  1. Krazylegz1485
    This rules. Damn I hate rattles/squeaks. Have one right now I think in my left rear door (that direction at least). Sounds like styrofoam squeaking. Ugh!
    Fienix likes this.
  2. Fienix
    Fienix Well-Known Member
    I HAVE IT IN THE REAR RIGHT DOOR! Let me know if you find the problem.
    Krazylegz1485 likes this.
  3. tangledupinblu
    Probably the metal door handle release in the door. The tend to rattle if the foam where’s out(because old) or falls off(because rallyrallyrally). I used some of the thick 3m double sided tape and wrapped it around a couple of times.
    Sometimes i miss my squeaky GD.
  4. Eric Carlson
    Eric Carlson New Member
    I spent 3 hours cleaning my engine bay using a toothbrush (for scrubbing), water mixed with a tiny bit of dish soap and shop towels.
    My plastics are looking great, but all the ugly metals and rusty coloring near the timing belt makes it look like nothing was done lmao
  5. tangledupinblu
    Noticed that the gas pump handle matches my rims. Nope, wasn’t bored at all.
    pillboy, Cotts612 and Krazylegz1485 like this.
  6. pleiades
    pleiades Well-Known Member
    I had a similar sound in my bugeye from the same area, in my case turned out to be the driver's seat belt squeaking where it runs through the height adjuster. Scuffed up the plastic a little and it went away.
  7. Navar Hren
    Navar Hren Active Member
    Wheels, peasant!
    derp, Dan4914, jubella2 and 3 others like this.
  8. jubella2
    jubella2 GC8 FTW
    I also switched out to the winter set Monday night. The summer tread was getting louder and stiffer with the cold temps. Winter tread feels like riding a cloud
  9. MN_XV_712
    MN_XV_712 Well-Known Member
    I went ahead and put my new "winter" wheels on today. Got to say, loving the look! 15" Method Race Wheels MR-502 V-Spec wheels wrapped in 225/70/15 General Grabbers AT2s.
    Dan4914, Leonnosyt, MNcrew952 and 5 others like this.
  10. tangledupinblu
    Giggity!
    MN_XV_712 likes this.
  11. MNcrew952
    MNcrew952 Member
    Love the theme.
    About a month old, but got rid of the nasty chrome housings and de-badged the booty.
    Dan4914, MN_XV_712 and tangledupinblu like this.
  12. Leonnosyt
    Leonnosyt Member
    Got my six speed badge and reverse lockout installed from Output Motorsports in Australia. The badge is a recreation of the factory 5 speed badge that came on the first gen legacys.
  13. subie-roo
    subie-roo Well-Known Member
    59A78309-C10D-46F4-8347-A624CAF0A71C.jpeg Since the Legacy is about to go into hibernation I gave my winter wagon a makeover. I’m very excited to be able to see at night while driving.
  14. tangledupinblu
  15. subie-roo
  16. MidnightImpreza
    Winter wheels today.
  17. ocie
    ocie Well-Known Member
    Woke up to a flat tire... So I threw on the spare, drove across the metro and back and put my winter setup on.
    Anyone have experience with the Tire Rack Road Hazard Protection claims? I purchased the Hanhook Ventus V12 Ev02s back in May 2017, so they fall in the two-year coverage window.
  18. idget
    "general maintenance." At least as far as turbo Subarus are concerned.
    ryjacobs and tangledupinblu like this.
  19. tangledupinblu
    How did the others look? Also, lmao
  20. idget
    150, 120, 150, 150
    Guessing cylinder 2 is a stuck valve, dropped valve guide, cracked seat, etc... Also guessing the were never lashed. Also also guessing it has the original clutch. Sure doesn't look like the bell housing had ever been cracked and the clutch fork pin and access cover both looked untouched.
    In any case I'll know more Wednesday when I pull the motor and start undressing it.
  21. Krazylegz1485
    Changed oil and swapped winter's on the WRX and the wife's Civic (98) on Saturday. Also changed oil in the truck (92 GMC). I continue to enjoy how simple it is to work on a Subaru. Oil pan drains to the passenger side which is conveniently where the filter is located. What's that? Oh yeah, the filter is mounted vertically and not directly above anything stupid, and the oil drains right into the same pan! Oh sh!t, that's brilliant!
    The GMC filter is horizontal and drains directly onto the front u-joint of the 4wd driveshaft. Guess I never need to worry about it rusting.
    The civic filter is also horizontal, and it dumps on what feels like part of the block casting, which then proceeds to run right onto the exhaust. Perfect!
    Sidenote, the Subaru's are the only vehicles that we have with vertically mounted filters. I know it's not necessary (because on most vehicles it's not possible) but does anybody else fill the filter with oil first before putting the new one on?
    pcwerk, tangledupinblu and joebush44 like this.
  22. joebush44
    joebush44 Well-Known Member
    LOL! And yep, I am also a member of the pre-filling the oil filter group.
  23. tangledupinblu
    Me as well! Um...well i used to be.
    joebush44 likes this.
  24. idget
    yes. Isn't that standard practice when applicable? Along with lubing the gasket? If nothing else it makes taking an accurate measurement easier.
  25. Krazylegz1485
    It is for me, I guess. Guy I used to work with taught me that as a way to prevent oil starvation right at the first start up. I'm assuming it's not that critical considering they're putting filters upside down now, like Josh's.
  26. idget
    More routine maintenance
    Really don't understand how some of you people burn through clutches. This one looks original to the car
  27. tangledupinblu
    I got 138,000 miles out of my clutch from the blue bugeye. The only reason that i pulled it then was because Mike rebuilt the trans. Lol. Clutch was still good doe.
  28. idget
    Nice! 176k on this one.
  29. tangledupinblu
    Kids these days, granny shifting instead of double clutching.
    MidnightImpreza and jubella2 like this.
  30. Fienix
    Had a local deer help me out with some cosmetic MODS. I think I'll have to take it to a professional to help me fix his mistakes... What does the urinal think?
  31. skubi1
    skubi1 Well-Known Member
    Both the headlights went out at the same time 2 days ago, so had to leave it at work the other night...picked up new bulbs and fuses (changed out 3...30A for the low beams, and 2 15A for the R and L side lights) for good measure. Fuses looked blown. Popped back on, was just weird that both went out at the same time...scouring the interwebs said that it's not likely but can happen, so thought I'd give it a shot. Glad I didn't have to take it in to have them figure out an electrical problem!
  32. JasonoJordan
    Fuses that large don't just blow out for no reason. So I would think that you will be experiencing it again soon if they were actually blown.
  33. idget
    Insurance?
    On the cheap cheap i'd just replace the fender then pop most of the door out. Should be able to get everything but the wrinkles out with the door card and handle off.
  34. Fienix
    I have $1k deductible... I think I'm going to do exactly this. I need to replace the right side fender as well, so just get two new fenders, pull the handle, pop the door dent out and do some body filler.
    I was doing about 20mph when it hit. At least it didn't shatter the window.
  35. idget
    Somehow missed the a-pillar and side mirror too! Congrats?
    Re: filler/sanding. Probably way easier to pull the door off and lay it on some sawhorses or a workbench after popping/smoothing the dents with the door still on the car. The 2 divots in the rear door look like they can probably be popped up with a glue bridge puller.
    Speaking of which I almost smoked 3 (the same?) deer driving through como park at like 7pm last night. That would have been... lovely.
  36. Fienix
    It did hit the mirror, but didn't cause any damage, just folded it in.
    Deer are everywhere in the metro area it seems like. I guess that's why there's no limit on anterless in the 601 area.
  37. idget
    Stopped by JM to grab heads.
    Continually impressed by the growth, parts availability, capacity, and general badassness of @jmyhre05 and crew.
    Inspected and started reassembling the motor.
    Found like 30 pre honeywell filters and a ton of prosport and defi gauges while digging through the garage for razorblades... Some seats, harnesses, sensors as well... Nothing I needed but apparently I'm a hoarder...
    Mnelson, tangledupinblu and JaloP like this.
  38. tangledupinblu
    Hey, I recognize some of dem stuffz!!
  39. ryjacobs
    ryjacobs Well-Known Member
    Sprayed the rear wheel wells with 3M rubberized coating, put on some coilovers covers, then mounted the winter wheels on the FXT.
  40. jubella2
    jubella2 GC8 FTW
    I like your garage
    ryjacobs likes this.
  41. Mnelson
    Mnelson Well-Known Member
    Getting ready to do a wheel bearing this afternoon. Thankfully my dad's garage is heated, unlike mine. I really need to stop buying **** i have to fix in the winter.
  42. tangledupinblu
    What’s sitting next to the Fozzy?:)
  43. pillboy
    So true. Nothing turns you faster from being a car enthusiast.
  44. Mnelson
    Yupp.. This wheel bearing is an absolute mess. I loved working on cars but this may have ended that.
  45. Mnelson
    Update: Wheel bearing is done!! They absolutely suck but now I have the tools, if anyone ever needs to borrow them.
    My dads 68 firebird
