  1. JasonoJordan
    Installed new head unit in the brz. Can't get the backup camera to work. Ordered a new one to make sure its not a camera incompatibility issue.
  2. Vector
    Vector Rally Organizer
    Stock backup camera? The camera used in the 2015+ WRX (and likely a lot of other current and recent models) requires a +5vdc power feed, not the +12vdc you might expect.
  3. Navar Hren
    Navar Hren Active Member
    Aftermarket. Most likely the same power supply it was getting pre-new radio.
  4. JasonoJordan
    No was wired different for the stock setup. The stock setup checks for the camera on boot so you had to have it wired into a constant 12v source. I changed the wiring for the new radio to the standard tied into the rev light circuit. Still no go. Ordered a cheap (although highly recommend via reviews) camera. Will be here today so will install that one and see if that fixes the issue.
  5. UnquenchableOne
    UnquenchableOne Well-Known Member
    Installed my Screaming Banshee Shockwave horn. mounted it in the engine bay next to the battery. figured less wear there and much easier than taking my front bumper off. routed the horn to an LED button i mounted in the car so i now i have 2 horns. One for me, and one that a passenger can hit if they want too since it is mounted in the center.
    https://screaming-banshee.com/products/banshee-horn
    123 decible air horn.
    Krazylegz1485 likes this.
  6. JasonoJordan
    Got the issue fixed. Was just the installer was an idiot...You would think yellow rca wire from camera into yellow rca port on radio...yea no the radio backup camera jack was brown...and no where in the book that I found did it have the back panel pictured with what the ports were. Only thing telling me that it was the correct port was engraved in the metal back plate on the radio was bkc..backup camera I guess. Plugged in there worked like a charm.
  7. Krazylegz1485
    Holy cow. Just watched a YouTube video of it. Did you hook it into the lights and stuff or just for sound? Seems awesome.
  8. JasonoJordan
    the people that ride with me are not adult enough for their own horn button...lol
    Navar Hren and tangledupinblu like this.
  9. tangledupinblu
    QFT!
  10. tangledupinblu
    Must see/hear in person!!
  11. UnquenchableOne
    here is my horn and button placement
  12. ocie
    ocie Well-Known Member
    The nickel-sized windshield chip that's been on my car for at least a year finally spidered out. The crack is like 3 feet in total, straight across my windshield :unsure:
    Having a shop come pickup my car, replace it and bring to back to work for me.
    If you look in front of the steering column, you'll see the white line that'll go across the majority of the windshield...
  13. tangledupinblu
    I've gone 880 miles on my fresh oil change and today...added a quart. Lmfnao
    GrawvyRobber and Deathly like this.
  14. CornyTumbleweed
    CornyTumbleweed Well-Known Member
    Now that's a thirsty Subaru. I'll bring you an extra quart of t6 for the cruise.
  15. tangledupinblu
    8 quarts per oil change...because Subaru.
    GrawvyRobber likes this.
  16. Krazylegz1485
    You're supposed to put the plug back in BEFORE you add the oil.
    Deathly likes this.
  17. tangledupinblu
    Wait...there's a plug?
    Deathly likes this.
  18. Niz
    Niz Well-Known Member
    Wanted to see what Torque would look like on a tablet...will probably stick with my phone.
    Also bought a dash cam and tried it out today. Video quality is not that great even though it's supposed to be 1080p but can't complain for $30
    ( I don't drive with the tablet mounted like that :thumbup:)
    TMF likes this.
  19. tangledupinblu
    You'd be alot cooler if you did man!
    Krazylegz1485 and Niz like this.
  20. JasonoJordan
    Took advantage of the nice day we have today. I removed my spare a couple years ago and since have had an issue with stuff falling into the space the spare tire used to reside in. To fix that I have made a cover plate with a hatch so I can use the spare tire area for storage of things.
    Nothing pretty here just functifonable. Will add a handle and a hinge to the cover in the future. Plan to use a stock all weather trunk liner ontop of it.
    TMF likes this.
  21. tangledupinblu
    That's some nice ball storage you have there!
  22. JasonoJordan
    Meh figured would be nice to have a small space in the trunk to store things I keep in the car without robbing it of trunk space or have them rolling around while hoooning
  23. Krazylegz1485
    My sub box frequently falls victim to the hoon.
  24. Navar Hren
    Bolt the sucker down. Or sell that shiz, and put a pancake under your seat.
    Deathly likes this.
  25. JasonoJordan
    I like pancakes
  26. Krazylegz1485
    I prefer waffles.
    I've considered a powered 8" or something. Nice little self contained thing. Would probably put.out about as much as what I've got now, and I'd maybe even be able to feel it more if it was right under the seat.
  27. GrawvyRobber
    GrawvyRobber Active Member
    Cleaned the MAF sensor and brake/clutch fluid flush. Nothing major but prob first time since it rolled off the lot..
  28. tangledupinblu
    Did i give you a sample listen of my setup when you stopped by? It's not small enough to fit under the seat, but the box has a super small footprint in the trunk! And bolting it down was a must. Because rallyrallyrally!
  29. Krazylegz1485
    Unfortunately I've yet to see your backseat. Would definitely like to check it out tho. I've got a single 12" sealed box currently so it's about as small as it can get unless I switch to a truck style box or downsize the sub completely. The one nice thing about the current box is the angled side matches the back of the seat perfectly.
  30. ocie
    That's nuts lol. I changed my oil yesterday and it looked like I burned 3/4 of a quart of T6 in 3000 miles, maybe less.
  31. tangledupinblu
    Hybrid 2.0/2.5L FTLofOIL.:(
    There is a benefit tho...alot more torque than a 2.0L bugeye!:D
  32. JasonoJordan
    Is your torque measured in quarts of oil lost per rotation?
  33. tangledupinblu
    QOC=Quarts of Oil Consumed, but yes.
  34. klutz
    klutz Well-Known Member
    Backed up into a neighbor who was driving wrong way in the alley this weekend. The REX just wanted some new paint :(
  35. Krazylegz1485
    Niaoooooooo (Arnold voice)
    klutz and tangledupinblu like this.
  36. WRXCarl
    WRXCarl Well-Known Member
    Washed it!! Yea crappy parking garage picture at work.
  37. TMF
    Bungee cord the sub box to your headrests. Simple, functional, easily removable.
  38. tangledupinblu
    Just got started at 5:15pm. Outer tie rod on the WRX driverside...
    Yep.
    20 minutes.
    Praying that the other side goes as well!*fingerscrossed*
  39. tangledupinblu
    Other side is done. Went just as quick!:thumbup:
  40. tangledupinblu
    Thank you KrazyLegz for the assistance! And Sheen for mobile m-oral support.
    Off for an alignment tomorrow!
  41. Bugeye18
    Bugeye18 Member
    Finally back in a Subaru. Test fitted some new shoes today :) IMG_1887.PNG IMG_1889.PNG
  42. JasonoJordan
    Ordered new rubbers for the BRZZ. nitto nt05's. Measured remaing tread on my continental dw that im taking off. If anyone is looking for some tires you could buy two new conti dw and match up to the tread depth on my 245's
    Navar Hren likes this.
  43. Niz
    Just tryna fit in...
  44. WLGT
    WLGT Well-Known Member
    Detailed in and out and tried out Chemical guys black wax
  45. WRXCarl
    Yellow Fogs & took the emblems off the trunk lid. :D
