw65c on a 60mm turbo and 25psi. But have 1650cc's and built motor lol
    techguymaxc likes this.
  40. techguymaxc
    Nuke recommended the new DW300c 340 lph in-tank pump. I think that will allow us to run more pressure and flow more fuel instead of using larger injectors. I just had those ID1000s installed in January, would suck to have to replace new parts already.
    Aluminati likes this.
  41. Aluminati
    Aluminati Vendor
    Yeah new injectors aren't cheap :(
    I'll get on the dyno one of these days. Should make 400whp or so.
  42. techguymaxc
    I would think more like 450 with a 60mm and 25 lbs. You should stop over at RS and find out, it's not terribly expensive for a baseline run (no tuning).
  43. Aluminati
    Aluminati Vendor
    I was planning to do a before and after but they didn't respond soon enough.
    I'm curious what it makes.
  44. xluben
    Should be between 400 and 450 at RS. Mine made 457 at RS with the same setup (same actual turbo) but I was at higher boost.
  45. techguymaxc
    I wondered if that was your old turbo, 60mm is a rare size.
